Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > The Library > Maintenance and Lubrication
Old 05-06-2005, 05:54 AM   #41 (permalink)
MyElise's Avatar
Images: 28
Originally Posted by sleepless
We contacted Canton Racing about getting the exact same spec'd accusump setup as is Lotus uses. Surprisingly, Lotus has given Canton the specs so you can now have the "official Lotus setup". Canton did say that Lotus will be offering the setup themselves in the future; which is why we were surprised that Lotus gave up the specs!Mine is on its way! Should be installed next week.
Sleepless - Did you get the Lotus plumbing specs as well? I'd be very interested in seeing these.
MyElise is offline   Reply With Quote
Old 05-06-2005, 06:01 AM   #42 (permalink)
>>>I wouldn't use 10 weight or even worse 15 weight in the 2zz. The vvt actuators & fuction get horribly delayed in cold weather and cold start ups.<<<
I've notice some Lotus dealers use 10W40 oil for the oil changes they perform.
In a conversation with one dealer I found that the reason they used 10W40 was that it's what they used in other cars, so they always had it in stock...
Charles Rozier is offline   Reply With Quote
Old 05-06-2005, 08:04 AM   #43 (permalink)
Elise Fanatic
sleepless's Avatar
Originally Posted by doma
sleepless>Contact Colin at www.speedwaremotorsports.com.
Have you all seen their 'project car' web page? It's an Elise - and they removed 180 lbs from it. Sleepless, is that your car?? :-)
http://www.speedwaremotorsports.com/project/#
it is my car. we have dropped the weight by 106lbs; not sure where the 180 number came from.
Pete
2005 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo
sleepless is offline   Reply With Quote
Old 05-06-2005, 12:47 PM   #44 (permalink)
A smile a mile.
NMRJock's Avatar
Maybe they dropped 180 lbs and then added 74 (Fire suppression, gauges, etc.).
Paul Parkanzky
Magnetic Blue with Biscuit Touring, LSS, Starshield
NMRJock is offline   Reply With Quote
Old 05-06-2005, 01:09 PM   #45 (permalink)
Elise Fanatic
sleepless's Avatar
It was a typo; now fixed.
NMRJock - Yeah, I've got to stop using those 25lbs VDO gauges But you have a good point, we added at least 10lbs back for the fire system, harness bar and harnesses.
Pete
Old 05-16-2005, 09:58 PM   #46 (permalink)
Elise Fanatic
sleepless's Avatar
Accusump installed!
Pete
Old 05-17-2005, 06:08 AM   #47 (permalink)
MyElise's Avatar
Images: 28
Very nice. Is that an adapter to the oil filter?
Old 05-17-2005, 07:03 AM   #48 (permalink)
Images: 1
It is a sandwich plate (non edible topping) to allow access to the oil system. I have one on the S2000, but mine allows elimination of the engine mounted oil filter and allows plumbing to an external filter, in my case a Canton-Mecca.
I am curious as to the placement of the antibackup valve, the brass fitting in the picture. With the engine mounted filter having an internal antidrain valve, such a fitting usually is not required. I'd have to see how the Elise's Accusump in plumbed to figure out that one.
Elise #2393 Bordeaux/Biscuit/LSS/HT/WindowTinting/Shield. Purchased new 06/01/05.
Canton Mecca Spin-on Oil Filter, Redline Lubricants.
Prolene is offline   Reply With Quote
Old 05-17-2005, 08:47 AM   #49 (permalink)
aletes's Avatar
It looks like the thermostat sandwich plate adapter is still installed? Won't that cause an issue with Accusump charging? I thought you needed use an external thermostat and a sandwich plate adapter with no thermostat built in.
“The Edge…there is no honest way to explain it because the only people who really know where it is are the ones who have gone over.”
aletes is offline   Reply With Quote
Old 05-17-2005, 11:34 AM   #50 (permalink)
TimMullen's Avatar
Images: 19
That should be the standard adapter plate on the Elise (where the oil cooler lines attach). I wouldn't think that the thermostat in the adapter would be a problem - it should simply direct the warm oil through the cooler lines, and cold oil should bypass. I would assume that the lines remain pressurized, and if you plumbed the Accusump into the return line, there wouldn't be any problem...
94 Miata R Package - Black
TimMullen is online now   Reply With Quote
Old 05-17-2005, 11:45 AM   #51 (permalink)
aletes's Avatar
It looks like it is plumbed into the return line. The 'T' fitting is just after the check valve.
Old 05-20-2005, 04:33 PM   #52 (permalink)
Terry's Avatar
What kind of fittings did you use to splice into the rubber line? Also, is there a check valve in the line on the oil cooler side? Did Canton supply it? Finally, what kind of fittings are used on the oil cooler lines into the sandwich plate - they're not AN although what Canton shipped me are AN.
Terry is offline   Reply With Quote
Old 05-23-2005, 07:19 PM   #53 (permalink)
Terry's Avatar
Accusump installed!
What kind of fittings did you use to plumb into the rubber line? Also, did you install a check valve? My mechanic has some questions about doing it this way and thinks another sandwich plate might be the way to go. What do you think?
Old 05-23-2005, 08:15 PM   #54 (permalink)
Elise Fanatic
sleepless's Avatar
Guys, I can't answer all your technical questions since I didn't do the installation. The folks at www.speedwaremotorsports.com have the complete kit. Please contact them for more info. I have a few more pics which I'll post; maybe they'll answer your questions.
Pete
Old 05-23-2005, 08:18 PM   #55 (permalink)
Elise Fanatic
sleepless's Avatar
more...
Pete
Old 05-24-2005, 05:21 PM   #56 (permalink)
Terry's Avatar
Thanks very much! Now, what 's the deal on warranty (maybe a little late for me since I've already bought the kit, but...)?
HTML code is On
