Go Back   LotusTalk - The Lotus Cars Community > Community > Other Cars and Comparisons
Old 05-22-2009, 12:36 PM   #161 (permalink)
AnsisK's Avatar
Oooo it's gonna be a bit of a surprise to see how that colour BBS rolls with the chartreuse paint. Might not sit too well, but I've got high hopes. This'll be one BA machine when all's said and done!
Cut me I'd bleed Lotus. -Gordon Murray
AnsisK is offline   Reply With Quote
Old 06-11-2009, 06:18 AM   #162 (permalink)
POSITIVE!
newman's Avatar
There have been a myriad of updates that I failed to post here:
E30GTR-TEST FIT TIRES/BRAKES ARRIVE
E30GTR-DISASTER: ENGINE PROBLEMS
E30GTR-FRONT BRAKES, AXLES
E30GTR-FUEL RAIL CONSTRUCTION
E30GTR-ENGINE CLEANUP, PARTS ARRIVE
E30GTR-POLISHING MASTER CYLINDER
E30GTR-EBRAKE INSTALLED, MORE POLISHING
2008 Aspen White Exige S240: CF splitter|CF wing|CF diffuser|CF side scoops|CF mirrors|Arquay Titanium|Von-hep delete|Saikou Michi catch can|Cup car airbox|6000K HIDs|Custom short shift|Stan+sector111+ctn shifter mods|vinyl wrapped floorboards|Flat black AC surround & center gusset|Tow hooks|Bootie|Led park & plate lights|Smoked front sidemarkers|DRL delete|Hella Supertones|JVC KDAVX44 head unit|Boyo 420t back up cam. PICS
E30GTR Build... too slow... http://www.onyxsyndicate.com/newman
newman is offline   Reply With Quote
Old 06-11-2009, 08:02 AM   #163 (permalink)
POSITIVE!
newman's Avatar
One more:
E30GTR-ATi SUPERDAMPER
Old 07-11-2009, 03:49 AM   #164 (permalink)
POSITIVE!
newman's Avatar
Engine mod list:
•R32 Nissan Skyline GT-R RB26DETT
•87mm bore/3 angle valve job
•Wiseco 87mm Pistons
•Eagle Rods
•HPE Crank collar
•ARP head studs
•ARP Flywheel Bolts
•ARP Exhaust manifold studs
•EPP valve guides
•Ferrea Dual valve springs
•Ferrea Valve spring locators
•Ferrea Retainers
•Ferrea Locks
•ACL Calico coated main and rod race bearings
•Garrett GT35R .82 A/R
Tial 38mm WG
•Spitfire Coilpacks
•New OEM Water Pump
•New OEM Oil Pump
•Trust Timing Belt
•Powdercoated valve covers
•OEM gasket kit
•Cometic MLS Head gasket
•Polished alternator
•ATI 1000HP Race Damper
•Custom valve shims
Rest of the car:
Chassis:
• 1987 BMW 325IS (manual)
•Seam Welded
•Vito Antonicelli 10 Point Cage
•Every suspension member powdercoated
Body:
•Ireland Engineering Fender flares
•OEM Mtech1 Valences and Sideskirts
•Euro Bumpers, Dechromed
•Shaved Side Moldings
•Shaved Fuel Door
•Shaved Sunroof
•Custom baby puke paint
•Newman Engine Mount
•Newman Transmission Mount
•Custom Tunnel
Transmission:
•Modified RB26DETT Transmission
•Nismo Flywheel
•EXEDY 3 puck clutch
•Custom Driveshaft
•E30 M3 LSD 4.11
Fuel:
•Bosch -044 800HP fuel pump
•Seimens 870cc injectors, flow calibrated to w/in .5% of each other
•Summit 8 Gallon Fuel Cell
•Custom Fuel Cell hold down straps
•Custom Fuel Rail
•Braided -8AN Fuel inlet line
•Braided -8AN Fuel feed line
•Braided -8AN Fuel return line
•Aeromotive Rising rate regulator
•Summit Inline fuel Filter
•Custom filter and pump mounting brackets
Exhaust:
•Newman 304SS heavy wall manifold
•Newman 304SS exhaust
•Tial 38mm wastegate
Induction:
•Newman 304SS IC Plumbing
•PWR 24X11X3 IC core semi-custom endtanks
•Tial 50MM BOV
Cooling:
•MOXIES/Newman Radiator
Electrical/Management
•AEM EMS Speed Density Engine Management
•AEM UEGO controller
•AEM Serial Gauge
•HKS Turbo Timer
•New Engine Harness
•Kwikwire Chassis harness
•(4) Greddy warning gauges
Suspension:
•Ireland Engineering road race springs
•Ireland Engineering poly trailing arm bushings
•Ireland Engineering Poly Subframe mounts
•Ireland Engineering 22/25mm swaybars
•Ireland Engineering Camber/rear toe kit
•Bilstein HD Dampers
•New OEM wheel bearings
•New OEM F&R strut mounts
Wheels:
•Work VS-XX wheels (17X10, 17X8.5) Custom Offset
•Falken Azenis RT-615 275/40/17, 245/45/17
•Vorshlag 90mm wheel studs
Interior:
•Sparco Evo Seats
•Corbeau Harnesses
•Sparco 300mm steering wheel
•Rhinoliner interior and trunk
Brakes:
•Wilwood billet forged superlite narrow body, differential bore 6 piston calipers (front)
•Wilwood superlite 4 piston caliper (rear)
•Wilwood 13X1.1 GT48 rotor (front)
•Wilwood 11.75X1.25 HD rotor (rear)
•Cutsom machined rotor hats and brackets
•Massive rear hat, ebrake ring and bracket
•Wilwood Q pads
•New OEM ebrake setup (backing plate, springs, adjusters, cables, pads, actuator, pin)
•Wilwood Prop valve (installed next to driver’s seat)
•Custom Brake Booster
•Polished Master cylinder
•-4AN stainless brake hardlines
•-4AN stainless braided brake hoses
Old 07-17-2009, 07:32 AM   #165 (permalink)
POSITIVE!
