Adding 12v lighter outlet
Having issues resizing my images...sorry
Special thanks to tesprit & TheViper. tesprit provided the instructions & filler plate. Filler plate was originally made by TheViper. Viper has a thread on this somewhere, but I've just included more pictures What you need from radio shack: 12v cigarette kit, fuse taps, female connectors Step 1: Remove start button panel (2 screws) ![]() ![]() Step 2: Remove plastic divider & route wires through hole leading into floor board (shine light up from floorboard to see hole) ![]() ![]() Step 3: Route wires underneath dash towards passenger side fuse panel. I used one of the screws next to the OBDII connector as my ground. ![]() Step 4: Remove fuse, install fuse tap, and put fuse back in. Note: I used the stereo fuse. I used pliers to mash the fuse tap onto fuse, & then carefully forced it back into the fuse panel. ![]() Step 5: Install female connector on positive wire of 12v cigarette kit, then slide connector over fuse tap. It should fit snug. If the connector is loose, then get a smaller size. ![]() Step 6: Replace plastic divider, start button panel, & install 12v cigarette piece. ![]() Step 7: Used 3m tape to secure plastic cigarette adapter "filler plate". Done. ![]() Special thanks to tesprit for providing me with the "filler plate" & installation instructions. Filler plate was originally made by TheViper for tesprit Last edited by txdude : 10-03-2009 at 09:35 PM. |
How is the socket quality?
I have trouble finding good ones. Marinco is the only good one I've seen.
"Everything is more wonderful when you do it with a car, don't you think?" -girl by the fire, while watching a huge tree rearranged in the bonfire by car bumper and cable Stop that! You're in direct violation of the laws of physics! |
Mods are good for you
I added one just below the starter button and tapped the DRL wire which is right behind the stock panel...works great. The outlet from Rat Shack comes with it's own in-line fuse holder, their p/n: 270-1556
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
Alarmed & Dangerous
Here is my original thread Front 12v power outlet. My only comment is that I found it unnecessarily to remove the divider as I recollect there was a small opening at the base of it. Thanks for the reference
.Cheers, Michael
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 10-04-2009 at 06:18 AM. |
#6 (permalink) | |
Lancia--the Radio Shack socket is a nice item and of good quality at a reasonable price. TheViper--Nice job of making those filler panels! |
#7 (permalink) |
Lotus Service
![]() Join Date: Oct 2006
I like to hide the additional outlets, so I use the curved plastic panel under the A/C controls, the one the surrond actually attaches to. The only issue is if you have some crazy big plug. I have found that the Valentine plug will fit and its pretty big.
T.J. |
