Go Back   LotusTalk - The Lotus Cars Community > Community > Other Cars and Comparisons
Old 01-17-2007, 09:58 PM   #21 (permalink)
POSITIVE!
newman's Avatar
OK, worked on the tunnel today... well, removing it... We are going to make a custom tunnel for the transmission as well as the exhaust. Probably just formed mild stell. We may make it a removable doghouse kind of thing.
From engine bay:
Yeah, you've stood in your engine bay, but have you ever done this?
Needs a bit more trimming. Just a little bit...
Tomorrow (or friday) I'll be finishing the trimming and building a transmission mount. We decided that since so much material was removed from the unibody, we are going to run some extra bolt-on stiffeners under the transmission.
Oh, and this came:
2008 Aspen White Exige S240: CF splitter|CF wing|CF diffuser|CF side scoops|CF mirrors|Arquay Titanium|Von-hep delete|Saikou Michi catch can|Cup car airbox|6000K HIDs|Custom short shift|Stan+sector111+ctn shifter mods|vinyl wrapped floorboards|Flat black AC surround & center gusset|Tow hooks|Bootie|Led park & plate lights|Smoked front sidemarkers|DRL delete|Hella Supertones|JVC KDAVX44 head unit|Boyo 420t back up cam. PICS
E30GTR Build... too slow... http://www.onyxsyndicate.com/newman
newman is offline   Reply With Quote
Old 01-18-2007, 12:07 PM   #22 (permalink)
Bane's Avatar
Images: 4
Nice cutting job on the transmission tunnel! That tranny is HUGE Is there enough room for the downpipe between the tranny and the steering knuckle? It looks like it's pretty cramped right there.
Old 01-18-2007, 12:57 PM   #23 (permalink)
POSITIVE!
newman's Avatar
the downpipe is crossing over the top of the tranny in a special compartment in our new tunnel, then down that side of the trans...
Old 01-19-2007, 07:39 AM   #24 (permalink)
POSITIVE!
newman's Avatar
last night's progress...
Cut the rest of the tunnel out (another 1" from the rear) and was able to bolt up the transmission. It fits nicely, there is no need to remove or even move the engine to access the transmission bolts... That's a great feature. Especially for anyone who has ever tried to change the transmission on a 300ZX...
I made a temporary tranny mount out of this prybar:
Here are a few shots of the trans in the car:
Next, I began planning a transmission mount. The first step was to make bolting plates. You can see the two i made here:
The main transmission bolting plate is made from 7GA Mild steel. You can see it bolted to the rubber transmission mount. We decided on keeping the stock rubber trans mount, despite the fact that we are using solid engine mounts. Need to have some compliance somewhere!
The other bolting plate picks up the two bolts for the stock transmission mount. Notice the distance from the rubber trans mount to the stock location. Since the transmission utilizes the rubber mount, simply joining the rubber mount to the stock location would result in a point loaded cantilever beam. The chassis is not meant to maintain such loading especially at a point that has already been compromised by tunnel modifications, so an alternate solution, or a dual cantilever beam must be incorporated.
As I mentioned a few days ago, since so much material was removed from the tunnel, a support brace would be desired. This brace was to be located midway down the tunnel, underneath the transmission.
Since the forward face of the rubber mount on the transmission is about midway back on the tunnel, it was decided that a transmission mount/chassis brace "subframe" could be constructed. Bolting plates will be welded to the chassis floor, then the "subframe" will be bolted to that.
Here is an artist's rendition of the proposed solution:
Old 01-22-2007, 06:42 PM   #25 (permalink)
HiOnPSI
P90Puma's Avatar
Updates Newman?
94 Miata. Turbo?
P90Puma is offline   Reply With Quote
Old 01-22-2007, 07:09 PM   #26 (permalink)
Virginia Beach Car Guy
VBCARGUY's Avatar
Neman are you going to race this car in a particular class or are you doing this to just have a bad ass street car? I was thinking of buying a e30 to run in the NASA e30 races. What class would this car be in if you wanted to race? Very cool project by the way!!!!
Triumph Tr4a Race Car 1967 SOLD
1954 CJ 3b Willys
2002 Yukon Denali Daily Driver
2006 Exige. The only man in america to have a exige s then go back to a NA exige
1967 911S 1900lbs 220hp
VBCARGUY is offline   Reply With Quote
Old 01-23-2007, 11:29 AM   #27 (permalink)
POSITIVE!
newman's Avatar
This is strictly a street car. I don't know what the ramifications of trying to use it in some sort of road series would be, but i imagine with all the chassis modifications, i'd be in a very difficult/competitive class. My initial plan was to build this car, then sell it... but i'm starting to like it more and more each day
Here's last night's work:
Alright, since don posted the pictures, i will explain them.
