#41 (permalink) |
Alarmed & Dangerous
I have at least 1/2" clearance by cutting the bottom of the tube at angle, grinding down the clamp and angling the trumpet at shown in the photo.
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 05-31-2007 at 12:14 PM. |
#42 (permalink) | |
I <3 chicken, I <3 liver
TB = Throttle Body Thank you much for posting. I'll try it again this weekend. Your sound improvement assessment makes me want to leave work and try to install the filter. You had bird feathers in your filter?? Didn't a sparrow or robin fly into the path of your car which ended up in your cabin?
#43 (permalink) | |||
![]() Quote:
#44 (permalink) | |
#45 (permalink) |
I'd just like to say thank you for creating this thread. I undertook an oil change, transmission gear oil change, air filter change, and snorkel delete this afternoon. The air filter part was by far the hardest part.
I'd probably still be out there in the garage on the first part without the photos and help of EliseTalk and its members. Thank you. |
#46 (permalink) | |
AR #1275
I probably would not have purchased the Elise if I could not do the basic maintenance on the car myself. Glad to see someone else doing the same work at their home.
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace Thank you FVMC! ![]() WOO-HOO!
#47 (permalink) |
well finally installed the green filter yesterday. Took about 1 hour this time...thank god. Was totally worth it though.
![]() 1) remove sensor on top of airbox. 2) loosen clamps on coupler from airbox to TB. 3) remove coupler. 4) jack the car 5) remove wheel & wheel liner 3) remove stock filter. 4) install green filter (align the back of the box, this part took a while...maybe 10-20 minutes? closing the box with the clamps was a tough since the rubber gasket is thicker and doesn't compress at all. 5) install wheel liner & wheel 6) lower car 7) install coupler and tighten clamps (this part was tough since the coupler is really not that flexible and the TB side as an upward angle. You've got to try to get the bottom to go on first. Sounds hard, but I had to poke my finger down there to try to roll the end out to sit over the TB. Also be mindful of the clamp on the airbox side. You have to have the clamp screw either straight up or facing the rear at a slight angle. You've got to leave room for the sensor you need to reinstall onto the airbox. 8) reinstall sensor. 9) DONE! go out a drive! The car feels a little better. Every time I get on the gas, I hear the PSSSHH sound and the SC whines much louder. Now i can hear the SC over my loud ass exhaust! I am in heaven. It feels a little stronger and maybe revs a little quicker. I went over to a buddies house and before they saw me the could have sworn that a sport bike was coming up the hill! LOL. Not only by the sound of the car, but how quickly it revved. Well, my exhaust note has changed a little. I'd say more so like a bike than it was before. All in all, I'm pretty happy. Next I guess is the FF race header, if we can get that group buy going.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 EXIGE S ** MY CAR ** VIDEOS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com Last edited by shay2nak : 06-11-2007 at 02:41 PM. |
#49 (permalink) | |
GR8 SCAPE
The K&N Air Filter Part Number is: 332252 I got mine at Advance Auto Parts. They were having a 25% Off sale on all filters, so I got it for $40.00 It was very easy to install and you can definitely hear a difference as compared to the OEM filter. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
#50 (permalink) | |
I concur with shay2nak. I tried to install the Green filter from the side without success. So after reading this thread I tried to take out the box from above. IT IS NOT POSSIBLE!!!. There is a fastener inside the air box that needs to be removed and there is not enough room to get the box out through the top. However, having taken off the sensor (2 screws on the top) and removed the rubber pipe to the throttlebody there is enough movement to enable the box to be closed without any force. It does help to have ones wife hold the inner hinges in place while you close the clips below.
05 Elise SS (1)39 Action Craft Coastline 18 - Flyfishing Autocrossing wife - priceless |
#51 (permalink) | |
Also, mine is on an Exige S. Having the IC pipe in the way complicates things a little.
#52 (permalink) |
Rollin' On Gold!
Ara, I should have called you to do the installation with you like I said I would. LoL. I tried doing the installation myself yesterday, and after 25 minutes of trying to close the thing, I just went back to watch TV and plan on trying again today after work. Too bad I don't have another set of hands to help me.
__________________ 2006 Lotus Elise AW |
#53 (permalink) | |
Did you remove the coupler from the airbox to the TB? Once you get the back end lined up the box should keep itself shut. The only reason I had another person help me was to keep the box closed just in case it came apart. You could just pre-cut a strip of tape and once you close the box attach it until you can latch the box closed.
#54 (permalink) |
Thought I'd share my experience
I'm a complete novice when it comes to cars. On this car I've adjusted the headlights, changed the oil, and changed the pedal height (I have an '05, not a DBW). This was by far the most frustrating thing I've done on this car yet. First, the K&N air filter listed for the Toyota engine is wrong. So that was awesome when I had to go back to the store. Second, I apparently don't know how to use jack stands. Can you put a stand next to the jack even though it's not right on the jack point as listed in the manual? Anyway, once I got the correct filter, I spent at least 30 min. trying to get that damn snorkel off. Of course it was 95 degrees that day and I was doing this outside (not enought light in my garage). I did get it off eventually, pulled my old air filter out (ridiculously filthy). Sans snorkle, it sounds waaaay better. The K&N slid in easy enough, but closing that damn box was ridiculous. I spent 2 hrs trying, and failed. My wife came home and helped (second set of hands approach as suggested), but that didn't help. Finally, by the grace of god, buddah, whatever, I just happend to get the correct angle and it popped together with no gaps. I just about lost my mind in the process, though. Worth saving the $ going to the dealer? In straight $ to $ terms, yes, but if my time is worth anything more than $8 hour, it wasn't. Maybe next time it'll be easier. I doubt it, though.
Racing Green, Touring w/ Biscuit. |
#56 (permalink) |
I just removed the snorkel last night and I have argray twin mufflers on my car. The exhaust drones more than before. While I was driving, I heard some flapping sound coming from air box. I don't consider it sounds better though. It seems odd that most of people love it. Did I do something wrong??
BTW, I did feel the throttle response is much quicker and crsipy. It may not have any hp gain, but it does feel faster. |
#57 (permalink) |
Trust in God
I just spent two hours trying to fit the K&N into the stock air box. I finally gave up and put the stock filter in. I couldn’t seem to get both sides of the box connected at the same time. I could either get the hinges attached of the C clamps but not both. Maybe there just isn’t enough room to work with it on the S. I am very frustrated and I am not going to try and tackle it for a while.
07 Exige S (Chili Red) 05 Legacy GT Ltd 98 Esprit V8 (sold) 02 WRX (sold) |
#58 (permalink) | |
#60 (permalink) | |
Took me long enough
up side down
Make sure the filter was in the right orientation. I seem to remember the writing being up-side-down when installed correctly.
-Andy Quote:
'05 CO, touring, sport, starshield, hard top, HID, Quicksilver '05 Mini Cooper S Cab '08 Fusion company car '06 Odyssey family hauler Gone: 97 Viper GTS, 93 Viper RT/10, 97 Neon ACR, 91 Miata, 69 Firebird, |
