No Livestock on Track!
I'm giving some thought to turning my Elise into a track-only toy and not driving it on the street. If I go that route, I'd strip out some weight and would make some other changes appropriate for its more-focused track-only role. One option would be to remove the catalytic converter. My only concern about removing the cat is that I'd prefer not to have the CEL illuminated all the time in the event that non-cat related error codes are thrown.
Does anyone know whether there are any electronic gizmo's made for the 2ZZ motor that will fool the ECU into not throwing a CEL? I know that such devices are made for other motors, but I've not heard of one for our car. Any thoughts/suggestions? Does anyone make a straight-pipe that'll mate to the stock header/exhaust? Thanks for your help, Twin
2005 Graphite Gray with Black Interior, Sports Package, Touring Package, Hard Top, Starshield, 6-point Schroth Harness, Fire Extinguisher, and Wiring Loom for DL-1. Otherwise bone stock -- and staying that way -- okay, okay, that's true if you ignore the Braille battery, Micro mirror, Multivex mirrors, ROTA slipstreams, RA-1s, two-piece rotors, springs, polyurethane ASB bushings, RTD brace, Sparco seat, and all the stuff I've taken out of the car... |
I <3 chicken, I <3 liver
2bular makes a decat for the stock header. You could have the CEL prevented from displaying, but you'll have to have your ECU reprogrammed.
I drank what?!?
Mil mod.
Or you can get Charlie's tune. De-cat pipe: http://sector111.com/products/perfor...e-cat_pipe.cfm |
Okay, so the straightpipe is available from a known vendor, but when I read through the Mil Mod thread, it wasn't clear to me if this solution actually works, long term. Has anyone done it, tracked their car regularly, and never seen a check engine light come on?
Thanks Shay3nak and Icedog! Twin
#5 (permalink) | |
"I'M OLD GREG"
After some research I will be trying this Mil mod. I figure for the $5 investment and availability I will try it.
Chris Quote:
Ardent Red, stripes, LSS, Hard top, Touring, Star shield. Mods:re-located Braile battery,2bular exhaust,larini decat,FF splitter,SS brake lines, motor mount bushings, ACT clutch, Toda flywheel, Quaife LSD, Stereo delete, Tilting rear clam, Aero catch engine cover, Alcantara dash, Turboxs intake, Ported stock header and throttle body,2 piece rotors,Pagid pads, Delivered 12/04/04 #742 Auto Europe |
#6 (permalink) | |
I drank what?!?
#7 (permalink) |
I was in your shoes a few years ago Twin, and it's still not really clear what the best solution is- However, I can offer that I drove my car for about a year with a racing header (no cat) and never once had a CEL- The workaround actually came with the header, and adapted the downstream sensor at 90 degrees and out of the direct exhaust flow- This is very simular to the plug defouler mod you probably ran across in your research- I suspect the 90 degree adapter that comes with the Exigemotorwerks header is simply for clearance, and that the plug defouler solution works just as well- Good luck!
Grab Life by the Wheel |
#8 (permalink) |
Form and Function
I had Charlie tune me
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#9 (permalink) |
that's what i'm going to do. Decat + 6" GT3 go on tomorrow!
#10 (permalink) |
I have to admit to being biased against using after-market ECU flashes -- I'm not willing to sacrifice longevity for a few HP, and I once spent a fortune trying to dial in an aftermarket ECU for a trackcar I once had -- but I'd be curious to learn more about Charlie's "tune". Any feedback? Phantom, what racing header did you buy and what's downstream of it? Thanks, all. I appreciate the help.
#11 (permalink) | |
Form and Function
Awesome combo....Ara, you will love it!!!
I have decat + 8" GT3 - I wish it were a tad louder.... Quote:
I have BWR s/c which he originally tuned, and then added a few things (decat, 2bular exhaust, cup box), and I am dyno'g at 227 whp. Cam changeover at around 5000 rpm.
#12 (permalink) |
I drank what?!?
I had no problems with Charlie's tune. The lowering of the cam changeover was worth it in itself. The power's not night-and-day, obviously, but every little bit helps. No CEL is the cherry on top.
#13 (permalink) |
Is the "Charlie tune" the result of work done by "CharlieX" on this forum? If so, I might PM him to see what he has to say. Thanks.
#15 (permalink) |
I've driven around for 60 miles or so and only had the CEL come on once. 0420. Then I just clear it. It's not like it comes on and stays on ALL the time. (I thought that)
#16 (permalink) |
General Freakin' Lee. :(
I ran the anti-fouler solution for years on my old subaru. Never had a problem. I will do the same thing on the lotus if I ever pull the cat.
-Matt 05 Chrome Orange. Touring, LSS wheels, The Blue Sector111 radiator of doom, Dieselgeek 1/4 turn kit, 1/4din Oil Temp gauge, Starshield, LETSLA, HKS exhaust etc etc etc. 99 Neon ACR. Broken. 2.4l, T3/T4, T850 swap, SRT seats, etc etc etc. |
