Go Back   LotusTalk - The Lotus Cars Community > Community > Roadtrip!
Old 06-18-2008, 05:54 PM   #161 (permalink)
Hilly's Avatar
Originally Posted by Randy Chase View Post
But then how would you lock and unlock the doors if the killswitch was flipped off?
You wouldn't.
In that the switch was installed shortly after I was having dead battery issues (due to fused/melted wiring in the original battery location, since replaced), I can only assume Bill thought this would allow me a way to avoid battery drain or any sort. I'll double check with him this weekend.
Randy Hillebrand
2004 Noble M12 GTO3R
2000 Ford Contour SVT
2003 New Beetle Convertible
Hilly is offline   Reply With Quote
Old 06-18-2008, 06:08 PM   #162 (permalink)
Hello Kitty's Avatar
Where are the pictures of the road trip? Chasecam.com has broken links, and "to be written" everywhere.
Hello Kitty is offline   Reply With Quote
Old 06-18-2008, 06:26 PM   #163 (permalink)
El Jefe - Agent 111
Randy Chase's Avatar
Images: 761
They work for me
ChaseCam Roadtrips -Noble M400
We have been feeling the buzz since 2002
2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds.
..is a stranger in an open car. Tempt you in and drive you far away
Old 06-19-2008, 07:42 AM   #164 (permalink)
J. Caesar
evomind's Avatar
quality work, hilly, but
why relocate the battery when it would be much simpler to just run alternate terminals to a more accessible spot? seems that would be cleaner and easier.
Vati.
C6 ZO6.
THE OBITS, YO!
KEEP CRYIN! WHAA!
REDNECK = PERSON WHO LIVES IN A DUMP BUT DRIVES AN ELISE!
I never played by the rules, and I never really cared
My nasty reputation takes me everywhere
It is admitted by all that he was much addicted to women, as well as very expensive in his intrigues with them, and that he debauched many ladies of the highest quality; among whom were Posthumia, the wife of Servius Sulpicius; and Lollia, the wife of Aulus Gabinius.
evomind is offline   Reply With Quote
Old 06-21-2008, 03:56 PM   #165 (permalink)
El Jefe - Agent 111
Images: 761
Finally put up some sampler video of Tail of the Dragon. Note, I was not trying to push the car too much, I kept asking the Elise guys to set the pace. I wanted to explore the car safely and there was too much traffic to go very fast for very long. We all did small spurts and got caught behind traffic. You can hear/see in the video that it was quite easy to break the tires loose and create oversteer. I was learning to modulate the throttle on corner exit.
Old 06-21-2008, 05:07 PM   #166 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
Wow, your car pulls hard when you accelerate in 1st or 2nd gears.
You need a louder blow off valve though j/k
'06 Evo IX Stage 1E Tuned by Road Race Engineering: Stock:turbo,intake,internals,ECU,Walbro 255lph fuel pump,RC Engineering1000cc Injectors,Espelir downpipe, RRE High Flow Cat, AVO catback, RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is online now   Reply With Quote
Old 06-21-2008, 05:19 PM   #167 (permalink)
El Jefe - Agent 111
Images: 761
It pulls that hard in higher gears too.... but it scares me more. So I don't press the gas down as much.
Yes, it is LOUD.
500 pounds of torque.
Old 06-22-2008, 03:54 PM   #168 (permalink)
Lotus Driver
solar's Avatar
Wow! It's super easy for you to break those massive A048s loose.
solar is offline   Reply With Quote
Old 06-22-2008, 09:31 PM   #169 (permalink)
Lotus Driver
solar's Avatar
A couple of photos I took...
Flickr
Old 06-22-2008, 09:38 PM   #170 (permalink)
El Jefe - Agent 111
Images: 761
Yep. I had to watch my throttle input. Even with the wider and sticker 315 series Hoosiers, you can break them pretty easy. The tuner Troy said they were breaking the tires loose under full throttle at 125mph.
Old 06-22-2008, 09:58 PM   #171 (permalink)
WTF
climb4fun's Avatar
So, that's telling that Noble is not as balance car as Elise is, right?
climb4fun is offline   Reply With Quote
Old 06-22-2008, 10:14 PM   #172 (permalink)
El Jefe - Agent 111
Images: 761
Not the case. It is all because of 500 pounds of torque compared to less than 140 pounds on the Elise.
Old 06-22-2008, 10:35 PM   #173 (permalink)
WTF
climb4fun's Avatar
.. And no traction control?
Old 06-22-2008, 10:59 PM   #174 (permalink)
El Jefe - Agent 111
Images: 761
Correct. No TC or ABS.
Old 06-23-2008, 02:49 AM   #175 (permalink)
noobified's Avatar
Are you able to make U-Turns in one turn, or do they end up being 3-point turns?
noobified is offline   Reply With Quote
Old 06-23-2008, 03:15 AM   #176 (permalink)
LotusFamily's Avatar
Randy are you running Yoko Ao48s on your car at the dragon? How did they hold up? We burnt down our Pirrelli P-0s in 4 days during the Hethel trip with only 1700 total miles on the cars. I really don't feel like we were pushing the Nobles that hard through the week (but maybe so). The rubber doesnt seem to be all it should have been.
Last edited by LotusFamily : 06-23-2008 at 03:47 AM. Reason: Wrote Ao38 instead of 48 - oopps
LotusFamily is offline   Reply With Quote
Old 06-23-2008, 08:14 AM   #177 (permalink)
El Jefe - Agent 111
Images: 761
One turn
Old 06-23-2008, 08:16 AM   #178 (permalink)
El Jefe - Agent 111
Images: 761
A048s indeed. Seem to hold up, grip okay in the beginning of the trip. Towards the end, I felt like I had lost some grip due to the typical A048 heat cycling death. But once I got back to San Diego, they felt okay again so not so sure. That is alone almost 4000 miles and they look fine.
Old 06-23-2008, 12:38 PM   #179 (permalink)
:panic:
John's Avatar
Randy - welcome back. Definitely want to stop by at some point to check out your new toy...
05 "Elixige" w/ Stuff
06 Titan SE 4x4 - tow vehicle
07 Mazda 3S - 4-wheeled commuter
99 YZF-600R - 2-wheeled commuter
John is offline   Reply With Quote
Old 06-23-2008, 05:30 PM   #180 (permalink)
cdn_alien's Avatar
Sigh! (Note to self)
Must... save... more... money... for... Noble.
Current: '06 Chili Red Elise, '06 Infiniti M35
Sold: '03 Nissan 350Z , '00 BMW 325Ci, '99 Miata, '90 Miata
cdn_alien is offline   Reply With Quote
HTML code is On