The first thing i did when i arrived was make the rest of the bolting tabs for the transmission mount. These were fabricated from 1/4 X 1 1/4 HRS flat stock. There were a total of four. The center plate is 10GA Mild steel. I obtained some 1 X 1 X 11GA square tube to use for the frame.
The next step was to fix the rear passenger transmission mount point. As you can see in this old picture, one of the mounting bolt holes (upper right) was removed to to allow for clearance of the differential.
The manner in which the floor was cut allowed access to the area near where the nut had been, so i simply drilled a hole and tacked a nut in place. I then sprayed everything with primer to prevent rusting. Done.
Next, I fabricated the front of the transmission support. This support is also an integral chassis member, as a substantial amount of rigidity has been lost when the formed tunnel was removed. Since there will be substantial stress on the member, it was important to have it bolt to a substantial support. The solution was to weld 7GA plate on the inside of the chassis. The location of the plates is such that the outside edge of the support is actually welded to the "frame rails" of the car. The steel is a pain in the ass to weld on, and welds like crap. I am not the best welder, or even decent, but there is something in the chassis that makes it very "spattery". I cleaned the metal VERY thoroughly.
On the passenger's side, the floor was very solid. This is the plate i welded in:
On the driver's side, the floor had been compromised a bit more by rust, so i used two plates. A slight bend was required and with no brake in sight, i used a seam as opposed to a bend. Before tacking these in place, I used a wire wheel to grind off ALL the rust underneath the plates. I still need grind off the undercoating before welding it. I started laying a bead and almost asphyxiated. Photo of the driver's side:
Next, i simply just welded up the frame. Some slight changes had to be made from the initial plan. These changes allow for better clearance, both ground and transmission. I still need to weld on two more braces that tie the mounting points together fore and aft. Here are pictures:
Engine is nice and straight:
View from the front:
View from the rear:
View from underneath:
Some research yielded information about driveshaft angles. The motor was moved up slightly from it's original position to allow for a closer driveline angle. The rear differential may need some slight shimming so it points upwards slightly more, but all in all, it is very close to perfect.
Answers to questions:
Originally Posted by Viper966
not gonna be too much room for a passenger seat
Not true, you can see the front seat mounting stud is actually behind the differential
Originally Posted by MaximaSE98
shifter looks like its going to be pretty far back
Shifter is about .75 to 1" back from stock location
Originally Posted by fastandcheap
why did you remove the steering wheel?
Steering wheel removal was required for dash removal. I kept hitting my head on it, so i took it off. It wasn't even bolted on, just placed on the spline to allow the car to be moved.
Old 01-24-2007, 10:42 PM   #28 (permalink)
POSITIVE!
newman's Avatar
here's today and yesterday's updates. I apologize for typos. More on this later...
Yesterday:
Added another brace to the crossmember. This triangulates the subframe and i am convinced it is now strong enough. My welding leaves much to be desired... I need to work on this much more...
Next, pulled the transmission back out of the car and unbolted the transfer case. I took everything out of it. This is what was left.
Then i went home.
Today:
Went to the shop after work. I taped off the bearings to avoid contamination and bolted the gutted transfer case back together. I then used the horizontal band saw and cut the output case off of the transfer case.
This step went remarkably smoothly. The result:
Next i mounted the transfer case on the milling table I was only able to get 2 mounting points, one of which was a bit "shady" but I hit it with a rubber mallet after i bolted it down, and it didn't budge. The tool in the mill is not the tool i used (i used a 2.5 inch facing tool) I used a level and shims to get the case mounted correctly. The location of the face didn't need to be that precise, so a level was fine:
Next, i made pass after pass on the part, taking off about .100 per pass. About an hour later I had a flat surface, about an inch shorter than the above picture. (sorry, no pic)
At some point during this, the tape over the bearings gave way and a ****-ton of aluminum chips made their way into the front bearing. I will try my best to get them out of there with a parts washer/ air gun, but i may need to suck it up and buy a new bearing. Meh, live and learn, I should have taken it out first, instead of trying to take the easy way out and "cover" it.
Also at some point during this, i somehow managed to crush my hand between the workpiece and the tooling. I had to pick bits of fingernail off the tooling. EW.
Now that the face was complete, i chucked up a drill and drilled (11) #21 holes X .9 deep along the perimeter of the face. Then using a hand tap, i tapped the holes to 10-32 thread. A hand tap was a bad idea, i should have used the mill to guide the tap, as one of the bolts went in slightly crooked, not a big deal, though. It is not terribly off. The hole that looks like it is "falling off" is intentionally placed there, as it was necessary to avoid an internal bolt.
