Old 04-19-2009, 07:46 PM   #81 (permalink)
NOT ßANNED!
Demonized's Avatar
Originally Posted by zygotesoup View Post
Is there a place to put a jack stand in the rear without removing the aluminum panel?
No.
Old 04-19-2009, 07:56 PM   #82 (permalink)
Resident Drunk
zygotesoup's Avatar
Originally Posted by Demonized View Post
No.
now i understand why those 1/4 turn screw sets are so popular
2005 BADA55 Lotus Elise
1993 Black BMW 325i
2000 Solar Yellow MR-S - SOLD
1987 White on White Porsche 944 Turbo - SOLD
1993 Maroon Lexus SC400 - SOLD
zygotesoup is offline   Reply With Quote
Old 04-19-2009, 08:00 PM   #83 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
+1,000
With a 1/4 turn kit, I can take off the diffuser in about 2 minutes while the car is sitting on it's wheels... priceless mod!
Old 04-19-2009, 08:02 PM   #84 (permalink)
Resident Drunk
zygotesoup's Avatar
Originally Posted by apk919 View Post
+1,000
are these still available? when i took the access panel off for the first time with my ratchet i thought my arm was going to fall off
1993 Black BMW 325i
Old 04-19-2009, 08:07 PM   #85 (permalink)
apk919's Avatar
Images: 20
Good question... I got mine from <a href=http://www.lotustalk.com/forums/member.php?u=8336>alexandertg4</a> through this thread: FS: 1/4 Turn screws for undertray and diffuser
Old 06-26-2009, 10:41 AM   #86 (permalink)
British by extrapolation
Mr. Know's Avatar
Images: 6
I just changed my filter to the K&N yesterday (including snorkel delete) and closing the box was a pita...until I looked at the first pic in this thread. Knowing that the tabs on the fixed (inlet side) of the airbox need to be on the outside of the movable (engine side) of the airbox made all the difference. Using excessive force (the clamps should slip right on even with the K&N) means something is not lined up correctly...and the engine side of the box is probably not in position (needs to move toward the passenger side more). I did mine solo, but I did have to reach into the engine bay from the top and bottom at the same time to get the alignment correct.
Sooo....if you used excessive force to close the airbox, I can almost guarantee the box is not actually closed correctly, and if you were to check the tabs, the movable section of the airbox is probably sitting on top of them and you probably have a leak. Thanks goelise for your pic in post #8, that made all the difference for me.
07 Magnetic Blue Exige S
Join the Blue Lotus Team on Facebook.
Mr. Know is offline   Reply With Quote
Old 06-26-2009, 10:51 AM   #87 (permalink)
avonnieda's Avatar
+1
I had my wheel back on before I realized that I hadn't lined it up correctly. Oh well, I can do it really fast now
I held onto the box in the engine compartment with my right hand, and clipped the tabs with my left. The tabs slid right on when it was lined up correctly.
2005 Saffron Yellow Elise, desnorkeled - Hey, it's a start..
1997 Ducati 748
avonnieda is offline   Reply With Quote
Old 06-29-2009, 01:41 PM   #88 (permalink)
xxxotic's Avatar
Do you have to remove any electrical or vacuum connections?
I got the old filter out, slid a new one in, but now the outer box is about an inch off to the right and I can only move it about 1/2 an inch in the direction I need it to go to line up the tabs.
xxxotic is offline   Reply With Quote
Old 06-29-2009, 01:49 PM   #89 (permalink)
GR8 SCAPE
waydui's Avatar
No, you don't have to remove any of the connections (hose or electrical) to replace the filter.
If you're putting in a K&N filter make sure you have the curved corner of the filter in the proper place (bottom left hand corner of the box) or you'll never get the airbox closed.
When properly aligned, it actually closes fairly easily. YMMV.
Regards,
Wayne
_______________________
Old 06-30-2009, 10:08 AM   #90 (permalink)
xxxotic's Avatar
I will try it again tonight and see if I can get it.
Are there are only two clips on the left side, and then it fits into the grooves on the right hand side
I didnt see any clips on the right side.
I just seems like the outer box doesnt want to move that easily.
