Old 04-27-2006, 07:51 PM   #1 (permalink)
choi0706's Avatar
Different mil mod
so my buddy made one for me.. same as what charlie said should work.. putting it on this weekend..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 04-27-2006, 10:07 PM   #2 (permalink)
Club a baby seal today!
hatchy's Avatar
What's the theory of operation?
hatchy is offline   Reply With Quote
Old 04-27-2006, 10:11 PM   #3 (permalink)
OSX Black hat
charliex's Avatar
matches the square wave of the o2 sensor
Old 04-27-2006, 10:23 PM   #4 (permalink)
choi0706's Avatar
if this works, and it should my buddy might make a few if anyone wants..
Rally Ready
Old 04-28-2006, 01:26 PM   #5 (permalink)
Phantom's Avatar
Images: 1
This would be a huge breakthrough in my opinion- I have a new Elise with Arqray dual muffler- When I learned Sector111 is out of the decat tubes, I cancelled my order for one- I have been concerned about the o2 sensor issue (new car, warranty, check engine light, etc.), and with Sector111 not having stock, I'm going to see what happens with this issue- Please keep us posted- Thanx
Grab Life by the Wheel
Phantom is online now   Reply With Quote
Old 04-28-2006, 01:35 PM   #6 (permalink)
choi0706's Avatar
no problem! I hope this is the fix everybody is hoping for..
Rally Ready
Old 04-28-2006, 02:51 PM   #7 (permalink)
hatchy's Avatar
Charliex, does this sit in between the rear sensor and the ECU, or does it replace the sensor? Do you know if this works with any other cars? I've had a hell of a time with my Suby...
Old 04-29-2006, 10:57 PM   #8 (permalink)
choi0706's Avatar
okay guys.. So far it works.. Put on 60 miles today and it runs good!.. I need to work out the wiring because I tapped the ecu for the ACC power.. Not very efficient but it works.. I will post pictures on sunday night.. Be ready to see something you've never seen on a elise..
Rally Ready
Old 04-29-2006, 11:00 PM   #9 (permalink)
choi0706's Avatar
one more thing.. With this mil mod, i dont even have to plug in the second o2 sensor.. Probably i can just do away with it completly..
Rally Ready
Old 04-30-2006, 12:56 AM   #10 (permalink)
OSX Black hat
charliex's Avatar
hatchy, there maybe a scooby version on the website i linked, it will replace the sensor, you might need a resistor mod as well for some cars.
glad to hear its working so far.
as for doing away with the second O2, stick an LM1 wideband in there instead
i've got another one that lets you change the mixture of the first o2 sensor too
Old 04-30-2006, 09:36 PM   #11 (permalink)
choi0706's Avatar
http://www.elisetalk.com/forums/showthread.php?t=22570
Rally Ready
Old 05-02-2006, 06:01 PM   #12 (permalink)
hatchy's Avatar
I picked up the parts at the local electronics store today, I'll see if I have time to put it together this weekend. Did you build yours based on this: http://www.mkiv.com/techarticles/oxy...sor_simulator/ or did you change some of the resistor values? thanks
Old 05-02-2006, 08:21 PM   #13 (permalink)
choi0706's Avatar
pretty much stayed the same.. if mine works, these will be made available for everyone.. my friend needs gas money..
Rally Ready
Old 05-02-2006, 09:47 PM   #14 (permalink)
OSX Black hat
charliex's Avatar
which pn 555 is he using
Old 05-03-2006, 06:33 AM   #15 (permalink)
choi0706's Avatar
no idea...^
Rally Ready
Old 05-03-2006, 06:41 AM   #16 (permalink)
What's a registered user?
Žob's Avatar
Almost all 555s are the same. Ratshack should carry them
Žob is offline   Reply With Quote
Old 05-14-2006, 06:16 PM   #17 (permalink)
choi0706's Avatar
so far all is good.. almost 300 miles no light yet..
Rally Ready
Old 05-14-2006, 07:18 PM   #18 (permalink)
eliseowner2b's Avatar
Any idea how many tanks of gas one of these is going to cost?
Dan Parker
92 BMW 325 - JP Race Car
09 Jetta Tdi
06 Z4 M Coupe
09 Child on the way (anyone need a car?)
eliseowner2b is offline   Reply With Quote
Old 05-14-2006, 07:33 PM   #19 (permalink)
OSX Black hat
charliex's Avatar
similar in operation, but temperatures vary as well as operating paramaters, enough to have to redesign the circuit, i'm curious about the exhaust temp and it helps to have to exact modem he's verified works.
they are from radio shack.
they cost around $10-$20 in parts
Old 05-14-2006, 08:04 PM   #20 (permalink)
kverges's Avatar
I think the theory of operation of these devices is as follows. First, the primary or upstream O2 sensor dithers back and forth between about 0.5 and 0.9 volts, as the engine goes lean and rich relative to stoichiometric 14.7:1. A traditional O2 sensor is very sensitive around 14.7:1, but also very nonlinear. So it makes a very square-wave like signal. I also think the ECU deliberatly richens and leans the mixture as part of the feedback system to make the signal dither.
The catalytic converter oxidizes the excess hydrocarbons that are introduced when even slightly rich. The downstream O2 sensor measures a slight rich/lean transition, too, but it is at a different phase and frequency than the upstream signal, since the cat affects the oxygen content as it does its job. Earlier O2 sims could simply make a signal that oscillated between about 0.5-0.9V at a fixed frequency and that was good enough. Many more modern ECUs (and the Lotus ECU may be one) look not only for an oscillating signal, but for a difference from the primary O2, as the difference is an indication of the function and health of the catalytic converter. I have not recearched Federal requirements, but it may be necessary for more modern ECUs to monitor cat health.
What I do not know is the expected phase and/or frequency difference between the primary and secondary O2 sensor signals - this may also vary from car to car.
So that's about all I know. What I can't tell is whether this circuit makes a fixed signal or integrates the primary O2 sensor signal to make a variable signal of if it is even necessary. I have never built a sim either, just bought 'em. Kudos to charlie for sorting out the details. I have a commercial O2 sim on my car that works as far as I can tell, but the Lotus O2 ECU is pretty clever and keep an eye on it and plenty of miles to be sure the sim is working.
FWIW, the sims I currently use need an O2 sensor input and the O2 sensor must be in the exhaust flow, so I beleive they alter the O2 sensor signal.
kverges is offline   Reply With Quote
