#21 (permalink) | |
Turbo Powered
Also consider this: Airflow is just one piece of the puzzle. The engines VE makes a HUGE difference in what kind of power actually comes out of that airflow. An engine with a VE of 98% will make LARGE gains over an engine at 80% VE. A good example of this is the SRT4 and Cosworth Focus SVT. The SRT4 with 8.1:1 compression and "so so" breathing head makes about 220whp with 17psi of boost. When turbocharging the 2.0 Focus engine with only 8psi, they made over 245whp. (Using the same GT28RS mind you). The more efficient engine does more with less. VTEC Honda's with boost are a very good example of this. How many 400whp B18's are out there running only 15psi of boost. We also made 480hp with a built Mitsu 4G63 running only 16psi of boost on a GT35R turbo - THAT car was a monster when all was said and done. Nothing like 4wd drifts from a roll in third gear. Technically, the 28RS compressor can flow about 33lbs of air at 1.7 ratio - but it's out of it's range to do that big time.
Jay Hassinger: Häss ProTurbo Built to a standard and not a price. 00 MRS Turbo - 11.2@119mph Stage-II+ Hass Kit |
#22 (permalink) | |
Turbo Powered
Lotus chose to go with an accusump for this remedy on the Exige 240R and I tend to side with that solution myself as a backup safety precaution. The turbocharger itself adds no more tax on the oil system as it flows a minimal amount of oil through it's center section and even has a built in flow restrictor. Making the extra power obviously generates extra heat which in turn can create higher oil temps but thankfully Lotus has put in good oil coolers in a proper location. (Not stuck in a side vent as an after thought.)
#24 (permalink) | |
Turbo Powered
On the 1Z Toyota in our MR2 Spyder kit you can really see the different characteristics of the turbos when going from the 28R (rated from Garrett at 280hp) 28RS (rated 320hp) and the GT2871R (Rated at 385hp) all on the same turbo kit and car. The 28R has lightening response and a linear pull from 2200-2300 to redline...very supercharger like feel. Transient response of the turbo in part throttle driving is out of this world. The 28RS has more of a "turbo" feel on the top end, a bit less responsive to the right foot but has a lot more "go" when you do mash the pedal. The 2871 is a wait for it...wait for it...wait for it..HOLY CRAP turbo with real soggy throttle response. It reallly comes down to throttle reponse and transient response IMHO. I've noticed the 1.8 Toyota's for whatever reason do not come close to motivating a turbo like a 2.0 liter Nissan, Honda or Mitsubishi. We've got a GT30R on an SR20 powered SE-R here that is simply a monster and will build 12 psi of boost by 3200rpm and is in full swing by 4000rpm - better than a GT2871 on the 1Z/2Z. The K20 is a whole different animal. It's a very close relative to the Nissan SR20. It has a square bore and stroke (83mmx83mm) and head that flows like the dickens. (Over 300cfm stock!) It also has a pretty healthy bottom power curve end compared to the 2ZZ. Eyelise: I think this is more the power curve you were talking about that you prefer. ![]() That is from our Mazda 3/6 kit with the GT28R on the 2.3 liter Ford engine. WICKED responsive - Audi/VW like, but still pulls good on the top end. That's all you will get out of that turbo on that motor before it starts falling off on the top end. It's done with a capital D, BUT the car is a freakin hoot to drive. This is a 2ZZGE with the GT2871 mentioned above at about 11.5 psi of boost. ![]() The VE of the 1.8 Yota just isn't all that great on the small cam, and it really doesn't push a turbo that well. Not to say that 140ft lbs at 4000rpm isn't about 40 ft lbs stronger than stock but you can clearly see where the turbo comes up and the power and torque takes off. It's building boost down low, but the turbo doesn't swing into it's sweet spot till about 4700rpm. That turbo is still streetable, but I would questions anything larger on a mid engine rwd car. Snappy power on one of these can spell trouble IMHO. It does for the MRS - ask me how I know. My rear quarter panel is primered for a reason. Just my $0.02
#25 (permalink) | ||
Turbo Powered
I think you might be surprised at how you find the 2ZZGE responds to larger turbos. I didn't pick the 28RS because I didn't know any better. I found it was the best turbo that could support 325whp comfortably and still offer excellent throttle response and boost response on the 2ZZGE, and I don't mean spool RPM. There is nothing like squeezing on the throttle 25-50% at 3500-4500rpm in traffic and having the car just squirt forward right away with the turbo happily singing away and increasing the torque by a lot. It makes the car a joy to drive and the power delivery very predictable. On FWD cars in road race situations, I would go the opposite route. The larger turbo cars have always been easier to drive as the boost comes up much more slowly and doesn't blow the tires off while in mid turn. Quote:
#26 (permalink) | |||||
Turbo Powered
That's more or less what I was getting at. Here's a video of what I was getting at. http://www.hassturbo.com/video/se-r/joes_car.mpg (This was at "light" boost BTW. )I owned an identical car to this one that I built and let me tell you - the car is all over the place at 110mph + grabbing for traction and can out run a Yamaho R1 from 50mph past 150mph. (The owner of this car actually owns an R1 and lost to his car on his own bike. ROFL) I was a MESS up at Limerock trying to muscle around the track and slower than the NA cars. LOL Quote:
![]() Quote:
We've tried different set ups including a tight tubular unit and saw no real gain on the dyno at these power levels, sad to say. Quote:
Take a look at this dyno chart: ![]() I was on throttle from the sample time starting and you can see it's building a little boost by 3500rpm with about 6psi by 4000rpm and then going into full swing at about 4700rpm. The turbo was building boost down low, but the engine simply was not responding very well to that boost until it was past 5K rpm. That's the scenario you were talking about using a large turbo with light early boost onset and I hope you don't see the same results. That was with the GT2871R BTW. Just passing along some info - not trying to discourage you at all.