newman's Avatar
Not sure if anyone reads this or not, but blog is updated:
E30GTR-BIGGER BRAKE KIT
E30GTR-VALVE SHIMS
E30GTR-TOP END
E30GTR-TURBO BRACING
E30GTR-MANIFOLD INSTALLATION
E30GTR-DROPPING THE MOTOR
Old 07-17-2009, 07:43 AM   #166 (permalink)
gt3guru's Avatar
I love single turbo RB26 motors. They look mean... even in pink!
2005 Elise, Saffron Yellow, Touring, Sport, Black wheels, Hard top, dual oil coolers, focal front speakers
1998 BMW 318ti, 77k miles. M sport package, 5 speed. Dependable daily driver since 97
1996 Colnago Technos, Dura-Ace, Zipp, spinergy, Specialized, Mavic.
And I ride it in the middle of your mountain roads. I hope your insurance is as good as my lawyer.
gt3guru is offline   Reply With Quote
Old 07-17-2009, 07:44 AM   #167 (permalink)
gt3guru's Avatar
Where does the exhaust go after leaving the turbo?!?!
Old 07-17-2009, 10:08 AM   #168 (permalink)
AnsisK's Avatar
Please don't stop updating! Plenty of people read this!
Thanks for sharing the build so far.
Old 07-17-2009, 10:57 AM   #169 (permalink)
NOT ßANNED!
Demonized's Avatar
Love it.
Old 07-17-2009, 01:00 PM   #170 (permalink)
Bane's Avatar
Images: 4
Dude checking the Rockwell hardness of the stock shims, finding raw material, turning it down, using a wire EDM, and then heat treating the metal is freakin' HARDCORE
$599 PPE header (INFO)
2007 BMW 335i - Mostly stock
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
Old 07-17-2009, 01:07 PM   #171 (permalink)
breinhar's Avatar
"•Custom baby puke paint" and a pink engine. I love the color combo!
"I think a Ferrari is a scaled down version of..... God"
breinhar is offline   Reply With Quote
Old 07-17-2009, 02:03 PM   #172 (permalink)
BANNED
SweetDaddyD's Avatar
Images: 2
This is utterly ridiculous.
And awesome!
SweetDaddyD is offline   Reply With Quote
Old 07-17-2009, 02:18 PM   #173 (permalink)
Carb novice
Cegan09's Avatar
you've got some interesting color choices, but overall
keep the updates coming, this think looks like it should be awesome.
1987 Porsche 924S - Project restarting very soon
1976 Yamaha XS500
'05 Elise - Dads
Cegan09 is offline   Reply With Quote
Old 07-17-2009, 05:09 PM   #174 (permalink)
POSITIVE!
newman's Avatar
There's a vband clamp right after the flex section now...
Old 07-20-2009, 06:06 AM   #175 (permalink)
POSITIVE!
newman's Avatar
E30GTR-TRANSMISSION INSTALLATION
E30GTR-CLEANING GARAGE
Old 07-20-2009, 10:30 PM   #176 (permalink)
BANNED
This really interesting thing and don't ever stop updating. Check out the new 2010 bmw m3, it might help you.
steves1986 is offline   Reply With Quote
Old 07-20-2009, 10:53 PM   #177 (permalink)
Driver!!
serpent's Avatar
SICK SICK SICK
please dont stop updating. Cant wait to see the fully finished car
Studies show 100% of people die. Might as well have some fun.
serpent is offline   Reply With Quote
Old 07-22-2009, 07:09 AM   #178 (permalink)
POSITIVE!
newman's Avatar
E30GTR-AN PLUMBING
Old 07-29-2009, 11:18 AM   #179 (permalink)
POSITIVE!
newman's Avatar
E30GTR-EXTERIOR PAINT
E30GTR-COOLANT PIPES/BREATHER LINES
Old 08-28-2009, 11:03 AM   #180 (permalink)
POSITIVE!
newman's Avatar
E30GTR-COOLANT PIPES POWDERCOATED
E30GTR-WINDOW CRANKS
E30GTR-BLACK TRIM INSTALLED
E30GTR-BREATHER LINES & PACKAGE TRAY
E30GTR-RACE TECH DASH
E30GTR-FAN & FIREWALL CLOSEOFF
E30GTR-3D PRINTER
E30GTR-SHORTENING STEERING HUB
E30GTR-SMOKED EURO LIGHTS
E30GTR-WIRING SCHEMATIC
E30GTR-COOLANT EXPANSION TANK (my second TIG welds)
E30GTR-WIRING STARTED
E30GTR-THOTTLE CABLE AND FUSE PANEL
