Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > The Library > Engine
Old 09-18-2006, 01:02 AM   #1 (permalink)
mlk_f1's Avatar
Images: 11
Helpful Tips for removing Stock Exhaust Manifold
I was trying to post this in the library but was denied access. So, if you Mods find this worthy, please move this to the Library section.
This might be helpful for those that plan to install header.
1) You do not need to remove Belt Tensioner
2) Nor, have to hacksaw the Air Injection tube off.
I did not take pictures, Photos are courtesy of ET user "milcher"
Stock Exhaust Manifold removal tips without the need of hacksaw or belt tensioner removal.
1) remove Cat, Exhaust Manifold upper and lower heatshields.
2) remove the 2 nuts and 3 bolts holding the Exhaust manifold. Also remove the one nut holding the Air injection tube from the rear right wheel well.
3) Remove the stud circled in RED below with a Torx socket.
4) Slide the exhaust manifold out until you have access to the Air Injection Tube Cap from the Rear Right Wheel well.
5) Use a plier to slide the clip free from the rubber hose cap circled in red below. You need to do this from the Rear Right wheel well. Remove the Hose Cap and Clip completely.
6) Now you can slowly work the whole Exhaust Manifold out of the engine bay from below. Trust me, it will come out at just the correct angle. Be patient.
Good luck.
mlk_f1 is offline   Reply With Quote
Old 09-18-2006, 05:02 AM   #2 (permalink)
User, Registered
Good tip, this looks like the best solution for getting the old manifold off.
Francis
2006 Chrome Orange Elise: Base, Hardtop, LSD/TC, FF Engine Damper, Arqray Twin Muffler, Nitron SAs with 525/650 springs, Katana Supercharger, Smaay's fuel rail, Saikou Michi dual catch can, Eliseparts bumpsteer kit, BWR 7/8" Front Bar
2000 Black Integra Type R: Konis, Neuspeed Race Springs, Mugen 26mm Rear Bar, 16x8 SSR Integrals
fpitas is online now   Reply With Quote
HTML code is On
