Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 03-24-2009, 07:41 AM   #1 (permalink)
the designer
spectre's Avatar
Chasecam setup question.
Ok, I got it all setup for the most part. It is pretty easy to do. One item for s240 people is to not get the EZ20 as its way to big. I ended up going to the hardware store and getting a smaller clamp. I think it was 25mm - 50mm but will double check that. Also, fine tuning the camera angle orientation is a bit of a tweaky process...no big deal though. One thing I wish it came with is a firewire port or more recent output plugs.
Anyway to the question.
I am using the gforce and want to know if there is a setting to automatically arm the gforce or do I have to hit the record button to always to arm it. I would think it would have a setting for auto arm so you can hide the unit or do I just need a remote to engage that function?
2008 Exige S 240
For Sale: 2005 stock shifter console and change holder. PM if your interested.
spectre is offline   Reply With Quote
Old 03-24-2009, 07:43 AM   #2 (permalink)
G-200 Driver
kestrel74's Avatar
I'm betting Randy ( MIGHT ) know !!
Old 03-24-2009, 07:45 AM   #3 (permalink)
the designer
spectre's Avatar
I used this thread New Auto-Record Feature - ChaseCam -video at speed
but for some reason it does not come on unless I push the button. One thing in the thread at the bottom is about the supercaps menu and auto shutoff but not sure why that would not initiate the recored though. I may just need to re-step through the instructions.
2008 Exige S 240
Old 03-24-2009, 08:20 AM   #4 (permalink)
registered nipple
fishguy's Avatar
Images: 1
my traqmate system turns on my chasecam automatically.
very slick set-up, having the chasecam/traqmate with traqsynch for the video.
2008-2009 SCCA AZ Regional "Driver of the Year"
1986 Swift DB-1 Sold
2008 HSR-West FF 3rd generation Champion
2008 "The Series" FF 3rd generation Champion
1987 Porsche Spec 944
2008-2009 season SCCA AZ regional Champion
Old 03-24-2009, 08:37 AM   #5 (permalink)
Randy Chase's Avatar
Images: 761
First, we make an EZ-10 that is perfect for you. We can swap.
USB is coming. Someday.
Apologies for the menus becoming quite involved. We keep adding features and it is a little confusing.
To have the unit auto-on, open the battery-card door and look for a little red slide switch. Make sure the white tab is pushed to the outside of the unit (away from the door). If so, the unit will power up automatically when sensing external power.
To have the unit auto-record, go into the MENU and select FEATURES
Toggle down to AUTO RECORD AT START and use the select button.
Toggle down to BEGIN AUTO RECORD AT START. Hit select button.
Press X back to FEATURES menu
Select GFORCE RECORD TRIGGER
Press select to toggle mode until top text says DIFFERENCES MODE IS ON
Change SENSITIVITY to 0.25G and hit select to save
Modify TIME DELAY AFTER from default 60 seconds if you want.
X back out of menu.
Power off and reboot.
Now the unit will power up automatically and record video every time the car moves.
http://www.facebook.com/randychase
1991 Toyota MR2. AutoX Beast
2006 Noble M400. Track weapon.
2009 Rossion Q1. Monaco Orange. Canyon Carver.
Lexus GX-470 tow vehicle. On Order: Lotus Evora Next: McLaren MP4-12C
Old 03-24-2009, 08:57 AM   #6 (permalink)
the designer
spectre's Avatar
Cool, I will go through and double check my settings and refer to the above.
One thing as feedback, I was hitting the buttons I thought were correct but it seems some buttons are opposite while some are exact. I didn't have it hooked up to my laptop as the output cables are dated compared to my laptop inputs so I went inside to view on tv. Apparently, I was selecting clear background and it would give me black background or bottom and it would be on top. If I were to do it again I would just do the core setup items out of the car then go back to the car for the gforce orientation setup. Or you can just write it up as a newbie learning it But as you mentioned USB would change that for alot of users.
2008 Exige S 240
Old 03-24-2009, 09:03 AM   #7 (permalink)
Images: 761
Yep. It became apparent that when you add enough features and options, there is no easy way to offer the selections. So the plan is to offer configuration files and a USB interface so you can do all the settings on your laptop and then save it. And offer standard configurations so you can use them instead of toggling all the different stuff.