All that was left was too make a cover. Since i had written down the X,Y locations of all the holes i had drilled in the case, it was relatively easy. I used a belt sander and the mill to make the outside perimeter, then after the holes and perimeter were complete, i made a few facing passes on the mating surface of the cover. Due to the fact that the cover was no longer in square, there was a tiinny bit of chatter on the final face, but nothing that wont be sealed with RTV or hondabond.
The finished cover and assembly:
Total time = 6 or 7 hours.
Dollar amount saved (vs buying rb25 transmission) = $1500
Weight difference = negligable
Now i just need to put it back together. Oh, I also plan on drilling a tapping a few holes on the cut-off portion of the tcase, then using a torque wrench to find out at what torque the threads strip, this will allow me to get a torque value to tighten the hardware to.
I will leave you with this picture:
Old 01-25-2007, 11:19 AM   #29 (permalink)
Land Rover
I have done a fair amount of chassis welding if you want to send me what you are looking at as far as rust.
The best way on a unibody car is to do what the 911 pre-galvanized pans do when it is not terminal and just cut it out the rusted bits and butt weld in a new panel of the same gauge.
I you don't care about looks you can just cut out the rust and plate the holes.
The strongest would be to do the 911 frenched in custom panel method and then plate over the weak spots.
Ron
2006 Autumn Gold Elise
SELL ME YOUR AUTUMN GOLD HARDTOP PLEASE OR WILL TRADE FOR CARBON FIBER LOOK TOP I ALREADY HAVE
evilfij is offline   Reply With Quote
Old 01-30-2007, 06:59 AM   #30 (permalink)
POSITIVE!
newman's Avatar
Alright, heres the update for the past few days...
Thursday: Begin assembling transfer case.
Friday: Complete transfer case and reassemble transmission. The total savings was a substantial amount of room and about 30lbs of ROTATING mass.
Here are pics of the completed transmission.
Saturday I began trying to solve the next major hurdle... The brakes. I tried a few things, looked at various brake boosters and master cylinders... What i found to be the most space efficient was a civic master cylinder and booster. I feel confident that this setup will be fine for the street. The car weighs less than a civic EX in full trim, and had plenty of stopping power on layzie's turbo hatch. (In fact, it's layzie's old unit :bowdown. While this setup isn't exactly track-able, it will do for now. I didn't want to blow hundreds of dollars on a tilton setup just yet, because I don't even know the fate of the car, as yet... but I digress.
Without modifying the civic brake booster at all, I probably could have fit it in place, but the clearance would have been tight. The bolt pattern on the civic unit is a wide rectangle. (3.5 inches wide X 2 inches tall). In order to get the mounting studs to clear the clutch pedal bracketry, I would have to cheat the master cylinder almost an inch TOWARD the motor. Also, the studs on the driver's side of the car would be floating in midair, as they passed through the center hole of the old unit. That's no good.
however, if I rotated the booster 90 degrees, the bolt pattern became a tall rectangle (2 wide X 3.5 tall). In this configuration, both of the above problems were solved. The new bolt holes required in the firewall landed on sheetmetal (albeit, not a lot) and not only was i able to "re-center" the booster, but was now able to cheat it about an inch AWAY from the motor. Holla.
The next step was to drill the new holes, and clearance the firewall for the snout of the booster. I'm a bit ashamed at how this turned out... I measured twice, carefully drilled the firewall, then tried to fit the booster. What I failed to notice was the clearance for the brake pedal mounting bracket interfered with the studs on the booster, so the whole assembly needed to be shifted around slightly. I was a bit frustrated at this pint, and probably should have called it a day, but i attacked the firewall with a die grinder until it fit.
Pic = YUCK!
Sunday:
Well, now that we had fit the booster at 90 degrees, it was now necessary to rotate the master cylinder BACK 90 degrees. Since the booster is a sealed unit with a rubber diaphragm, welding and/or drilling it was out of the question. My answer to this problem was again the machine shop. Using some 3/8 6061, I fabbed up these brackets in about 3 hours. They allow the master to be mounted at exactly 90 degrees from it's original position.
Still a bit embarrassed about my ****ty firewall job, i fabbed up this closeoff plate out of 11GA 304SS. The picture is deceiving, but all the edges are perfectly square and all the holes are clean.
