Old 09-05-2005, 08:26 AM   #21 (permalink)
Jack's Avatar
Autoxray Easy Scan 5000-- got it at Kragens. Info can be downloaded to your computer with the included PC interface cable.
I had a chance to play with the Lotus Scan tool for a weekend. This will do all the same stuff, except you can't access and activate certain proprietary Elise functions, like cycling the ABS system or turning on the fans, etc.
Jack
'07 Exige Cup 255
'08 2-Eleven
Old 09-05-2005, 09:52 AM   #22 (permalink)
not a Mod, just an Admin
CALtd's Avatar
IIRC the ODB II will reset the CEL but not reset the ECU. When I installed the ITG I also disconnected the battery for >10 min to expedite the ECU re-learning process. Then I did the step recommended from someone in the UK to let the car idle for ~10 minutes (till get the fans to come on) to initialize the ECU.
CALtd is offline   Reply With Quote
Old 09-19-2005, 08:54 AM   #23 (permalink)
arandolph's Avatar
Originally Posted by 2sporty
So I just filled up on a new tank of gas and that didn't fix it. I plan to talk to the people at sector111 and seeing if they have any suggestions on how to fix it. If it can't be fixed, i'll probably go back to stock. The rough idle is getting to me.
Did you ever get your MAF problem figured out? I had no problem in the first 600 miles after installing my ITG system, but yesterday, poof, on goes the MAF light. I am several hours from the nearest dealer and hopeful that you found a solution to try.
arandolph is offline   Reply With Quote
