Old 06-12-2009, 10:12 PM   #1 (permalink)
Form and Function
plastique999's Avatar
Turn Signals, Alarm, Immobilizer not working...
After a track event, my turn signals and alarm/immobilizer aren't working. My headlights and tail lights work fine. Everything else electrical works fine.
Is this a fuse issue....or something else?
My battery is also having trouble holding charge....have to trickle it even after a day's ride.
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 06-13-2009, 04:57 AM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
a) Although the turn signal lights are used by the alarm, they are independently fused and controlled also, and should still work for signaling, do they? Check fuses F6 & F9
b) Does the interior light work?
c) Check fuse F11 & R2?
d) Have you done any work on the car?
Old 06-13-2009, 07:44 AM   #3 (permalink)
Form and Function
Hi Michael, thanks for the reply....
There has been a lot of work done on the car...turn signal delete with rewiring of DRL's....LED light upgrades with rewiring...
My car is at the body shop, so I can't check fuses just yet, but I'll do so as soon as I get it back - are those fuses in the front (under right access panel?) or in the rear?
www.FaceNBody.com
Old 06-13-2009, 09:29 AM   #4 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Fuses starting with F = Front, C = Cockpit, R = Rear (engine bay)
You are going to have to do some trouble shooting, with a meter, eyes and being able to read the wiring diagrams. If I can be of any help, don't hesitate.
Check those fuses first.
Old 06-13-2009, 10:20 AM   #5 (permalink)
eH?
cd4age's Avatar
U didn't by anychance pull ur center console out for the trackday or anything did u? If u pull out the hazard lights switch it creates a break in the circuit so the turn signals won't work. Just a shot in the dark
cd4age is offline   Reply With Quote
Old 06-26-2009, 08:54 AM   #6 (permalink)
This just happened to me as well!! What was the cause?
Just did 6/19 at Thunderhill, noticed on the way home, turn signals not working! I checked my fuses last night, all look fine...the center console idea was interesting since I had a terrible time shifting into 3rd on hard acceleration..maybe the wiring harness was in the way and got mangled/pulled off. Before I pull the center console it'd be nice to see what your fix was...thanks
Dave,
2006 Exige
QuickTurn is offline   Reply With Quote
Old 07-09-2009, 11:52 PM   #7 (permalink)
Form and Function
My car is being worked on now, and part of the failure was due to a crappy battery...(there were also some blown fuses - long story).
Now the issue is that alarm/immobilizer has reset and I don't have the PIN # to reset....anybody know how to reset the alarm without the PIN?
www.FaceNBody.com
Old 07-10-2009, 01:17 AM   #8 (permalink)
right seat driver
Brent Bauman's Avatar
handled
Brent Bauman is offline   Reply With Quote
Old 07-10-2009, 05:31 AM   #9 (permalink)
Alarmed & Dangerous
TheViper's Avatar
At this time, either the remote or PIN is needed to disarm the alarm /immobilizer. The PIN can be obtained though a dealer.
Coming soon, I am developing a simple system that will enable arming / disarming of the alarm / immobilizer and unlocking of the doors through an alternative method.
Cheers,
