Old 10-01-2009, 03:07 AM   #1 (permalink)
fred2602's Avatar
Wiring under the front wings?
Hello,
I need your help to identify the following wiring under the front wings:
Is it a kind of sensor for the airbag/crash warning? My Exige S is from 2007.
Thanks in advance,
Fred.
fred2602 is offline   Reply With Quote
Old 10-01-2009, 03:21 AM   #2 (permalink)
NOT ßANNED!
Demonized's Avatar
Originally Posted by fred2602 View Post
My Exige S is from 2007, so I don't believe I have an airbag in the steering wheel.
If you're in the U.S. It would have had an airbag when the car got sold here.
Old 10-01-2009, 03:33 AM   #3 (permalink)
fred2602's Avatar
Thanks, my mistake if I talked about airbag (I am located in Europe), I would like to keep the focus on the wiring if you are ok. Lotus prepare the cars in a way that even if you don't have the options, you have the wiring
Old 10-01-2009, 03:47 AM   #4 (permalink)
Lotus Service
twaszak1's Avatar
that is the radio antenna. It connects by the fuse box under the right side access panel, runs up the center of the clam, and the splits off into 2 wires one going to the right fender well, and one going to the left.
T.J.
twaszak1 is offline   Reply With Quote
Old 10-01-2009, 05:59 AM   #5 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
I second Twaszak1's comment - Antenna wire!
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 10-01-2009, 06:23 AM   #6 (permalink)
fred2602's Avatar
T.J.
You are the best! Thanks a lot.