One problem is we added these features over the years so our interface was not consistent. We intend on fixing this.
Old 03-24-2009, 05:40 PM   #8 (permalink)
the designer
spectre's Avatar
Ok that worked perfect! User error
It was the begin at auto record at start that I thought was selected but it was not.
2008 Exige S 240
Old 03-24-2009, 05:55 PM   #9 (permalink)
jmiesse's Avatar
On a side note ... I just got home and noticed a package on the counter from chase cam... I am not sure my girlfriend knows thats where the package was from ...it was addressed to her...hmmmmm
I think its supposed to be a surprise
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II
Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror
jmiesse is offline   Reply With Quote
Old 03-24-2009, 06:13 PM   #10 (permalink)
the designer
spectre's Avatar
Nice
What could it be....
I can't wait for April 5 and 6th to really test this bad boy out at mid ohio. I took a few small drives in setup to make sure all works as it should and does which is great. The audio was a lot better than I had anticipated especially with that exhaust. When I get a card reader I will post something.
2008 Exige S 240
Old 03-24-2009, 06:21 PM   #11 (permalink)
jmiesse's Avatar
Well I just opened my package.. although not quite as elaborate as yours I now have an SM 30 Camera Mount!!!!.... Too bad its dark out. I will test mine out tomorrow. She's awesome. See you at MID OHIO!!
Old 03-24-2009, 07:25 PM   #12 (permalink)
the designer
spectre's Avatar
She is awesome to support the habit...I mean hobby
2008 Exige S 240
Old 03-24-2009, 08:22 PM   #13 (permalink)
Form and Function
plastique999's Avatar
you mean addiction...
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 03-24-2009, 08:36 PM   #14 (permalink)
the designer
spectre's Avatar
So right!
2008 Exige S 240
Old 04-04-2009, 03:54 PM   #15 (permalink)
the designer
spectre's Avatar
Had my first track day of the year at mid ohio and just got home to watch the video and apparently I still don't have the PDR setup right. I have 1 min. - 1:30 min. movies. So I didn't get video of full sessions. Also, I have it set to auto come on and it seems like it is randomly recording footage so I must have something else not setup right. So I don't know if its a memory allotment per file and my gforce is not right...I have the settings to what Randy has above but if anyone has any suggestions that would be great as sunday I have day 2 and would like to get all the sessions.
2008 Exige S 240
Old 04-04-2009, 04:06 PM   #16 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
1) Make sure that you've calibrated the g-sensors properly
2) Make sure that the g threshold for recording is set low enough... I think by default it's actually very high (2Gs)
Old 04-04-2009, 04:11 PM   #17 (permalink)
Images: 761
Make sure you dont have LOOPING or RECYCLE recording on.
Call me when you have the unit in front of you.... we can walk through the menus. The downside of so many features we have added is that there are many ways to mess things up.
Randy
Old 04-06-2009, 03:12 PM   #18 (permalink)
the designer
spectre's Avatar
Well, I think I maybe tracking this issue down...on sunday after session 2. I went to see how many videos have recored. I saw 5 videos (really should have only been 2 or 4 as it may time out prior to getting on the track) than the whole unit lost power. So we checked the outlet and it was working fine. So we popped the fuse from the PDR cord plug and sure enough fuse was shot. So Im not sure if the fuse was having issues or if I was getting spikes in voltage. When I got home last night I used a meter and it seemed to be consistent. So Im thinking just a faulty fuse...I hope it doesn't do it again as it kinda defeats the purpose and I really was hoping to not hardwire it...
2008 Exige S 240
Old 04-06-2009, 04:05 PM   #19 (permalink)
2009 XP National Champion
fzust's Avatar
How do you get the traq mate interfaced to the chasecam? My unit didn't have instructions with it really(Got a really good deal on it). Need that video synced with traqmate etc.
Thanks!
Old 04-06-2009, 04:07 PM   #20 (permalink)
Images: 761
Traq Systems sells a cable for $17 that connects the two.
