Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 05-26-2009, 10:55 AM   #1 (permalink)
Will There Be Cake?
ItsThaMonsta's Avatar
Stereo keeps cutting in and out
This has been happening for the last couple of days. Has anyone experienced this. Dying fuse maybe?
ItsThaMonsta is offline   Reply With Quote
Old 05-26-2009, 11:45 AM   #2 (permalink)
smicker's Avatar
Images: 2
Faceplate seated correctly?
2008 Lotus Exige S240
2006 Lotus Elise RIP
smicker is offline   Reply With Quote
Old 05-26-2009, 12:10 PM   #3 (permalink)
Will There Be Cake?
I think so. It opens and closes without a problem.
Old 05-26-2009, 12:11 PM   #4 (permalink)
V Not my picture V
RacyTracy's Avatar
I think a fuse is either good or bad....no in-between.
Tracy
1996 Porsche 993TT Big news coming @ 3pm onTuesday.....(hopefully).
2008 Toyota FJ Cruiser
LOG 29 photos
RacyTracy is online now   Reply With Quote
Old 05-26-2009, 12:12 PM   #5 (permalink)
Bane's Avatar
Images: 4
+1
I vote for an intermittent ground.
$599 PPE header (INFO)
2007 BMW 335i - Mostly stock
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
Old 05-26-2009, 12:13 PM   #6 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Nope, fuses are either good or bad, nothing in between. Does the stereo cut in and out on all sources (i.e. AM/FM/CD/Sat)? It could be a voltage problem, as some head units are sensitive to low voltage.
EDIT: Tracy and Bane beat me.
EDIT2: Aftermarket or OEM stereo? Power amp? Does the display cut out too, or just the sound?
Old 05-26-2009, 12:34 PM   #7 (permalink)
Will There Be Cake?
All stock from 07. The display and audio both cut out simultaneously. Power goes completely out. It sometimes will do it about 4 times within a minute. It will cut out, then the HU will load back up as if I was just turning the car back on.
Old 05-26-2009, 12:49 PM   #8 (permalink)
apk919's Avatar
Images: 20
OK, next question: does it happen while the engine is running, off, or both?
Old 05-26-2009, 01:07 PM   #9 (permalink)
Will There Be Cake?
Definitely while its running. Ill test to see if it does it while its off.
Old 05-26-2009, 01:33 PM   #10 (permalink)
apk919's Avatar
Images: 20
Well, at this point I'd say the two most likely causes are either a loose wire/connector, or a malfunctioning head unit.
Old 05-26-2009, 01:40 PM   #11 (permalink)
Does the same thing occur regardless of the volume setting? I had something similar happen as a result of a pinched wire to one of the speakers, however, it would only occur when the volume setting was past about 30%.
Brennon is offline   Reply With Quote
Old 05-26-2009, 02:00 PM   #12 (permalink)
20 min into the future
I have a problem with my stereo as well. Whenever I'm listening to AM radio and step on the brake, only static comes out of the speakers. As soon as I release the brake, everything returns to normal. I'm assuming its a bad ground, or somehing similar. I don't listen to AM enough to be a problem but was definitely planning to have it looked at the next time I bring the car in for service.
blankdan is offline   Reply With Quote
Old 05-26-2009, 02:23 PM   #13 (permalink)
Will There Be Cake?
yeah it does it when the engine is off as well. volume isn't a factor.
Old 05-26-2009, 03:20 PM   #14 (permalink)
It's a Lotus
LARRY's Avatar
Stereo? You have stereo?
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats.
LARRY is offline   Reply With Quote
Old 05-26-2009, 07:33 PM   #15 (permalink)
perfututum futūtor
RoadDad's Avatar
Sounds like you have HID brake lights
Loose wire/harness/ground/etc.
Me... I don't need to.
Bite me." -Randy
Old 05-26-2009, 07:54 PM   #16 (permalink)
Mors ab alto
dfa2100's Avatar
The AM radio bit is a known problem, if you take it in to your dealer they should know how to fix it. Improper shielding of some wires or something, but there was a bulletin about it and it took them like 15 minutes to fix mine. No big deal. That being said, I don't know what they did, so if you're out of warranty I am not much help.
Nightfall Blue, Biscuit Interior, Hardtop
Oh, I have slipped the surly bonds of earth
And danced the skies on laughter-silvered wings...
dfa2100 is offline   Reply With Quote
Old 05-26-2009, 09:57 PM   #17 (permalink)
Thanks. It's still under warranty and it's good to hear that it's a simple fix. I'll probably have it looked at next time I bring it in. Fortunately the only time I listen to AM is when I'm stuck in traffic and trying to find a traffic report.
Old 05-28-2009, 06:48 AM   #18 (permalink)
Will There Be Cake?
Is there any way that I can find out if its a bad wire or if its the HU completely? I don't want to go to Tampa just to find out that they have to order a new HU.
Old 05-28-2009, 07:06 AM   #19 (permalink)
Race lines on the mind
Tracktimeplz's Avatar
Im not trying to be a dick, but you seem to have a new problem every day lol
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline   Reply With Quote
Old 05-28-2009, 07:19 AM   #20 (permalink)
apk919's Avatar
Images: 20
Which HU is it? The Alpines are fairly easy to remove; you take off the faceplate, use a small screwdriver to release the locking pins on each side of the HU, then slide it out. When it's out, you can check the wiring connector, and even replace the faceplate and turn it on... jiggle the wiring and see if it cuts out.
If the HU cuts out when the engine is off and the car is sitting perfectly still, I'd lean toward it being the HU though...
