Yahoo! Got my Rotus!
Weird electrical issue, anyone have any ideas?
Hey guys
Late last week, I found my battery dead when I came out to the car at the end of the day. I suspected my own stupidity, coupled with the fact that the car is a garage queen and can sit for a week+ in between drives. I called AAA and they tried to jump with a portable battery box, which would not start the car. They jumped it and it started, I drove home. I noticed my dash lights weren't on, but all indicators work. I tried the dimmer adjust and it would not brighten them. I then noticed that the second light switch in the control stack seemed to do nothing. I now know I have no tail lights either. I checked all of the fuses in the cabin and adjacent to the brain, all look fine. Does anyone know what could be the issue? This is a bummer as HRM has closed, I don't have any local support. The car is now sitting disconnected from the battery as I read an electrical reset can help this. Anyone have any ideas or troubleshooting steps? Battery is fine, car runs. Thanks
David Avery 05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE 08 BMW 135i being painted in the mother country 04 Mini Cooper S JCW ~ 210hp JCW bump up kit 07 Husqvarna TE-250 visit FocusedE, my e-business company | visit Spyderclub |
El Jefe - Agent 111
How do you know the battery is fine?
* V E R I T A S * A E Q U I T A S * We have been feeling the buzz since 2002 2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds. ..is a stranger in an open car. Tempt you in and drive you far away |
Thanks Randy
It starts the car, Headlights, stereo, signal lights, etc. No tail lights, no front marker lights. I would think +12V enough to start would be enough to power some misc. electricals. I used to be able to turn on the parking lights, the switch does not do that anymore ![]()
Ex-Brit
Did you check the fuses under the front access panel, specifically fuse F16?
A/C Improvement Modifications http://www.lotustalk.com/forums/f3/e...ent-mod-59938/ 1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat. 2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up. 3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose. Last edited by TheViper : 09-06-2008 at 04:04 PM. |
El Jefe - Agent 111
Good catch. In the cabin and adjacent to the brain is not the main fuses you need to check.
#7 (permalink) |
Ex-Brit
Check fuse F16
A/C Improvement Modifications http://www.lotustalk.com/forums/f3/e...ent-mod-59938/ 1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat. 2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up. 3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose. |
#8 (permalink) |
It was the first 20A fuse under the front access panel. Very odd, thanks all. So now, only time will determine if the fuse blew from the jump start or if the fuse blew causing me to NEED the jump start!
#9 (permalink) |
This may be a dumb question, but I went on the Sunday drive this weekend. While coming home my radio started acting weird. Lights on but no sound. Then my turn signals stopped working. A few miles later a CEL lit up. Is this all coincidental or are these all related. Checking the fuses today, but can a blown fuse give you a CEL?
Jacob Join Lotuscar.ning.com for LA Lotus social events 05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels |
#10 (permalink) |
Ex-Brit
Interesting, because that #1, 20A fuse is only for the power outlet
#11 (permalink) | |
No Acceptable Substitutes
There is a CEL for low system voltage: P0562, so that might be the code you're throwing... do you have a voltmeter handy to check your system voltage (both with the engine on and off)?
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam |
#12 (permalink) |
disproving HD MTBF daily
yeah a blown fuse can give you a MIL, i forget which fuse it is off hand but one of the ones in the two engine bay packs will cause some problems with the lift and subsesquently set codes, it might be ecu b+ but that usually limits the rpm too.
dma, was the portable battery box the cigarette lighter type ?
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it. |
#13 (permalink) | ||
#14 (permalink) | |
#15 (permalink) | |
That's two symptoms that indicate low system voltage, at least at the instrument cluster. It's possible you have a loose connection somewhere that's causing the voltage downstream of the alternator to be too low. EDIT: Do the turn signals come on, but not blink? EDIT 2: On reviewing the schematic, the hazard/flasher unit does not look to be load sensitive... but might be voltage sensitive anyway...
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam Last edited by apk919 : 09-09-2008 at 01:56 PM. |
#16 (permalink) | |
#17 (permalink) | |
EDIT: Power gets to the flasher module differently under those two circumstances, so that might be a good debugging step... I'm assuming that your doors lock and unlock properly and the interior light comes on when you open the door?
#18 (permalink) | |
#19 (permalink) |
Ex-Brit
I am betting you have a high resistance connection somewhere. Check all connections at the battery.
#20 (permalink) |
OK...
Signals - nothing Hazard - one blink when I press the button then nothing Locks - work, both from the fob and the button on center console. Inside cabin light - working Checked the battery cable and it seems tight. Could it be the cable themselves? I have had the battery die for no reason twice. And there is a current draw that I've never figured out, but as I said before I don't know why the alternator doesn't seem to recharge the battery well. ![]()
