Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > Electrical - Audio (and video)
Old 09-09-2009, 10:12 AM   #1 (permalink)
Wiring for Alpine KTP-445
This was touched on in another thread, but I don't think it was ever definitively answered.
I just purchased an Alpine KTP-445 4 channel amp. This amp plugs directly into the alpine wiring harness, and hopefully should be small enough to fit behind the dash. The issue is that it requires 15 amp power lead run to it. If I'm understanding correctly, the stock radio only has 7.5 going to it. One member said that they hooked it up to the wiper motor line which is switched and on a 15 amp fuse. This doesn't seem ideal to me. If you happened to turn on the wiper when you had the tunes cranked I would assume you could very easily blow the fuse.
So my question is, are there any other options?
jgran is offline   Reply With Quote
Old 09-09-2009, 02:01 PM   #2 (permalink)
I'm thinking of using a 12 Volt Relay to switch the power to the amp. Does anyone see any downside in doing it this way?
Old 09-10-2009, 09:36 AM   #3 (permalink)
Ok, so I bought the following:
Parts-Express.com:12 VDC Tyco Relay SPDT 20/30A (Formerly Bosch) | spdt relay spdt sound security relays relay plastic mounting DC boss bosch relay 330-070 automotive relay automotive 12v bosch
Parts-Express.com:12 VDC 5-Pin Relay Socket | 12v 12 volt bosch alarm relay relay socket remote start starter kill
4 Circuit ATO/ATC Fuse Block
Depending on the work schedule, I plan to wire it up in the next week or so. This way I will have switched power for the amp, GPS, and Radar detector. I'll post photos as I go.
Old 10-16-2009, 07:20 AM   #4 (permalink)
noel_audio's Avatar
What would happen if you put inplace of the 7.5amp fuse a 15amp fuse?
noel_audio is offline   Reply With Quote
