Go Back   LotusTalk - The Lotus Cars Community > Lotus Discussions > The Library > Maintenance and Lubrication
Old 10-19-2004, 09:07 AM   #1 (permalink)
offroadr35's Avatar
Accusump
So now that we have our cars, has anyone gotten an Accusump system? I have heard it is a wise thing to do in this car when using it a lot on the track.
offroadr35 is offline   Reply With Quote
Old 10-20-2004, 02:34 PM   #2 (permalink)
Forum Mop
ace3's Avatar
Images: 5
Re: Accusump?
i'll be in "wussy mode" on the roadcourse until i get an accusump in mine. i trust that motor about as far as i can throw it.
ace3 is offline   Reply With Quote
Old 10-20-2004, 02:37 PM   #3 (permalink)
Also note that Lotus suggests the use of Castrol 10W60 on the track. BMW dealers carry this grade for the M3/M5 models.
Old 10-29-2004, 04:03 PM   #4 (permalink)
untitled
Beanie's Avatar
Accusump is a good idea. I believe there are baffles in your oil pan (unlike the 1ZZ engine) so this should help prevent oil starvation. Still, with a car that pulls more Gs than anything else the 2ZZ has been in and the cost of repair, I'd do it. -- Just my two cents.
Edit: Accusump is also good for startup lubrication!
It is all about "Other".
Beanie is offline   Reply With Quote
Old 10-29-2004, 04:29 PM   #5 (permalink)
aletes's Avatar
I put together a bill-of-materials for an Accusump system a few months ago ... Here is the list:
Canton Racing / Accusump
http://www.accusump.com/
--------- Accusump Unit
3 qt. High Pressure Accusump
1x 24-016 187.50
Electric Pressure Control Valve
1x 24-275 148.50
Stainless Steel Mounting Brackets
1x 24-200 17.50
Steel N.P.T. to AN Fittings
3x 23-245 4.50
Straight Hose Ends for Steel Braided Hose
3x 223-625 9.75
45 Degree Hose Ends for Steel Braided Hose
1x 23-645 19.25
Stainless steel braided racing hose
10x 23-605 7.50 (Foot)
British American Transfer / Mocal
http://www.batinc.net/
--------- Accusump Fittings
AN Female Tee Fitting
1x 938-10
AN Male Union
1x 815-10
Low Restriction Check Valve
1x 610-10
Please confirm the oil pressure requirements.
aletes is offline   Reply With Quote
Old 10-29-2004, 04:33 PM   #6 (permalink)
aletes's Avatar
Paraphrased from Toyota Engineering white papers:
The stock Toyota 2ZZ-GE oil pan has no baffle. According to Toyota this quickens the return of oil into the oil pan. Air suction was minimized by optimally positioning the suction pipe inlet. The 2ZZ-GE can withstand 1.0G without sucking air.
Old 10-29-2004, 04:45 PM   #7 (permalink)
insert clever title here
MattG's Avatar
Images: 11
What about warranty concerns? If we suffer an oil starvation problem, I'd expect that to be covered by our warranty. If we add an accusump, and then experience *any* kind of oil-related problem, our warranty may be voided. Sorry, not trying to hurt Accusump sales here, just pointing out another way of looking at this...
Old 10-29-2004, 05:14 PM   #8 (permalink)
untitled
Beanie's Avatar
I could have sworn I saw an actual picture of baffles in a 2ZZ oilpan.... will search.
EDIT:
You are right. My memory sometimes does that to me.
http://www.spyderchat.com/phpBB/viewtopic.php?t=5181
Sorry.
Old 10-29-2004, 05:35 PM   #9 (permalink)
aletes's Avatar
I plan on using the Accusump in combination with an air to water oil cooler.
Mocal / Laminova
-------- Oil-to-Water Heat Exhanger
Laminova Oil to Water Heat Exchanger
1x A43-330
Sandwich Plate Adapter
1x SP1
Old 10-30-2004, 04:21 AM   #10 (permalink)
Just an idea :
Perhaps the Accusump and the Laminova oil cooler can be combined in one compact unit.
