Hydrocarbons Rule
Argray Single Tip Issue
I have a 2006 N/A Exige and installed the Argray single tip exhaust earlier this week. Everything else engine wise is stock. When I shift from 1st -2nd -3rd gears at light to medium throttle I get a nice pop. I noticed tonight there is a nice flash behind the car when it does this so it's definitely a small fire ball. It's kind of cool, but not all the time, especially when the PoPo is around. I'm sure it's over fueling during decel fuel cut. Is this common with the Argray and less back pressure on the engine or do I have anouther issue I need to look in to. The car also feels like it goes kind of flat on power from around 5k-6200rpm cam change over then it takes off again. It did this with the stock exhaust as well in fact it was a little worse and some times is actually stuttered like it was going way rich. I have no Cells. The first thing I checked was the air filter and it looks pretty clean and unrestricted. The car only has 7,000 km's on it. I have a scan tool on the way, but not sure this will help me much since there are no cells and I'm not sure how much data it will allow me to see and log. Also would like to note that actual engine braking decel is pretty smooth and I'm not getting the lean burn popping that others decribe.
So, the question is. Is this normal, a common problem or is there something simple wrong that won't throw up a cell. PS. I've built many engines and have LOTS of tuning experience with Power FC datalogit, Motec and Microtec. I also have many certifications with ASE. So feel free to get as technical as you want. Last edited by Dragon : 10-27-2007 at 11:37 AM. |
Jobu no like curveball
the dip in power you feel from 5-6.2k is probably from the dip in torque in that range. There's a loss in torque before you hit the 2nd cam. So I'd say that's normal. I'm surprised you're getting fire bursts from your exhaust with a stock cat. I've got a 2bular straight pipe exhaust with a stock cat and I haven't gotten any. Just a lot of popping, burbling, etc. oh, this is on an Exige S, btw. Everytime I see a popo, I either drop it in neutral or take it up to higher gears and just go easy on the throttle.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 '08 Acura TSX 6-speed support WTC 2! |
#4 (permalink) | |
Hydrocarbons Rule
Thanks... |
Remove the cat.
Guess only a few of us notice how restricted the car feels with the cat fitted. N/A and 's'. remove it.....
i'll give you the information if you stop hitting me...
#7 (permalink) | |
Hydrocarbons Rule
Are there any issues running the stock map with out the cat? I don't want to go threw the send the computer out for a retune and wait and then hope it works crap. I also don't want to waste the $ on doing that since I plan on getting a supercharger in the near future. Even then I don't feel comfortable getting the supercharger unless I have the ability to tweak the map for future mods and higher boost. I've also noticed the flywheel in this thing is way too heavy. I'm actually quite disappointed in the performance as far as engine power and response goes. It's not what I expected from all the reviews I'd seen on the car. I'm used to playing with Rx-7's I've built with 400-600hp, so maybe I'm a bit spoiled. I do love the car, its looks and handling, but there is a HUGE improvement to be made in the engine department. I also think that there is still something a little off with it as well. Last edited by Dragon : 10-28-2007 at 03:53 AM. |
#8 (permalink) |
afaik, the stock ecu is encoded, so you can't just plug something in a play around with the parameters. Unless, you get a piggyback ecu.
BTW, decatting will also get you a CEL. The motor is entirely stock 2zz that you find in a celica gts. all of it except for the ECU.
#9 (permalink) |
Hydrocarbons Rule
http://www.apexi-usa.com/product_ele...=260&pageNum=1
Hrm.. has anyone played around with running something like this on the lotus to control the cam change over point and adjust fuel like the honda's do? |
