Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 09-08-2009, 07:02 PM   #1 (permalink)
Well, my system is done
all FOCAL
Utopia Be Kit N°5 up front with the crossblock
and Utopia Be 21 WX in a JL Audi Stealth box
and for power I have installed a FOCAL FP 5.500 LE
the front end has been bi-amped
all controled by a ECLIPSE CD7200 mkII
here are some pics
these are custom mounts
some install pics
569dean is offline   Reply With Quote
Old 09-08-2009, 07:19 PM   #2 (permalink)
Wow, those front speaker "grills" look very distracting. Bet it sounds nice though.
'05 Elise, Nightfall/Touring (1TON 1G)
'94 BMW 325iS
'67 Austin Healey 3000
Spudboy is offline   Reply With Quote
Old 09-08-2009, 07:32 PM   #3 (permalink)
The Azteks are coming!
the1sen's Avatar
damn man, where do you work?
That's one of the nicest setups I've seen in this car.
The difference between ordinary and extraordinary is that little extra.
F The System - ChuforiaGraffix.com SweetDaddyDelicious(at)hotmail(dot)com
the1sen is offline   Reply With Quote
Old 09-08-2009, 08:36 PM   #4 (permalink)
Yahoo! Got my Rotus!
dma550's Avatar
nice... are you worrying about the sun cooking your woofers?
I just googled those, are they really 4000 for the set?
Focal Utopia Be No. 5 5-1/4" component speaker system at Crutchfield.com
David Avery
05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE
08 BMW 135i Stock
visit Spyderclub.com
dma550 is offline   Reply With Quote
Old 09-08-2009, 10:03 PM   #5 (permalink)
sleepe's Avatar
never understood why people but an Elise and try to make it into a GT
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 09-08-2009, 11:26 PM   #6 (permalink)
check out the sub
the car sounds crazy
Old 09-08-2009, 11:37 PM   #7 (permalink)
cory1000's Avatar
+1
cory1000 is offline   Reply With Quote
Old 09-08-2009, 11:43 PM   #8 (permalink)
JWA
#33
JWA's Avatar
FWIW, the plastic/foam dash doesn't block the satellite signal, so you will get just as good reception if you place the antenna underneath the dash.
JWA is offline   Reply With Quote
Old 09-09-2009, 12:40 AM   #9 (permalink)
NOT ßANNED!
Demonized's Avatar
Originally Posted by cory1000 View Post
+1
+1
Bet it sounds good though...
Old 09-09-2009, 03:09 AM   #10 (permalink)
Denuo Volatilis
...m...'s Avatar
never understood why people buy an Elise and try to make it into a GT
...name another elemental car in current production...
Old 09-09-2009, 08:35 AM   #11 (permalink)
Very nice. Got any photos of the mount that you attached to the chassis?
Also, ditch the stock mirror, you won't believe how much safer the car is without it.
ken
All torque, no traction...Exige S.
Real sports cars don't have A/C!
Ken Wright is offline   Reply With Quote
Old 09-09-2009, 09:51 AM   #12 (permalink)
dma550's Avatar
Dean, did you baffle the front speakers? IMO the placement is the weak link. They are using a very cluttered inner dash as a speaker baffle, hardly a finite enclosure.
David Avery
08 BMW 135i Stock
Old 09-09-2009, 12:44 PM   #13 (permalink)
the front were taken care of with this
and a small peace of this
then sealed with this
we made a pocket with the stuff and placed on the bottom a small peace of Blackhole 5
them sealed with Blackhole SEAL
so the front end is mint
Old 09-09-2009, 01:05 PM   #14 (permalink)
Scott's Avatar
Wow... I like it. I would be one of those that has an Elise but also wants really good sound. It's that simple. Soooo... if that is difficult to understand perhaps something else is amiss.
05 Saffrron Yellow, Sport, Touring, Star Shield, Larini w/ sport cat, Katana Supercharged, SSR Comps with RE01R's.
Scott is offline   Reply With Quote
Old 09-09-2009, 01:07 PM   #15 (permalink)
for pics for the amp rack i dont realy have any
this is half of it
so these 2 stubs are welded to a plate that is then mounted to the floor with4 x 1/2 inch toggle bolts solid as hell then the rack slips over top of them to give a clean install
the rack is supported with two 2 1/2" tubes
the top of the tubes are bent at a 45 and cut to a 90 then welded to a 1/8" plate that has been mounted to the amp
you cant even shake the mount its so solid
the mount weighs in at 6 3/4 lb so its not too bad
Old 09-09-2009, 01:28 PM   #16 (permalink)
Resident Drunk
zygotesoup's Avatar
+1
looks like a nice install but the first thing i would do with that system is remove it
2005 BADA55 Lotus Elise
1993 Black BMW 325i
2000 Solar Yellow MR-S - SOLD
1987 White on White Porsche 944 Turbo - SOLD
1993 Maroon Lexus SC400 - SOLD
zygotesoup is offline   Reply With Quote
Old 09-09-2009, 01:30 PM   #17 (permalink)
dma550's Avatar
Cool...I need to do that. I just have some high end Diamond audio coaxes, but wow is the mid muddy, I was too lazy to baffle. If you have any extra baffle material stuff let me know
David Avery
08 BMW 135i Stock
Old 09-09-2009, 03:10 PM   #18 (permalink)
Exige S240
BadtZ's Avatar
+1
+2
Larini 6" Sport, DBW Pedals...and minor stuff
So far so good
BadtZ is offline   Reply With Quote
Old 09-09-2009, 08:19 PM   #19 (permalink)
Is the extra +/- 10 lbs of stereo stuff really noticeable? If I recall I have read a few posts that some of these cars need to be kept above half tank of gas when out on the track to eliminate fuel starvation. Seems like keeping a extra 5 gallons of fuel at what 8-10lbs per gallon weigh quite a bit more then a small amp.
I would guess that unless the car is always on a racetrack (thus a very exerienced driver) the extra 10ish lbs of stuff will not take away from daily enjoyment of the car. Probably make it better actually
Exige S summer 2010.... hopefully
Viggen is offline   Reply With Quote
Old 09-09-2009, 08:39 PM   #20 (permalink)
Bane's Avatar
Images: 4
Wow, major kudos on putting together a fine high-end system.
The weight penalty is only one reason why people are saying "+1, +2, etc". The Elise is so noisy and has such bad acoustics to begin with it seems kind of strange to spend a lot of time and effort on the stereo system.
My stock radio was turned off 90% of the time while I was driving... I could barely hear myself think let alone the stereo at any reasonable speed.
$599 PPE header (INFO)
2007 BMW 335i - Mostly stock
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
Bane is online now   Reply With Quote