From Laminova you can get cores in various lengths and diameters
Ruediger is offline   Reply With Quote
Old 10-30-2004, 08:11 AM   #11 (permalink)
Auld Lang Syne
Need4Speed's Avatar
Is that to say a complete oil change is necessary for a single track day, or repeated track use, Stan?
Perfection is reached, not when there is no longer anything to add, but when there is no longer anything to take away.
- Antoine de Saint-Exupery
Need4Speed is offline   Reply With Quote
Old 10-30-2004, 10:53 AM   #12 (permalink)
TimMullen's Avatar
Images: 19
Although an Accusump could be a good idea, why change the oil coolers? The Elise already has oil coolers...
94 Miata R Package - Black
Old 10-30-2004, 11:06 AM   #13 (permalink)
Possible accusump aid...our cars come with a bleeder near where the oil filter lives. See PIC below. If this is on the motor side of the thermostat, after the filtered oil ideally then this would be a nice spot to plumb into. There may be others, or the plate could be drilled and tapped to suit.
(You can also see that there is room for a larger diameter / length oil filter if that was desired....You can also plumb an accusump right into a Canton Mecca oil filter if you change the end plate)
Old 10-30-2004, 11:34 AM   #14 (permalink)
TimMullen's Avatar
Images: 19
Why would you need to tap into the "bleeder"? I would think just putting a "T" into the oil cooler return line would be an ideal place to plumb in an Accusump.
Old 10-30-2004, 11:42 AM   #15 (permalink)
>>>Why would you need to tap into the "bleeder"? I would think just putting a "T" into the oil cooler return line would be an ideal place to plumb in an Accusump.<<<
It's not a need, it's just another option. There are many ways to hook these things up. They suggest doing it on the far side of an oil filter with an antidrainback valve. That way most of the oil goes into the motor and not potentially backwards through the oil filter and oil pump. I'm not sure where the various fittings are located along the oil path. I have seen accusumps plumbed into the line leading toward a remote oil filter. That is between the oil pump and the oil filter. In that instance when pressure drops, a good portion of the benefit of the accusump will be wasted as some of the oil goes in the wrong direction. Potentially there could be other issues too.
Old 10-30-2004, 12:43 PM   #16 (permalink)
aletes's Avatar
I would like to use the oil radiator location for a pair of air-to-water intercooler radiators.
The only reason I mentioned the oil radiator and sandwich plate adapter is because the oil thermostat (in the sandwich plate adapter) needs to be taken into consideration when installing an Accusump. If the Accusump is installed on the oil return line, it may discharge fine, but I don't think it will charge as long the thermostat is closed. It may be necessary to install a sandwich plate adapter that doesn't have a thermostat and use an extermal thermostat.
Old 10-31-2004, 07:18 PM   #17 (permalink)
htdaab
atyclb's Avatar
Lotus specifies Castrol RS 10W-60, which is not available at BMW dealers.
I posted more info in the "official track oil" thread
atyclb is offline   Reply With Quote
Old 10-31-2004, 07:43 PM   #18 (permalink)
>>>Lotus specifies Castrol RS 10W-60, which is not available at BMW dealers. I posted more info in the "official track oil" thread<<<
There are some differences of opinion on that oil amongst BMW enthusiasts. Some say the two versions are...the same... and it's just a marketing thing. Some say that one superceded the other. And others say that they are completely different.
Of the three oils Lotus has suggested, only one is easy to find. The Mobil 1 15W50 is easy to find at many auto parts stores. Some dealers are not even using the 5W-40 Texaco street oil.
Old 10-31-2004, 07:52 PM   #19 (permalink)
htdaab
atyclb's Avatar
Old 11-01-2004, 03:32 AM   #20 (permalink)
>>Lotus specifies Castrol RS 10W-60, which is not available at BMW dealers. <<
So...where is the concern? Same oil, two different names per BMW. For me, if I want it I'll get it from BMW where it is stocked. I'm not going to order the same oil with a different name from someone in Europe.
Reminds me of that segment in Pulp Fiction. Over in Paris they call a quarter pounder with cheese a Royale With Cheese. No need to go to France if you want a 1/4 pounder though.
