Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 10-21-2008, 10:52 AM   #1 (permalink)
Head LOONY
tvacc's Avatar
Looking for a VSS sensor...what cars use our engine?
Hello all..
I want to pick up a VSS sensor to again work on putting cruise in my car over the winter.
What Toyotas or is it Pontiacs? use or used the same engine.
Model and year if you have it....
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus
Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances
tvacc is offline   Reply With Quote
Old 10-21-2008, 12:04 PM   #2 (permalink)
Form and Function
plastique999's Avatar
I am looking for the same....
Help!...Speed sensor for JVC kd nx5000???
I am doing research at junk yards as well...so far....many cars fit the VSS we need...but the closest would be a '93 to '98 Celica....but even Camry's and Tacomas use the same speed sensor
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 10-21-2008, 12:48 PM   #3 (permalink)
Parts scattered about...
MaineLotus's Avatar
Bought mine at the local Toyota dealer, not cheap - $$$. You'll also need to buy the cheapo plastic gear, a seperate part number.
My car is modified.
MaineLotus is offline   Reply With Quote
Old 10-21-2008, 01:54 PM   #4 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Corolla XRS, Matrix XRS, MR-S, and Celica GTS if I'm not mistaken....
Old 10-21-2008, 03:47 PM   #5 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
Originally Posted by tvacc View Post
Pontiacs
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 10-21-2008, 05:42 PM   #6 (permalink)
Head LOONY
tvacc's Avatar
Originally Posted by Monsi View Post
Doesnt the Pontiac Vibe have the same engine...?
Tony Vaccaro
Old 10-21-2008, 06:04 PM   #7 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
I guess it is... but the vibe is just a matrix
Old 10-21-2008, 06:20 PM   #8 (permalink)
Head LOONY
tvacc's Avatar
Is this the unit....guy says it is from the 1994 1995 1996 1997 1998 1999 2000 2001 TOYOTA CAMRY AND TOYOTA AVALON AND LEXUS ES 300 WITH V6 ENGINE WITH AUTOMATIC TRANSMISSIONS
Tony Vaccaro
Old 10-21-2008, 06:55 PM   #9 (permalink)
Head LOONY
tvacc's Avatar
or is this the one...fits...1993 1994 1995 1996 1997 1998 1999 2000 2001 2002 2003 2004 SPEED SENSOR FITS 1993 THRU 2004 TOYOTA COROLLA TOYOTA CELICA AND GEO PRIZM WITH 4 SPEED AUTOMATIC TRANSMISSION WITH OVERDRIVE AND 5 SPEED MANUAL TRANSMISSION
The celica site says the 6 speed and 5 speed are the same...
Tony Vaccaro
Old 10-21-2008, 08:03 PM   #10 (permalink)
Head LOONY
tvacc's Avatar
OK guys...I have a lead on some used sensors.
What I need to know is what is the size of the hole that the o ring shaft fits into...
I have one speed sensor that is like 7/8 and another that is 1 5/16
Does anyone have a real picture of what this thing looks like? I could also tell that way...
above are pictures of what I have a line on...it s tough to get size perspective on these...
Tony Vaccaro
Old 10-21-2008, 08:12 PM   #11 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
t- I'll try to check tonight. I've got the clam up, engine out, and can take some quick measurements for you if that would help...
Best,
Phil
Old 10-21-2008, 09:11 PM   #12 (permalink)
2/3 hp to the paws.
Simba's Avatar
You want the sender for the 7th gen (2000-2005) Celica GT-S. The unit with the shorter shaft is the correct unit.
Old 10-22-2008, 12:09 AM   #13 (permalink)
Rei
Lotus/TRD Geek
Rei's Avatar
^give this man a cookie but you don't have to get one for the gt-s you can get it for the regular celica if I recall. Both trans are c series trans so speedo gear will be the same for both. I would say search ebay for this part. It's has a very low failure rate so why pay new??
Kids in the Back seat causes Accidents
Accidents in the Back Seat causes Kids
Moral Stick with a Two Seater
Rei is offline   Reply With Quote
Old 10-25-2008, 08:03 PM   #14 (permalink)
Head LOONY
tvacc's Avatar
OK...got me a speed sensor...
What is the wiring....I know one goes to power...one to ground and one to cruise device
But which terminal where? They are not lettered or numbered or colored coded.
Tony Vaccaro
Old 10-25-2008, 08:07 PM   #15 (permalink)
Head LOONY
tvacc's Avatar
Sorry.....Just found it on one of Tim's posts..
Touring radio not wired for speed?!
Tony Vaccaro
