#61 (permalink) | |
You now have a filter that actually filters better, is cheaper to replace, and fits properly. ![]()
#62 (permalink) | |
Trust in God
07 Exige S (Chili Red) 05 Legacy GT Ltd 98 Esprit V8 (sold) 02 WRX (sold) |
#63 (permalink) | |
The solution is a 45 Degree Silicone coupler ....
07 Lotus Exige S , Solar Yellow, Touring Pack, Traction Control, Lotus Stage 2 Exhaust, KandN Air Filter, Velocity funnel intake, JVC KDNX5000 DVD+GPS, Compact Sub Kenwood KSC-SW1, Tinted windows, Lotus Sport windshield and front plate decal,HID Kit 6000K,Parking Light,license plate Led conversion. Next mods :Gotham 265 Flash ... http://nofear99.monchar.com |
#64 (permalink) |
Replacing the air filter is a PITA. I miss my old Chevy with the wingnut clamped circular filter.
Like someone self mentioned, the worst part was getting the box to line up and then get the clamps on. I used a big pair of channel locks to do it after making sure the box was lined up. I appreciate the thread a great deal.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs. ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com |
#65 (permalink) |
Snorkel fastener lost
I pulled the snorkel off to make it easier to change the filter. When I went to install the plastic screw at the top of the snorkel assembly, it would not thread back in. The screw just fell into the hole. I got a look at the hole and there is no fastener for the screw to screw into....just a hole. Either the fastener fell into the air box when I took the screw out or it was one of those expandable fasteners that fits into the hole before the screw (like the ones that hold the wheel well liner in place) and somehow I lost it when I removed the screw.
Anybody know what the hell holds the screw in place????? Thanks, 2006 Elise Sport #46 |
#67 (permalink) | |
perfututum futūtor
#68 (permalink) |
perfututum futūtor
The base looks like this (but has a screw instead of this push type):
![]() You can look in the air box but it couldn't fall through the hole on top that holds the snorkel on. The fastener is too big. I'd look all around the floor before popping the air box open again.
#70 (permalink) | |
User Restricted By ΑDMIΝ
![]() ![]() ![]() OK... ![]() It's much harder to get the airbox to close on the "S", especially without anyone to help. I had to take the supercharger to intercooler pipe off, just to <b>see</b> the inner hinge... then with one arm in the engine bay, and one up through the wheel well, align the inner hinge and close the box. I've used up enough four letter words for a month. That said, I'm glad I changed the filter: 10,000 miles and very dirty...
#71 (permalink) |
I <3 chicken, I <3 liver
which still amazes me how Ritchie was able to take my old green filter out and put the new one in all within 5-10 seconds!
all he did was remove the wheel liner, swap out the filters and close the box. And it closed properly...
#72 (permalink) | |
did it once, and never could do it again.. ![]() |
#73 (permalink) | |
![]() He must be a freakin' Lotus magician!
#74 (permalink) |
K&N air filter sealing surface leaks?
Tim,
If you are saying that the stock filter does a better job than the K & N, I might have to agree with you. I have run two K&N's for a total of about 6000 miles. During that time, two Blackstone oil samples checks produced Silicon levels in the oil of about 30 PPM. The universal average is 9. Blackstone indicates the oil I use typically has about 12 PPM of Silicon so if I subtract that from 30, I get a true sample of 18. This is twice the universal average. Silicon can come from a number of sources, but a common one is dirt in the air. I looked at the K&N filters carefully and noticed that in some areas, the engine side of the rubber sealing surface has fine sand-like particles attached to it. These particles also show up slightly beyond the sealing surface on the engine side of the filter. Though I can't say for sure, it gives the appearance that the relatively incompressible rubber sealing surface does not contact the mating air box surface 100%. In other words, it looks like a leak. The stock filter is soft and compressible at the sealing surface and might do a better job of preventing leaks. I just switched back to the stock filter. Any thoughts from other K&N users? 2006 Elise Sport #46 |
#75 (permalink) |
Any interest in re-running your test to see the result after switching back to a stock filter?
Click links to see my 2008 Lotus Exige-S 240 , '99 M3, 505rwhp '89 Mustang (
sold) , '05 WRX STI ( sold) homepages or here for my M3 vid (11MB) |
#76 (permalink) |
Why do you need to remove the wheel liner? I just reached in from the top of the engine bay, unhooked the 2 clips, swapped filters, lined up the 2 airbox halves properly, and snapped the 2 clips back on. Viola! Sounds awesome on 2nd cam!
'07 CO Exige S TrkPk/TourPk/TrkContrl/Star - Braille 13.1lb batt, 2bular 8x24, Green filter, desnorkle, Gotham, shifter mods, Moroso oil pan, Pagid RS 4-2, fettled '91 NSX Blk/Blk many suspension mods,headers,exhaust(SOLD) '01 Integra GSR Blk/Blk Comptech header, intake, & rear tie/sway bar '04 CBR 600 F4i Red/Blk '01 Honda Rebel 250 - 80mpg! |
#77 (permalink) |
Finally got to experience the "joy" of changing the airfilter last Saturday. Spent about 20 minutes trying to get the airbox to close
Then all of a sudden...tadahh!!! Still don't have clue what I did different.
Never trade the thrill of living for the mere safety of existence. |
#78 (permalink) |
AR #1275
i just cleaned my air filter out and closed it, again, in just a few seconds...not meaning to rub it in but really, its quite easy.
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace Thank you FVMC! ![]() WOO-HOO!
#80 (permalink) |
Resident Drunk
Isn't this improper jack stand placement?
![]() Is there a place to put a jack stand in the rear without removing the aluminum panel?
2005 BADA55 Lotus Elise ![]() 1993 Black BMW 325i 2000 Solar Yellow MR-S - SOLD 1987 White on White Porsche 944 Turbo - SOLD 1993 Maroon Lexus SC400 - SOLD |
