insert clever title here
Valentine1 mounting bracket
Well, I don't typically like talking about my designs before an actual prototype is built, but I already let the cat out of the bag on this one so what the heck. Enough people know I've been working on this, and the protos are due later this week, so here goes. Below is a computer generated image of a V1 detector mount I've come up with for the Elise. It mounts where the interior light is, without any drilling or other permanent modifications required. The original light then snaps into the front of the detector mount as you can see in the image. The material is black anodized aluminum, laser cut and precision formed. The Valentine itself is held in a 'theft resistant' manner, though I may change that depending on how the prototype works out.
I'll be at WCLM if anyone wants to get a closer look at it then, or catch me at this Saturday's autocross in Marina (CA). All that business-like stuff (pricing, etc) is not worked out yet (forgive me, I'm an engineer first and foremost). Comments are always welcome! Oh, and to answer the first question on everyone's minds - the unit weighs approximately .22 pounds (excluding V1 and light) if Solidworks is to be believed, I'll verify that myself when I get the proto.
'05 Elise, Magnetic Blue / Biscuit / Hardtop Radar detector mounting brackets for sale here |
That looks great! My concern would be that the unit might need to be a bit higher to "clear" the rear clam view. Thoughts???
What is on the front of the case?
'06 Krypton Green Elise (touring/LSD/HT) '05 Magnetic Blue Elise (sport/HT) dedicated track car '07 Jeep Wrangler Unlimited (4 door!) Excelsior-Henderson Super X/Ducati Monster 620 ie 3 Series BMW/Acura MDX Carver Yacht |
#3 (permalink) | ||
Ah ha! I just put my V1 in , so I am not as well versed in the debate of placement as others are. I must say, that is very well done!
Yeah, I'd like an option for 1/2" higher placement. I'm a Pro/E guy,.... but this is such a needed product that I'll accept your Solidworks model
If you need help with pricing/selling/distribution let me know. I've done similar stuff in this field. cheers,-Christopher |
short angry bloke
Looking forward to the prototype. I'd prefer to lose the box and moving the light that far forward, but it's a pleasant solution regardless. Not that you're looking for feedback, but... Will it clear a harness bar? Which ones? I'd advise against colored anodizing, especially black. Colored anodizing has a hard life in sunlight - I've had black pieces that have faded in under a year and it really ruins the cosmetics.
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
#7 (permalink) | |
Codymac, moving the light forward was necessary for the way this is mounted (that'll become clear once I post pics showing the innards). I could move it back an inch or so, do you think that'd be better? It'd probably have to move down a little bit at the same time for structure though. I'm not sure about harness bars, I'll look into it. Thanks for the anodizing tip too!
#9 (permalink) |
Shaken AND Stirred
FYI on light fastness of anodizing dyes:
Light fastness is determined by 2 factors. The first is a properly done sealing step. The second is the light fastness of the dye itself. All dyes have a light-fastness rating to help the specifier select the correct dye for a given application. For example, a part that is used in the dark doesn't need light fastness. There are a whole host of blacks made by Sandoz, for example, the largest producer of such dyes, that have slightly different trace hues that can be seen by people with acute color vision (such as my wife) but not me. They also have a large range of light-fastness ratings. I have manufactured literally millions of parts designed to be used outdoors with very little problem. The tricks are to carefully select the dye that you want (many anodizers only use one stock black dye that is usually chosen for color qualities, not light fastness) good sealing, and careful instruction to the vendor to inform him of your requirements. Don't forget that there are quality vendors as well as the budget variety.
I never dreamed any mere physical experience could be so stimulating! Rose Sayer From "The African Queen" |
#10 (permalink) | |
short angry bloke
#13 (permalink) |
G-200 Driver
Looks clean !! If there would be no interference with the rear clam in detecting lazer, I'd be interested. Any idea of $$ ??
74 Europa Zetec TC Special 3614R Elise #2292 / CO/Starshield/Nitron Sport SA/RTDbrace/Uprights machined/Down Low rails/ChaseCam w/DM10/V1/SS lines w/Pagid Black/G-Pan/Rota-Hoosier R6 "My daily driver does .85 Mach" " I started flying when Sex was safe and Hang Gliding was dangerous " ![]() BUY My Europa ! http://www.lotustalk.com/forums/f94/...pa-sale-43829/ |
#15 (permalink) |
Prez: The K.G.B.
That positioning is very close to how I have mine. I put velcro on the bottom of the V1 unit and a small strip of it on the black plastic above the stock interior light. The back of the V1 attaches here and the front of the V1 rests on my harness bar. I built a little black cardboard cover for it so that wandering eyes won't be able to tell what it is. I then use the remote unit mounted on the dash to see the readout. It works great and I can easily move the V1 to my wife's car because its only held on with velcro.
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - Sector111 motorsport engine mounts - stripes - harnesses - Pagid pads - Green air filter 2002 Jaguar XKR convertible 2000 BMW 528i President - Lotus Limited Southeast http://autos.groups.yahoo.com/group/LLSE/ |
#16 (permalink) | ||
#17 (permalink) |
You can call up Mike at Valentine and he should be able to help you. I think the case is only thicker but I don't know if it uses a different bracket? The new case thins down from the display area. The old one was the thickness of the display area.
As for anodizing, there are 2 prefinishes you can consider. One is used the brushed aluminum of the plate and anodize directly. This give a nice almost shiny finish. I prefer this, but there is an advantage of the second choice. You might also consider getting the item bead blasted with silicon carbide. We do this before anodizing on parts that go into the cockpit of race cars. It provides a very flat finish so that sunlight can't reflect off it. --christopher |
#18 (permalink) |
I have both dimensions from when I was designing a similar case (I decided to work on other things instead). The entire case is slimmer now from the old V1. That changes the point where you are grabbing it. The footprint did not change. In my design, I had the two sides movable so they could clamp down on either one.
Mine is the older one and I will have it mounted to the harness bar at WCLM. |
#19 (permalink) | |
Keep in mind that any laser source must be stationary, and thus if it's behind you, you just drove past it and hopefully saw it already. The cost will not be competitive with the DIY solutions out there, this is designed for someone who wants an OEM-type solution, one that doesn't require adding any holes to the car or applying adhesive backed velcro that may be difficult to remove later. It'll easily cost less than $100, but the final pricing can't be worked out until I review the proto and see if any more significant changes are needed.
#20 (permalink) |
BANNED
Slightly higher to help out rear laser (since it is one of the attributes of the V1 in the first place), and a box to hide that it's a V1 sitting there for those times it's parked with the top off, or worse the top on and captain sticky fingers is sporting a knife- and I'm in.
| Thread Tools | |
| Display Modes | |
