Old 08-27-2009, 08:32 PM   #1 (permalink)
Anyone replaced their OEM Cat to High flow Cat?
Was wondering if anyone replaced their OEM Cat to high flow cat only in conjunction with OEM header and exhaust?
Will I likely to see more gains replacing the cat only then an exhaust?
I do like the looks of the Oem exhaust.
Any problems with emissions?
thank you
monkeyboo is offline   Reply With Quote
Old 08-28-2009, 05:02 AM   #2 (permalink)
User, Registered
fpitas's Avatar
You might gain a few hp, but you might also start getting a P0420 CEL, I know I did from the ForcedFed sport cat. Some solutions exist:
CEL Eliminator works
Francis
fpitas is online now   Reply With Quote
Old 08-28-2009, 06:37 AM   #3 (permalink)
How much of a difference in terms of HP and noise? As well did you have trouble doing emissions after the sport cat?
Thank you
Old 08-28-2009, 07:17 AM   #4 (permalink)
GR8 SCAPE
waydui's Avatar
Thank you
I replaced the stock cat with a straight pipe.
Noise increase was significant, but I like it. Butt dyno says it is good for some extra hp, but how much is just a guess.
I used a Weapon R eliminator angle fitting (see pic) to trick the O2 sensor. No CELs or engine issues.
Emissions isn't an issue for me as my car is registered as a "Collector" vehicle in Ohio and as such is exempt from emissions testing.
Regards,
Wayne
_______________________
Old 08-28-2009, 07:48 AM   #5 (permalink)
Super charged!
Vishus_1's Avatar
Images: 62
Monkeyboo
The problem with any exhaust/cat modification is the ECU. On all Elises and Exiges the adaptive ECU detects cerain alterations and adjusts to compensate for it.
Even if there was some HP to be gained from the high flow cat, the ECU will adjust A/F ratios, timing to basically prevent that.
To ever make the sport cat or an exhaust improve performance, you will need a custom ECU tune. Someone like CharlieX can do that but it will be as much, if not more, expensive than the whole exhaust itself.
If you search this forum, you will learn other pro's and con's to header, cat and exhaust changes. There are lingering fuel fumes, codes tripped and emissions issues (in some states) that you might want to be aware of.
2009 Exige 260 SPORT - Chrome Orange / Carbon Fiber / Black with the mustache
Purchased through St Louis Motorsports
Vishus_1 is offline   Reply With Quote
Old 08-28-2009, 08:11 AM   #6 (permalink)
Exige Cup 255
Noel's Avatar
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
I run a Komo-Tec high flow cat and use the same CEL eliminator as Wayne.
No problems whatsoever.
Noel is offline   Reply With Quote
Old 08-28-2009, 09:23 AM   #7 (permalink)
FIL
Serial Thrilla
FIL's Avatar
I run a Larini Decat and a CEL Eliminator from PEP boys ($3). No CEL lights or emission problems. Biggest difference is deeper sound, fumes, and improved throttle response.
05' Elise - BWR supercharger, Quaife LSD, Nitron Race Triple Adjustable, LETSLA, Larini Decat, Larini Exhuast, ACT HDSS, Fidanza flywheel, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, desnorkled, ForcedFed CF splitter, Manly's engine mounts, S111 harness bar, Schroth harness w/ S111 seat grommets, Oil Drain Valve, Painted Black Diffuser, Braille battery, Custom Battery Switch
05' Corvette - Z51 Convertible - 630hp 6.6L [DON'T YOU JUDGE ME!!!] (SOLD!)
FIL is offline   Reply With Quote
Old 08-28-2009, 11:30 AM   #8 (permalink)
rstutts's Avatar
Have you thought about getting your header ported? According to a thread on 'Intakes and Exhausts' you will gain hp and not have to get a reflash on your ECU. I am just repeating what was said on that thread, as I have not had it done (although I have considered it).
Rick
2005 Solar Yellow Elise touring package, star shield, hard top, soft top, ACT HDSS clutch, Saikou Michi catch cans, LED tail lights and VF II, 288 whp ()
2001 Green Toyota Tacoma, 4 x 4
2008 Red 5455 Massey Ferguson, 6 x 6, cab, ipod, GPS navigation, regular beer holder
2001 Yellow Cat D3G-LGP, custom made beer holder
rstutts is offline   Reply With Quote
Old 08-29-2009, 07:17 AM   #9 (permalink)
Thank you guys for all the wonderful reply! I will have to rethink about this one.