#27 (permalink) | |
Turbo Powered
![]() FYI: I've been past 15psi on pump gas using a 1mm water jet. I don't dare tell customers to do that, but it doesn't change the fact that the stock 2ZZGE was pretty damned okay with it believe it or not. The ignition system bitching up a storm trying to light the fire at that boost with water was another story. LOL
#28 (permalink) | |
Turbo Powered
#29 (permalink) | |
Turbo Powered
Frankly I'm shocked at how many guys are tracking their car. By FAR the Elise community is the most hard core I have delt with regarding actual use of their cars and wanting to drive them around a track. Out of the five cars we currently have in our shop three are going to track them. I would say at least 70% of the kits we have sold to date will be on a road course. I think the low boost option you are talking about will be a pleasant surprise. The most common feedback I have gotten at 6-7psi is "wow, it still feels like the NA car in regard to power delivery - just a lot more of it." Once you get into the higher boost range, the power delivery is more tied to the boost gauge so you feel that "rush" come on when the boost dial swings towards the big end. The light weight of the Elise is also an asset to this nature. My EVO by comparison is a heavy bitch. Off boost, the car is dead as you are trying to move 3300lbs with 122ci. It's not until the boost gauge swings past 15psi does the car get up and go. It really makes for an "on/off" type car as it NEEDS that boost to make enough power to get out of it's own way. With the Elise and low boost it accentuates the already balanced nature of the car while fattening up the powerband across the board so you can punch through that hole and not have to flat foot the car and painfully watch the tach and speedo creep up slowly on the top end. Bah...you guys will just have to start driving them and report back with your own experiences. Trying to talk about it is like trying to explain sex if you've never had it. LOL ![]()
#30 (permalink) | |
Also something quite interesting, Jay thought that the Arquay Sport Cat might actually be more restrictive than the stock CAT. Any one have any info on this. All I know is the Arquay CAT is lighter. |
#31 (permalink) | |
Turbo Powered
The comment was a casual observation. The sport cat has a much smaller overall area compared to the stock unit, but the "cells" look larger so it may be a wash. I really don't have any hard proof for the record and don't want misinformation to get out about the product. I'll see what I can come up with, but the shopvac test isn't going to be very much help IMHO. Maybe we can rig a turbo compressor on a 12hp briggs and stratton to make our own industrial strength blower. LOL
#32 (permalink) |
Here's my latest correspondence from Jay:
"The coated intercooler is supposed to be here late today, that's is the last piece of the puzzle we were waiting on to finish bolting the turbo system up. So we will be back in full swing on Friday to get her buttoned up regarding the turbo." |
#33 (permalink) | |
The 500 mile break-in Sky-King was requesting was not so much for the actual engine break-in but rather to give Hass some time/miles with the car to ensure proper ECU tuning and component reliability. It was more of a Turbo System trial period to help uncover unforseen problems before being delivered across the country. |
#34 (permalink) |
Well I dropped in on Jay unannounced today. He's swamped but things are looking great. My Elise is coming along great. I saw the powder coated intercooler and was amazed on how OEM it looked. Jay still needs to section my Arquay Sport Cat so that the system will work with my Arquay SS twin Tip exhaust. We are hoping to have the car at the Dyno next Wed if all goes well. Unfortunately I didn't have my camera so I couldn't take any pictures.
#35 (permalink) | ||
#36 (permalink) | |
1FastMX5 I saw your car there too. I don't know how you have made it through all this time without your car. I'm going crazy and it's just been 1 month for me. Looks like your having a fun time with that PB Wing of yours. What's happening with that? It looks like XCUSEMI will have the distinction of being the first Hass Turbo on the road. His car is nearly finished. I think Jay's just waiting on one part to come in so he can button her up. |
#37 (permalink) | |
Jay, I'm ready to take it off your hands whenever you are The new PB wing should be there by now and hopefully will have no more issues and can be quickly installed. I'm so ready to get her back! |
#38 (permalink) |
Jay gave me a call today to let me know that he’s trying to figure out what to do with my Arquay exhaust and CAT. It wouldn’t be a problem if I chose to go without the CAT, but I don’t want to have any issues when it comes to emissions. No one is really sure what’s going to happen in CT yet when it comes to this. So it looks like he is going to have to alter the piping on both the cat and exhaust to get it to work with his turbo set up. Hopefully we’ll know whether the system will work with the Arquay Dual SS Tip sometime tomorrow. If not, he will source out a new CAT & Muffler that will exit the rear like the Euro 111S.
#40 (permalink) |
Got some pictures from Jay today. My sport Cat finally got back from the powder coater. Also, Jay's working on a custom gauge pod for me that will go on the shelf on the dash. It will house three gauges. I'm also thinking about having 2 gauges mounted vertically in front of the shifter. Do you guys think it will be too busy?
