Old 12-03-2008, 08:30 PM   #1 (permalink)
Add Lightness
xeeeejme's Avatar
Transmission Ground
I recently had the transmission replaced under warranty. I have been having some troubles starting the car & it's not the battery. Can someone tell me where the ground is on the transmission? Pictures would be awesome, if you have any.
Thanks for reading.
search...ground, transmission, cable, starter, battery, loose, crank, turn over, jump, jumper
'06 CO Exige - sold
xeeeejme is offline   Reply With Quote
Old 12-03-2008, 08:36 PM   #2 (permalink)
Casey's Avatar
The ground is on the front(firewall) side of the tranny. If you are going for it from the top, the intake tube will be in the way. It is probably easier to drop the mid pan...then you can't miss it. It's a large braided metal cable with a 17mm bolt holding it on the trany case and a 13mm nut holding it to the ground junction on the firewall. I would also check the battery cable at the starter...12mm nut to verify that it is tight.
Casey is offline   Reply With Quote
Old 12-03-2008, 09:04 PM   #3 (permalink)
Add Lightness
xeeeejme's Avatar
Perfect, thank you. I'll check it from underneath.
Much obliged!
'06 CO Exige - sold
Old 12-05-2008, 02:14 PM   #4 (permalink)
Add Lightness
xeeeejme's Avatar
Can someone look up the size of the bolt that holds the ground to the transmission?
Thanks!
'06 CO Exige - sold
Old 12-05-2008, 07:21 PM   #5 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
'05 AR Mods: Stebel Nautilus horn; tesprit's rearview mirror; Custom Interior Pictures; PPF full front clam wrap
Old 12-05-2008, 07:37 PM   #6 (permalink)
Lotus Service
twaszak1's Avatar
Thanks!
17mm socket
it is the same bolt size that holds the clutch line bracket
twaszak1 is online now   Reply With Quote
Old 12-06-2008, 06:20 AM   #7 (permalink)
Add Lightness
xeeeejme's Avatar
The bolt was missing, so I had to go to the hardware store to pick one up. I was actually curious what size thread it was, how long, etc.
I found one that worked through trial & error.
'06 CO Exige - sold