Also difference between De-Cat and Sport cat, would this be Night and day interms of performance???
Old 08-29-2009, 06:31 PM   #10 (permalink)
I've got the Larini sport cat with the stock exhaust. Sound remains close to stock and no CELs. Car seems to have slightly more torque. I daily drive my car and can run in high gear at times when I would have downshifted before.
trav34 is offline   Reply With Quote
Old 08-29-2009, 06:44 PM   #11 (permalink)
Seb
<3 QR25DE
Seb's Avatar
High flow cats are bull****, and a waste of money.
Seb is offline   Reply With Quote
Old 08-29-2009, 06:58 PM   #12 (permalink)
You seem to feel strongly about it. Care to share some more detail?
Old 08-29-2009, 07:17 PM   #13 (permalink)
Seb
<3 QR25DE
Seb's Avatar
Sure. They are dyno proven to do nothing.
The only thing they do well is break apart. They have a much shorter shelf life than typical OEM supplied catalytic converters.
Old 08-30-2009, 05:56 AM   #14 (permalink)
Got a link so the rest of us could review the dyno data?
Old 08-30-2009, 09:37 AM   #15 (permalink)
Seb
<3 QR25DE
Seb's Avatar
It was so long ago in the DSM community, I doubt I could find it. It was on a site called MitsubishiUnited.
It's a pretty universal opinion though, so I'll just google it.
I just googled it, and couldn't find what I was looking for, so I'll just explain it myself.
The reason it's a 'high flow' catalytic converter is because it simply has less material than the OEM one, thus increasing the flow. So what? Well that means that the cat won't last as long. If you have ever removed a cat from a high mileage car, they weigh a freakin' tonne and a half. So think about it, by reducing the restriction ever so slightly, what are you really gaining? I can tell you with certainty that it's in the tenths of a horsepower.
Old 08-30-2009, 02:05 PM   #16 (permalink)
Might want to check this out ... 2Bular - Performance Exhausts
"Sports Cat" ... always an exception.
Ol'Racer is offline   Reply With Quote
Old 08-30-2009, 02:24 PM   #17 (permalink)
mx1
Wrong info?
So, after reading the Tubular page on this, I guess the guys who said the ECU won't relearn and that sport cat does not do any good were wrong???
I almost thought no after reading their posts, now I'm back to considering.
Thanks.
Previous--66 Austin Healey 3000; 79 Alfa Spyder; 72 BMW 2002; 85 944; 86 MR2; 89 944S2; 89 944S2 w M030;
Current--01 Audi S4, modded twin turbo;07 Lotus Exige S
Lucky enough to have driven the autobahn for 5 years
mx1 is offline   Reply With Quote
Old 08-30-2009, 03:05 PM   #18 (permalink)
Super charged!
Vishus_1's Avatar
Images: 62
2bular is a quality product - absolutely, however reread what Jim (at 2bular) states on the site link above...
The Lotus/Toyota ECU will adjust, eventually.
What he means is any actual gain from the sport cat will be taken away by the learning of the ECU. This is just how it works. He then goes on to talk about some of the reflashes available. This is the only way you will get a gain from a sport cat.
The Gotham + 2bular tune is what - about $1400 (goth.am webstore!) - so add that cost on top of the cat and exhaust. Then, according to Charlie, you should be good for about 240-250RWHP.
Old 08-30-2009, 03:18 PM   #19 (permalink)
Seb
<3 QR25DE
Seb's Avatar
Yes, that is a true exception.
Old 08-31-2009, 08:11 AM   #20 (permalink)
Exige Cup 255
Noel's Avatar
I beg to differ that high flow cats don't work. If you can get away with running a test pipe, good for you.
But a high flow cat with (IE - 100 cell count vs. an OEM 500 cell count) will produce a very different exhaust output flow.
Also, the difference between having a cat and no cat in practicality is only 1-3 bhp increase. Anyone can argue, that itself is pointless.
