Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > The Library > Front Suspension
Closed Thread
Old 02-15-2006, 01:23 PM   #1 (permalink)
Lotus Sales
Mark Starr's Avatar
Factory Track Pack Recommended Set up
Several of you out there have ordered or already have the optional Track Package on your MY06 Elise or Exige. There is no mention of the recommended set up for street and track use in the manual. There will be an addendum sent out but until that arrives, I wanted to post this for your convenience. This is just the recommended set up and you might find that your style of driving or the track conditions require some fine tuning of the settings or set up............................
Good judgement is based upon experience. Experience is based upon BAD JUDGEMENT!!!
Mark Starr 914 217-4817
Mark Starr is offline
Old 02-15-2006, 03:11 PM   #2 (permalink)
#0518
Robert Puertas's Avatar
Images: 14
Originally Posted by Stan
Does anyone know if they left the steering rack shim alone...and the free length of the springs if different than LSS.
That's the info I have been given. No change to the rack, and slightly longer springs of the same rate.
Robert Puertas
Robert Puertas is offline
Old 02-21-2006, 08:04 AM   #3 (permalink)
Rookie999
Rookie999's Avatar
Track Pack Pics
Some pics of the optional Track Pack dampers/anti-roll bar. The rear track link is under the rear diffuser so no pics. Factory settings for dampers were 3 front, 2 rear, and the anti-roll bar was on the middle (3) setting.
Thanks to Richmond Euroclassics Porsche/Lotus for allowing me to take these pics.
06 Elise, Krypton Green
Sport, Touring, Track Pack,
LSD/TC, SS, HT
Rookie999 is offline
Old 03-18-2006, 12:50 PM   #4 (permalink)
Randy Chase's Avatar
Images: 761
Here is my kit...
As you said, it is to prevent chassis problems and improve safety, when the car is used under high grip loading conditions.
Lexus GX-470 tow vehicle.
Randy Chase is offline
Old 03-18-2006, 05:29 PM   #5 (permalink)
Lotus Sales
Mark Starr's Avatar
I should add that I have gone through many sets of rear wheel bearings due to the added grip of running with slicks. I would imagine that the rear brace kit would help eliminate or at least lessen that added wear and tear of the added and not anticipated stress that slicks add to the rear suspension????? I have not seen that probem arise as of yet on the S2 but expect that this second season of track use with S2's and many running with slicks or Hoosiers, we'll start to see that problem. I would suggest that anyone with lots of track time give a real hard look at the rear wheel hubs and check for play. It's not fun when they go. I have also broken several of the 10.9 strength bolts that secure the rear hubs. If you are out there and running on slicks, I STRONGLY suggest changing the bolts as a precaution. They don't cost much and if you break one when you are on the track loading a wheel, it's not fun!!!!! I have broken them several times and have just made it in with 1 bolt hanging on to the hub keeping my wheel on the car. The warning sign is a wheel bearing noise when one side is loaded up but goes away when unloaded...............PULL IN AND STOP!!!! The cars were NOT designed to run on slicks.............The AO48's allow the rear end to rotate more freely and lessen the stress.............
Closed Thread