Maybe it was because it was 100 degrees inside my garage when I tried it this weekend and I was getting heat exhaustion!
Old 06-30-2009, 10:18 AM   #91 (permalink)
apk919's Avatar
Images: 20
You're right, there are no clips on the right side, but there are two "hinges", i.e. interlocking plastic pieces that allow to two halves to pivot from the right side. If both hinges are correctly positioned (and the filter is seated correctly), the box closes fairly easily. Otherwise, it seems like an impossibility...
Old 06-30-2009, 08:55 PM   #92 (permalink)
AR #1275
goelise's Avatar
Images: 1
Find a electric screwdriver that is short enough to fit easily underneath(found mine at target, black and decker for < $10, uses 4 rechargeable AA batteries in the handle) with a 1/4" socket adapter and 8mm short 6 point socket makes it VERY easy to get those bolts off and 99% of the way back on. When reinstalling I get it close to all the way on and then manually use a short handle ratchet to get it 'snug' on there. Its actually fun to get those bolts off using this method.
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace
Thank you FVMC! WOO-HOO!
goelise is offline   Reply With Quote
Old 06-30-2009, 08:57 PM   #93 (permalink)
AR #1275
goelise's Avatar
Images: 1
Glad to help a fellow Lotus owner!
Old 06-30-2009, 11:25 PM   #94 (permalink)
perfututum futūtor
RoadDad's Avatar
You could also buy one of theviper's 90 degree drill attachment thingies. Under Tray Removal Tool
Me... I don't need to.
Bite me." -Randy
Old 07-01-2009, 06:58 AM   #95 (permalink)
xxxotic's Avatar
Finally got it back on. Had a neighbor come over and push it on the bottom while I pushed it on the top and it lined up.
Noticed that the snorkel wasnt fitting into the opening on the box so I fixed that too.
Old 08-23-2009, 11:04 AM   #96 (permalink)
One thing to realize that helped me out was to understand that the part of the airbox that is toward the front of the car (cover?) and connects to the snorkel is attached toward the front of the car and hard to move easily. I found it easier to move the intake part that is connected to the engine to line up to the cover than trying it the other way. Once the side in the engine bay is lined up it went together easily. Also make sure the top metal clip (in wheel well) is out of the way when bringing the two sides together. That top clip kept getting in the way for me. I am now de-snorkeled and was AMAZED at how much crap was in my filter. Small gravel and leaves fell out of the box when I opened it and pulled out the filter. Filter replaced.
apxfndr is offline   Reply With Quote
Old 09-23-2009, 02:49 PM   #97 (permalink)
Hiya guys,
I have ordered a 33-2252 K&N Filter for my 06 Exige S.
What are peoples experiances so far?
I have a performance exhaust and can hardly hear the supercharger now, I am hoping for some improved breathing and possible supercharger whine improvement.
Also I took the snorkel off with the standard filter, after a few drives I am not sure its made any noise improvement really.
So if you have the K&N with the snorkel still on, hows the sound?
Thanks in advance.
.:: Lotus Exige S - Chili Red ::.. | ..:: Audi A3 S-Line TDI 170 - Brilliant Black ::..
Feel free to msn me - dale_pearson@hotmail.com (MSN Only)
dalepearson is offline   Reply With Quote
Old 09-23-2009, 05:44 PM   #98 (permalink)
choi0706's Avatar
you need to get a cupairbox..
PM me if you want one, its a great addition..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 09-24-2009, 12:00 AM   #99 (permalink)
Thanks but not looking for a cup box right now, already ordered the K&N, and I think postage would be abit much to the UK
Old 09-24-2009, 06:55 AM   #100 (permalink)
BBeauty
RWLott's Avatar
replacing the filter
I tried to get the air box to close for a good 45 minutes, then I got my wife to help. She held the top together, while I pulled the bottom together. With a little wiggling the air box closed easily. Using two sets of hands made it much easier. Try getting someone to help next time.[/quote]
Ditto!
It was a no brainer and a ton easier having my wife help. I'll never try to do it myself again! My arms are not long enough.
RWLott is offline   Reply With Quote
