Old 10-03-2009, 05:09 PM   #1 (permalink)
Philip's Avatar
Towing with the Elise - yes, no joke
Greetings.
Since I now have a double set of tires (street & track) I am planning on towing a very light trailer (120 lbs) with my track tires on it (and a few tools.) The whole thing should not exceed 200 lbs.
Anyways... the trailer came with electrical connections so it can show when I brake, blink right/left, have my lights on.
Now for the trick question, anyone can indicate to me how to connect those 4 wires to the Elise? I figure I can piggy-back from the trunk and I can also figure it out by myself but if anyone has done this before...
Thanks!
Philip is offline   Reply With Quote
Old 10-03-2009, 05:15 PM   #2 (permalink)
I am more curious on how you are rigging up the hitch
Southernguy is offline   Reply With Quote
Old 10-03-2009, 05:18 PM   #3 (permalink)
thread killer
jasper's Avatar
Phils done it, and i looks feasible
check out BOE
2006 Exige (wife's car)
2005 Caterham Superlight (4 wheel motorcycle)
2004 Subaru STI (Urban Assault Vehicle)
1966 Lincoln Continental - in progress (dropped and chopped)
jasper is offline   Reply With Quote
Old 10-03-2009, 05:53 PM   #4 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
I've built a bunch of tow bars for the elise/exige, FWIW.
Info in my sig that links to the LT thread and then a few pics on BOE site... It's doable. I tow a trailer all over the place with tires, tools, jack, tents, and chairs and I'm sure it weighs over 200 lbs. No step too big for a stepper
Best,
Phil
Old 10-03-2009, 06:01 PM   #5 (permalink)
Alarmed & Dangerous
TheViper's Avatar
You could splice into the brake and indicator wiring and route the wires though the rectangular hole that most (not all) cars have above the rear license plate. One word of caution, the resistance of an additional indicator bulb may cause the flashing rate to change.
Originally Posted by Philip View Post
Greetings.
Thanks!
Old 10-03-2009, 06:56 PM   #6 (permalink)
Elise...Best Daily Driver
British_Marques's Avatar
Big negative there on the splicing. Our Lights (LEDS) do not like the scotch locks. The stock '05 lamps are okay, though. A way to do it is, sans the third brake light and use that for your trailer brake lamps, signal are okay as they are not LED. Or you can cut and solder into the LEDS wire harness and all will be good. I hope this little tid bit helps.
2005 Elise, Starlight Black/Red, Modified tilting clam, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and Cup Wheels & Tires.
British_Marques is offline   Reply With Quote
Old 10-04-2009, 10:14 AM   #7 (permalink)
Philip's Avatar
"Sans the third brake light"? What exactly do you mean by that?
Thanks
PS: and yes, I am using the BOE tow bar. I just received it 3 days ago. I'll take pics of the install but it looks fairly easy.
If you access another part of this site: BOE TOWING BARS- VERY limited Supply
You can see how it is installed.I also just noticed that TurboPhil did not install the electrical system which came with the Harbor Freight trailer. Maybe I do not need it as well but since I'll do some late evening back traveling (back from the track) perhaps just installing some battery powered red lights would be enough... I'll think about it.
Old 11-06-2009, 12:52 PM   #8 (permalink)
I just got a BOE tow bar too. How did you end up wiring your trailer lights? I have a 2006 Exige so all the tail lights are LED. I don't want to mess anything up when I tap in for the trailer lights.
Thanks,
Dan
DrTurbo is offline   Reply With Quote
Old 11-09-2009, 01:37 PM   #9 (permalink)
Philip's Avatar
Brake lights for the trailer off the Elise
Well, after reading the possible troubles that awaits someone wanting to tap off LED lights/circuits, I decided that it would be much more convenient to attach my own set of LED lights to the trailer. So I went to a bike shop and got 4 bicycle lights. The ones I got have 5 LEDs each. I turn them on by default (even in day time) as I drive. The batteries, it states, last over 70 hours of "on" time.
I attach them with velcro. I drove with that set up over 300 miles 3 weeks ago and did not lose any. ;-) This is very simple and headache free.
I also taped reflective tape all around the trailer.
Old 11-09-2009, 02:02 PM   #10 (permalink)
spf4000's Avatar
Trailers need working brake lights per CA regulation:
Trailer Lights
Trailers in California are required to have reflectors, tail lights, brake, and license plate lights. Also, signal lights are required if the tow vehicle lights are hidden. Trailers over 80 inches wide must have clearance lights. Most manufacturers comply with these requirements, however, it is up to you to be sure that all lights operate correctly.
CA DMV
spf4000 is offline   Reply With Quote
Old 11-09-2009, 04:15 PM   #11 (permalink)
Philip's Avatar
With the small trailer as obtained via Harbor Freight, even with the tires loaded, on the Elise (lights are fairly high) one can easily see the car's brake lights and turn signal lights. I am using the front license plate as the trailer's license plate and that can also be easily illuminated by clear LEDs. Reflectors can easily be added (glued or velcro'ed). So, yes a cop could still pull me over technically. It all depends on his or her mood that day whether or not I would get a ticket.
