Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > The Library > Wheels and Tires
Old 09-07-2005, 12:06 PM   #1 (permalink)
Team Fiscal Irresponsible
spider's Avatar
Yokohama 048 tire information, LTS & MH
From TireRack:
"On the M vs MH:
We haven't done test on these tires so we don't have any direct feedback
or first-hand experience with the new compounds.
According to sources at Yokohama, the M compound is good for autocross
or very short time-attack sprints, where tire temps will not build too
high. This is not a track compound. The M compound should have higher
grip levels than Lotus OE spec.
The LTS A-048 compound (original equipment on the Sport Package) is a
unique compound that has been spec'd and tuned by Lotus, and is very
similar to the MH compound.
Also, the construction of the LTS tire is different than all other A-048
versions. The Lotus spec has a nylon carcass, while all others have a
Polyester carcass.
M compound pricing is:
195/50-16 $185 225/45-17 $232.
All 3 tires are molded 6/32nd tread depth. We can shave to 4/32nd's.
Shaving cost is $15 per tire.
We're trying to get tire weights from Yokohama and will forward these to
you as we can get them. Assuming the A048 LTS and A048MH weigh the same
and you're looking at mainly track use I'd recommend going with the A048
LTS since it has been tuned for the car. If you're using for Autocross
the A048M is a better choice.
Thank you. "
'05 Arctic Silver/Ruby Red - Touring/SS/HT
spider is offline   Reply With Quote
Old 09-07-2005, 12:07 PM   #2 (permalink)
#0518
Robert Puertas's Avatar
Images: 14
LTS = Lotus Tuned
MH = Medium Hard Compound
M = Medium Compound
The LTS compound is the same as the Medium Hard compound, but the construction is slightly different, with the LTS tires being slightly lighter in weight.
Robert Puertas
Robert Puertas is offline   Reply With Quote
Old 09-07-2005, 03:57 PM   #3 (permalink)
Elise Royalty
Patricko's Avatar
These are all new A048
225 45 R17 90W LTS; 21.6 Lbs
225 45 R17 90W MH; 22.6 Lbs
195 50 R16 84W MH; 19.8 Lbs
I don't have a LTS front...
Patricko is offline   Reply With Quote
