A 2bular mule
Hi Guys thought you might like to see this.....
With the extra volume and heat of the SC I had been talking to Jim about trying to increase the flow by going to a larger diameter. Jim wanted to cut my original zaust up to see how it had done with the extra flow. The Bemani kit runs a 3inch diameter up to after the U-bend so the cat went back to Jim to have the taper replaced and run a 3inch through the whole system. The actual box is the longest Jim could fit in the space (24in long) Friday night was fitting time as I was at KH at the weekend and boy is it a mean zaust Jim has made ![]() ![]() ![]() ![]() |
Meow!!
That looks freakin' MEAN.
#6 (permalink) | |
kinda over estimated the length of the new diffuser Jamie had fitted! I'll sort it out next time. More interested in the noise readings though. |
#17 (permalink) |
Waiting for next Lotus...
Is the tip a bit too close to your painted clam? I wonder if it could cause permanent damage to the paint??? I was worried about mine, but looking at yours; you are right on top of it.
Just a heads up before something happens; maybe you can avoid it if this is a possibility.
2009 Mini Cooper JCW - Dark Silver/Black - sport suspension/cold weather package 2008 997 GT3 - Carrara White/Black - PCCB's - 350 lbs of weight reduction Past Lotus Cars: 2005 NFB Elise, 2007 CO Exige S, 2005 AR Elise, 2008 CO Exige S 240 |
