#21 (permalink) |
OSX Black hat
this sim doesn't need the original o2 sensor, it generates the signal completely.
narrow band O2 sensors are fairly easy to replicate, wide band on the other hand not so much, the signal of a titania compared to a zirconium is quite different not just amplitude but direction, luckily we don't have to deal with that. it'll switch lean/rich in closed loop the ecu is looking for both the voltage and the frequency its switching at, the ECU has a preset frequency to cycle the engine so it knows exactly what to look for. the circuit can be adjusted for just about any car, different types of injection, carbs etc will generate a different frequency. As far as i know its not an actual comparison between the two O2 sensors, as it is a base test against a known quantity in the ECU. the frequency determines the cats performance so i dont think it'd need the upstream O2 sensor to compare too, as the working range is already known. (that is as long as the engine is performing correctly, the upstream O2 sensor may alter the base frequency comparison if its out of spec ), it will compare the upstream to the downstream and when the frequencies gets to close it also throws the code, this may explain why some people get it and some don't, as many factors will determine what that base frequency will be. the OBDII code is thrown when the switching frequency is too high as it then considers the CATs oxygen storage capacity to have detoriated. blergh i'll rewrite this in the morning, i'm not even making sense to myself ![]()
Black Exige S - http://goth.am 265 Mule / Elan M100.ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 West Coast Lotus Meet - Las Vegas - November 6-9 2009 http://www.westcoastlotus.com/ Last edited by charliex : 05-14-2006 at 11:25 PM. |
#22 (permalink) |
OSX Black hat
Its a Texas Instruments NE555P
#24 (permalink) |
going towards 400 miles still no light.. he is looking for another test bug, anyone who is interested shoot me a email choi0706@gmail.com
#25 (permalink) | |
thanks ![]() |
#26 (permalink) |
after testing with an official toyota canbus/obdII diagnosic tool this mil mod works.. the ecu is very happy with the signals it's getting..
on a side note, the toyota tool can read all our sensors/test and view them in real or almost real time.. But it's a $4,000 unit.. |
#27 (permalink) |
OSX Black hat
Good to hear that the circuit is still going strong (for those who want to build their own the circuit diagram is available too )
ddi you try the powertrain settings on the toyota unit ?
#29 (permalink) |
OSX Black hat
the extended diagnostic data, the rest is just standard obd ii
its unlikely its the same, but worth a shot.
#30 (permalink) | |
ohh the lotus data? top speed, top rpms? none of that showed up.. but David did say he can reflash toyota ecus with that tool if toyota made a update.. |
#31 (permalink) |
OSX Black hat
yeah federal modern cars are flashable now, its required by law.
#33 (permalink) |
The Real Slim Shady
my defouler method seems to work pretty good lately. im getting over 600 miles before it turns on. if it turns on. but the last time it came on it also went off by itself.
2005 Lotus Elise Magnetic Blue/Touring/Black (orderd 1/10/04)(Received 10/21/04) #528 QuickSilver exhaust, Larini De-Cat Pipe, custom intake, Xtec HID, Avic-N1, Chase Cam, Polk Speakers f&r My pictures! Elise/Exige Owners Map |
#35 (permalink) | |
#36 (permalink) |
The Real Slim Shady
i got my code reader off of ebay for 50 bucks. easy to use and comes in handy sometimes.
#37 (permalink) |
untitled
I thought charliex had hacked the ECU -- just some of the data maybe? If you can get to the code that check the post-cat sensor and runs the test for catalytic converter efficiency, that's all you need, right (no hardware mod required)? I mean if you are going to do a hack why not go all the way?
The above description of how the ECU compares the signals matches what I've read about the Toyota ECUs. The test is done periodically after everthing is warmed up. It takes something like 15 minutes (maybe 30? can't recall) of driving before it does the test for the first time. I have a Power FC and just plugged the post-cat sensor bung. The Power FC is wired for the post-cat sensor, but does not appear to do anything with it. There's an Innovate Motorsports LC-1 in the pre-cat bung, which has two programmable analog outputs (1 narrowband, 1 wideband) plus a digital serial output that I can read via USB to serial converter. LC-1 is like LM1, but cheaper (no gauge). You can buy the gauge for it later, which is what I did. LC-1 consists of the sensor, electronics, and cables and costs $200. The XD-1 gauge can be mounted anywhere. It is very thin (about 1" thick), so you can stick it on just about anywhere. It comes with velcro to stick it wherever as well as screws etc to mount in the dash. ![]() Note: tach goes to 8K, engine goes to 9300. I have another tach (virtual on tablet PC) that goes to 11K. Even if you can't alter the A/F mixture, it is nice to know what it is. ![]()
It is all about "Other". |
#38 (permalink) | |
#2116 - Aztec Bronze |
