Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 10-11-2009, 12:17 PM   #1 (permalink)
Please help on stereo wiring
Hello all. So, I have installed new speakers in the stock locations in my 2007 Elise and have gotten a Stealthbox (not connected yet) and a Alpine pdx-5 amp. I took my car to a pretty popular car install shop in my area to wire everything up and to install the amp behind the drivers seat. However, after many hours they said that they just couldn't figure out how to run the rcas (3 sets) and all of the speaker wires for a nice clean installation.
Can someone please provide me some detailed instructions, or even pictures on where you have ran your wires, how you did it, and how to get the power wire from the battery to inside the car.....I guess I am going to have to tackle this project myself. Thanks in advance for all of the help. Mason
Oh yeah, I have the Alpine deck that came with the car that I am keeping...any ideas on how to pull it out to connect all the wiring so that I dont have to take the whole dash out?
masonsied is offline   Reply With Quote
Old 10-11-2009, 12:36 PM   #2 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Hope this helps: 600W Audio Power Coming To An Exige S Near You
Old 10-11-2009, 12:58 PM   #3 (permalink)
Thanks for the quick reply. That is going to be helpful. Do the seats come out pretty easily and did you have to take the "tunnel" around the shifter out or fish the wires through it? The area behind your rear speakers seems to be more open than mine....I have some kind of vinyl covered foam across the back?? Did you have to remove that? Thanks again. mason
Old 10-11-2009, 01:07 PM   #4 (permalink)
apk919's Avatar
Images: 20
The seats are easy to remove... if you've got the stock hardware I think you need a 6mm hex bit for the rear bolts, a 10-12" socket extension, and a universal or "wobble" adapter. I removed the screws on the center console, but just lifted it up enough to run the wires; I didn't remove it. It's a bit of a tight fit, but you can snake all your wires through the aluminum footwell separator without removing it as well. The rear speakers have some rectangular sound dampening insulation behind them... I cut a hole in the center of them to allow deeper speakers to fit.
Old 10-11-2009, 01:10 PM   #5 (permalink)
Thanks again for all of the info...on final question I forgot - do I need any kind of special tool to get the Alpine deck out of the dash? Thanks. Mason
Old 10-11-2009, 02:32 PM   #6 (permalink)
apk919's Avatar
Images: 20
No, not really. Once you remove the faceplate, you'll see two small screw-like pins on either side of the head unit. Use a punch or a small screwdriver to slide both of them upwards at the same time. That will release the head unit.
Old 10-11-2009, 02:35 PM   #7 (permalink)
Service animal
dbisbee's Avatar
Do it yourself! I ran the rca's down the center gear shift parking brake channel. I put my PDX-5 in the trunk next to the battery.
For the RCA's I used StreetWires ZeroNoiseŽ 7 Series 6-Channel Patch Cables for a clean install under steering wheel under dash to the center. It was a challenge but patience and persistence paid off. For the speaker I also ran Street wires 14 gauge.
Drive on down to Tampa I will help!
The word "PASSION" should aways be uppercase.
#349 '05 AS Elise Touring, Hardtop, Starshield, Plinth delete, GPS Garmin 680, V1, V1 mirror, Leather console, Multivex, Alpine CDA9887, JL stealthbox, Focals, Alpine PDX 5, HID, RAC Monolites, R888's, Stage II, Front Slotted rotors, R4-S pads, Stebel nautilus, TitanQR and Odyssey 925 now with bracket.
dbisbee is offline   Reply With Quote
Old 10-12-2009, 10:44 AM   #8 (permalink)
I'm in the process of doing some modifications to my stereo as well... here's some threads to look at that i've saved.
These are things to do if you have your dash out:
Alarm wire mode for range - Increase the range of your remote
Jim's Speaker mod - FS: Adaptor rings for 5-1/4" front speaker install
CDL relocate and vibration points- Things to do with the dash removed....?
Wiper relay - JnC's Programmable Intermittent Wiper Relay Hack (I've actually got the relays in my mercedes now... love it, straight swap in part).
If you hate the daytime running lights there's a thread for disabling that too when your dash is out. Check out the "UBER-POST" for a link to it. It doesn't bother me.
Here's some other general links.
Wire routing: Wiring Routing Pictures - Cockpit to Trunk
Wire routing: Installing an amp... No head unit can compete!
Removal of dash - My Dash Removal Instructions
2006 Aspen White Elise. Hard top (never left it's shipping box), LSS, LSD, Traction control, Red leather.
ewalberg is offline   Reply With Quote
Old 10-12-2009, 10:55 AM   #9 (permalink)
insert clever title here
MattG's Avatar
Images: 11
I ran the RCAs behind the carpet (the strip that covers the chassis side) on the left of the passenger seat, and all other wires through the center console (amp is behind the passenger seat). Power came from the battery, via the grommet behind the driver's seat.
Old 10-12-2009, 11:20 AM   #10 (permalink)
Put everything under the dash..
I put my alpine pdx.5 and my kenwood dvd headunit brain (along with bluetooth/nav/hdradio/ipod cables etc) under the dash
headunit brain and other units I put behind the guage cluster, and the amp etc I put behind the passenger dash (I removed airbag and hardware since I have 6pt harnesses)
pm me if you want pics or for questions..
gpheck is offline   Reply With Quote
Old 10-12-2009, 12:56 PM   #11 (permalink)
Thanks for all of the tips and information guys. That is going to help out a lot as I start to tackle this project. Just can't wait to hear what it sounds like. Mason
