What's a registered user?
Body epoxy Durability
Not that's it's mentioned anywhere I could find...but does anyone know what the life expectancy of the chassis glue is supposed to be? I'd imagine it would be varied depending on what climate the car lived in.
Epoxy
may want to start here. The shop manual may also lead you to the answer.
http://www.sandsmuseum.com/cars/elis...echnology.html As I understand it is a variant of the glue used on satellites - those have been up there for a while. And I understand there are no reports from Europe of problems and the Elise has been there since 1996. good hunting have fun Nick |
Bucket of Cold Water
As far as what type/brand used, I think it's changed at least once over the production run.
Per the "Elise - The Inside Story" video, the original epoxy was sourced from Ciba Polymers in England. I remember reading somewhere (probably here) that the current glue is sourced from one of the big guys like DuPont or PPG. I'm going to dig up the Ciba website for giggles...
Kevin Magnetic Blue/Hardtop/Starshield - sold 5/17/05
#4 (permalink) | |||
Finally Elise Driver!
http://www.allbusiness.com/periodica.../682738-1.html Quote:
http://www.polymer-age.co.uk/archive64.htm Quote:
http://www.huntsman.com/
05 Elise Racing Green/Red, Touring, Hardtop, StarShield |
#5 (permalink) | ||||
http://www.huntsman.com/advanced_mat...fm?PageID=5813 Quote:
![]() From: http://www.huntsman.com/renshape/Med...r2000_2_Uk.pdf Note at this time it's still Vantico after change of ownership in June 2000. Quote:
From:http://www.huntsman.com/structural-a...l2001_3_Uk.pdf Quote:
http://www.huntsman.com/advanced_mat...fm?PageID=5865 Edit: easier link to remember but takes you to the place above www.araldite.com And FAQs: http://www.huntsman.com/advanced_mat...fm?PageID=5911
#6 (permalink) | |
As for how long they will last, well... I also seem to remember from information provided when the Elise was first created (over 10 years ago), that in accelerated "aging" tests, there was no degradation in the bonding over time. The bonded aluminum chassis will far outlast a typical steel chassis - even in dynamic loading properties. There may be things to worry about with the Elise, but chassis strength and/or lifetime is not one of them.
#7 (permalink) |
Funny I did another google search just in case I found more info, and found this link on elisetalk from two years minus one day ago from Ruediger
http://www.elisetalk.com/forums/showthread.php?t=2626 Coincidence? ![]() Edit: Ok, one last related link: http://www.initialdave.com/cars/tech...isbasics03.htm Edit2: I lied, index to that last link, interesting read: http://www.initialdave.com/cars/tech.htm
#8 (permalink) |
Actually, thegit is right regarding the rivet situation.
My comment is loosely based on the Elise video again. I played the grooves out of that video for about nine years while I prayed that the car would be imported. In one video segment, one of their test engineers illustrated the peel stress resistance of a glued test joint versus one that was also reinforced by rivets at the corners. Although the strength of the bonded joint was sufficient, the controlled tests pointed them towards using rivets for additional crash strength. Having rivets does not undermine the innovative use of epoxies in the Elise; the rivets were simply added to further improve the Elise's safety. Arno, are you out there? I'll bet the self-proclaimed "nerd" could shed further light on this...
#9 (permalink) |
We have attempted to remove a section of the frame and even with removal of the rivets and the use of heat to release the epoxy we had problems. The technician doing the work was an FAA certified aircraft repair person who specialized in metal and composite work.
#10 (permalink) | |
Nerd on wheels
Life expectancy of the bonded chassis is indeed still 'unknown', but even one of the first built S1's right after the real test-mules called 'Ruby' is still running and AFAIK still owned by Dave Minter. Also, as is explaind in the original Elise video... The bonding agent used on the chassis is of a 'hot cure' type. This is the reason why the chassis is put together and then goes into an oven to be 'baked' around 190 degrees C, at which time the bonding agent cures completely and gains it's final strength. On every car you can find stick-on thermometers. Usually on the chassis extrusion visible in the engine bay towards the passenger compartiment. These are there to verify that the chassis did indeed reach the right temperature and are checked after they have cooled down again. As far as I know there is no (generally available) bonding agent that gives the same strenght and has the same properties, but cures at ambient temperatures. This is basically what makes repairing the chassis 'impossible' as you'd need to 'rebake' the chassis after a repair, but that can't be done without stripping it completely bare. The expense in labor cost would be horrendous, making this not a commercially viable option. Technically it's 100% possible, but economically it's 'interesting'. It will be interesting to see how the chassis holds up as the years pass. It is still a bit of a guess what will happen. A lot of experience with bonding has of course been gathered in the aerospace industry, but I think someone in the Elise video does remark on the aging data from planes and crash-resistance that 'if you crash in a plane, bonding strength doesn't really matter anymore'.. Bye, Arno. |
#11 (permalink) | |
Nerd on wheels
Just look in your engine bay and take a careful look at the aluminium extrusions of the chassis beams you can see sticking out from the passenger compartiment (the subframe bolts onto that). You'll see a thermometer somewhere and it will still read the temperature the chassis reached when it was baked. You do find in the service manual the different BetaSeal types used to bond on the different fibregrass parts, windscreen, etc.. Aka everything that's added onto the base chassis later on and is supposed to be removable/replacable in the life of the car. Bye, Arno. |
#12 (permalink) | |
esprit89
50degF, 21 hours 59degF, 13 hours 77degF, 10 hours 104degF, 2 hours 159degF, 35 minutes 212degF, 7 minutes The maximum temperature you cure at will be dictated by what the base material can tolerate and how big/what kind of oven you have. Interestingly the product data sheet also lists lap shear strength knock downs for ambient temperature (higher temperature, lower strength), immersion in various substances (gasoline, oil, water, etc.), hummidity and heat aging. Datasheet The web site indicates that this adhesive Beige in colour (or it's packaging is ), isnt' the adhesive still orange/red in colour?Michael |