Of course, even without the plate, when everything is installed, you can barely see any of the "hack job", but it's there for my personal peace of mind. As for structural integrity, the brake pedal support, which you cannot see, provides all of the support for the booster assembly. The firewall, even in stock form, provides very little support.
Monday:
The last step, since the booster (and thus, the actuation shaft) moved OUTBOARD 1", the pedal needed to be modified. I don't have a before picture, but perfectly enough, the OEM pedal actually had a 1" extension INBOARD. I simply cut this off and welded it back on @ 0" extension.
After i bolted everything back together, i tested for smooth feel and travel. Success!
We spent the time afterwards relaxing, chilling out and just talking about our feelings.
I also performed some preliminary radiator and intercooler fitment analysis...
The entertainment of the night was watching Gary (deviousTSi) manhandle his 1G DSM with 4 seized brakes into the shop. It was manly as ****.
Old 01-30-2007, 08:13 AM   #31 (permalink)
HiOnPSI
P90Puma's Avatar
I've done that one before, Except it was using a hatchback to push in the DSM and it wasnt a shop it was my garage. With no help either. It sucked.
94 Miata. Turbo?
Old 01-31-2007, 06:27 AM   #32 (permalink)
POSITIVE!
newman's Avatar
Pretty simple yet a bit time consuming.
Yesterday I wire wheeled and sanded the driver's side floor pan making sure to get all of the rust off. Most of it was actually just rust dust from a few problem spots:
Then, using some 16GA plates, I tacked the plates over the rust from the inside:
Next, I will fill in the seams with seam sealant and then paint the floorpan with rust inhibiting paint. This is a lot easier than I thought it was going to be.
Old 01-31-2007, 06:47 AM   #33 (permalink)
Land Rover
Seam seal the underside too.
Then primer, then paint, then underseal.
Old 02-01-2007, 01:08 PM   #34 (permalink)
POSITIVE!
newman's Avatar
yesterday, tonight, and tomorrow all look like they will be spent grinding rust and welding. Not a lot to report on that front.
However...
2 sets one for mockup/jig one for the final product.
1/4 Mild steel
1/2" 304SS
Compliments of Derrick Corporation. Holla.
Old 02-04-2007, 01:50 AM   #35 (permalink)
POSITIVE!
newman's Avatar
Ok, here's some body shots...
Before:
After:
A few blow holes, nothing that won't be taken care of with seam sealer, but all in all a good solid repair.
The last shot is a good comparison for everyone who thinks the shell is beat... See the rust at the bottom? That's one day of surface rust on 100% new metal... The camera REALLY makes it apparent... It's almost invisible to the naked eye... Same goes for a lot of the "rust" on the car...
Old 02-05-2007, 06:17 AM   #36 (permalink)
POSITIVE!
newman's Avatar
Sunday...
Before:
After:
Only one more rust spot remains, then it's on to the manifold!
Old 02-05-2007, 02:36 PM   #37 (permalink)
Bane's Avatar
Images: 4
Pretty impressive body work from what I can see.
Have you thought about spot/seam welding all over to stiffen the car up? You may as well at this point...
Old 02-07-2007, 05:38 AM   #38 (permalink)
POSITIVE!
newman's Avatar
just dicking around, not the actual dimensions... yet:
Originally Posted by focusinprogress
ok, for real......i tried doing a collector like that a while back with CAD and couldnt do it.......how did you do that?
That part actually only took about 20 minutes. It took me an hour or so to figure out the best way to constrain the elbows...
The way i set it up, I can simply enter a few constraints to my browser bar to adjust the runner length, until they are all equal, then I can actually drag the tubing around on the screen until it is packaged properly, all the while maintaining 100% tangential fitment.
Old 02-08-2007, 09:48 PM   #39 (permalink)
POSITIVE!
newman's Avatar
Ok, so... I finished all the tack welding on the floor... I received an offer from a guy at work to do the whole car, so as soon as i have it soda blasted, he is going to seam weld the chassis...
So, in the meantime, i picked up a can of this (ted nugent approved!):
It was 30 bucks a quart, I hope it works well...
I am just going to leave it like this until the underbody/bay/interior has been blasted...
Next, I built a jig to mount the turbo... Yes, i know what you are thinking about turbo inlets... the answer is MAYBE...
I included some frame reference planes and a motor mount clearance simulator, so that When i start drawing this in CAD, I will know what i need to avoid, without having to keep taking measurements on the car...
Old 02-09-2007, 07:39 AM   #40 (permalink)
Lulu ROX!
Andrikos's Avatar
Phenomenal work, Newman.
I'm enjoying your writeup, keep it up!
My daily driver is an orange plastic toaster
Andrikos is offline   Reply With Quote
