Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 05-30-2009, 11:07 PM   #1 (permalink)
AMP install
so i am installing a 5 ch amp behind the seats
i need help running all my wires from front to back
i have 3 RCA, remote wire from radio to amp
and i have 4 speaker wires to run from the amp to the mid and tweet in the dash
the center consoul is tight to get all those cables though is there another path or way???
569dean is offline   Reply With Quote
Old 05-31-2009, 12:10 AM   #2 (permalink)
A pound at a time.
Do you have the dash out?
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser
Sh4rkattk is offline   Reply With Quote
Old 05-31-2009, 08:15 AM   #3 (permalink)
i will i need to pull it to get the wires to the speakers
Old 06-03-2009, 09:03 PM   #4 (permalink)
A pound at a time.
If you have have the dash out, its do able but takes some time. What I did was all the wires going from front to back, starting at the HU go under the airbag to the pass side cubby hold and route to the fuse panel behind the tray, go along the back wall. Remove the alum piece with the holes in it and the center console, also helps with the seats out. Run the wire along the main harness under the alum piece and center console.
I hope you can understand what I'm on about.
Ill try to take some pics of what I'm talking about, but its doable.
FYI I have a alpine 9887. Boston acoustics component 5.25" in the front and 6" coax in the rear. Behind the driver seat is a PDX-4.100. Almani self-powered sub.
Old 06-03-2009, 09:13 PM   #5 (permalink)
There is room in the center tunnel and you do not need to remove the dash. That is the route I went.
Routed through the center tunnel, up and under the dash, then behind the left and right cubby holes to the front speakers. RCA cables and all.
Brennon is offline   Reply With Quote
Old 06-04-2009, 07:58 AM   #6 (permalink)
insert clever title here
MattG's Avatar
Images: 11
If you have the touring pack option, you can also hide wires behind the small strips of carpet on the sides of the frame. I had read that it's best to route RCA cables separate from power cables to minimize electrical interference, so I routed the RCA cables behind the carpet, very easy to do and not noticeable.
MattG is online now   Reply With Quote
