Old 07-03-2008, 03:50 AM   #1 (permalink)
DOES THIS EXIST..
before i start.. i have tried searching the web then i remembered my old muckers here in this forum namely Jim V and such like. Who made me the first2ubular Ultra......hence maybe a quicker way on yes / no / or possibly!
Also please dont take the piZZ at the concept or drawings as i am a specialist in a field far removed from metal, engines and mechanics.
Previously (although with the rear panel elimanted it made it relatively easy) it was a pain to swap between the exhaust systems dependant on what mood i was in - loud, quite or intermediate on the exigeS
so the question being:
does the following concept exist (drawing below) where by you can automatically swap (in the cockpit) between a through pipe (or other loud silenced) to a fully silenced box. Where by a disk can shut or open with a cable type of system and thus alter the path dependant upon where you want the gas flow to exit. either on or off type of situation and not nessesarily variable
I am currently specing the build on a hand built road car for the UK where it will ultimately need to be fitted with the fully silenced system for SVA but would want it as such if i wanted this fitting later it would be a straight swap.
There is loads of room on installation if this is possible.
anybody with any views on this or how this goal could be achieved or if they could make it
The engine is a LS7 v8 505bhp in standard form and will be running CATS
craig7l is offline   Reply With Quote
Old 07-03-2008, 04:03 AM   #2 (permalink)
dmh
dmh's Avatar
...such as a cutout?
How it works: DMH Electric Cutouts are designed to better your cars performance and feel. The cutout works by welding into your stock or modified exhaust. They can be placed anywhere after the headers. To open the cutout you press a switch, which opens cutout, releasing your exhaust. This enables you to bypass your muffler, increasing horsepower
Welcome to DMH Performance!
dmh is offline   Reply With Quote
Old 07-03-2008, 04:18 AM   #3 (permalink)
thats the story of my life inveting something that already exists
so that will fit in the system then as per my fantastic drawing? or similar?
if so then you could well be getting an order.
cheers
i assume it can be added before the CAT and then a through pipe for max LOUD
Old 07-03-2008, 11:39 AM   #4 (permalink)
Fly N Lowr
azskycop's Avatar
I have something very similar on my boat. Chaparral calls it a "Quick or Quiet" exhaust. Flip a switch and exhaust goes out one pipe or another, loud or quiet depending on what you want at the time.
If you're not living on the edge you're taking up too much space!
www.GoodBodyHealth.com
azskycop is online now   Reply With Quote
Old 07-03-2008, 01:57 PM   #5 (permalink)
Smoky's Avatar
I'd be wary of installing a cut-out on the Lotus. The ECU is so finicky, I think it would have trouble going back and forth like that. I bet you'd get CELs and poorer performance in the long run.
Cut outs are for 60's and 70's muscle cars. I've seen some good cut out kits on 4th-gen F-bodies, and newer trucks, etc that work well. But even then it starts to get hairy because of the sensors feeding the ECU a whole different stream of data when the cut out is on vs off.
-Smoky
'07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, S111 Ultra Discs
Smoky is offline   Reply With Quote
Old 07-03-2008, 02:14 PM   #6 (permalink)
It's a Lotus
LARRY's Avatar
More than a few modern sports cars have a switched or automatic switch that opens a valve to allow straight-through exhaust.
2005 Saffron Yellow Elise, Sports & Touring Packages, Hard Top, Stage II Exhaust, '07 Probax leather seats.
LARRY is offline   Reply With Quote
Old 07-03-2008, 02:24 PM   #7 (permalink)
fitfan's Avatar
the old euro 111's had that actuated exhaust .. i have a picture of it somewhere.
Driving it around!
Old 07-03-2008, 02:26 PM   #8 (permalink)
Fly N Lowr
azskycop's Avatar
By the way what car is that in your 1st post?
Looks very nice but I can't tell what it is. Please post more pics and details if that is the one you are talking about having built. Looks like fun!!!
Old 07-03-2008, 02:33 PM   #9 (permalink)
Sydney111s
yes mate, its the XFORCE VAREX muffler. I have the 3" version on my exige S- magic- push the remote- quieter than stock, push remote again... straight through and over 102db with my 200 cell metal cat (have full 3" mandrel pipes).
XForce - Performance Exhaust Systems
watch the VE commodore clip for your application (i actually used the same muffler- just 1 instead of the two used on the v8)
and yes, I previously had a 111s, and it had something similar (but waaaaay to baffled) from the factory. I have put a few thousand kilometers on the VAREX exhaust, and have no CEL/MIL light problems; in fact I think it actually stops the "self-learning" from cutting out the advantages of the straight through exhaust which many have commented on.. best of all the muffler only costs less than USD 400 (actually about AUD 400). I actually got mine on sale and had it fitted for $450... its very well made stainless steel- I really can't believe the mark up on the other "so called" performance exhausts such as quicksilver, larini etc.. (and I actually previous spent 3x as much on a well known muffler, but got sick of the constant drone). The VAREX was cheap and I thought I would give it a go.. could not be happier!
I am working in London at the moment and the car is back in Sydney
Sydney111s is offline   Reply With Quote
Old 07-03-2008, 02:53 PM   #10 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
here's another exhaust cut out system:
QTP - QTEC Electric Cutout
'06 Evo IX Stage 1 Tuned by Road Race Engineering: Stock:turbo,intake,internals,ECU,Walbro 255lph fuel pump,RC Engineering1000cc Injectors,RRE catch can,Espelir downpipe, RRE High Flow Cat, AVO catback, RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is online now   Reply With Quote
Old 07-04-2008, 01:46 AM   #11 (permalink)
its a Aspira SL-C.
Aspira SL-C Available 2008
visiting detroit on 1st August to examine wether this car will make UK sva compliancy.
RicardoGT box, aluminium TIG welded monocoque, 6pot wilwood big brakes, 18" wide wheels, LS7 505bhp in a 950kg car.errrmmmm me thinks....even got aircon, leather interior
should top 200mph i will think
first 22 cars have come off production line as we speak.
Old 07-04-2008, 04:30 AM   #12 (permalink)
Sydney111s
isnt this kind of an ultima?
Old 07-04-2008, 06:29 AM   #13 (permalink)
LEKSAK
swede's Avatar
RR silver ghost had this exhaust feature on the 1927 model. If I recal correctly it was a label on it stating "not for use in GB"
All mechanical obviously.
That RR also had anti lock brakes (vacuum operated some how)
Cool car
_____________________________________________
Touring pack, Hard Top, Star Shield ++, Stage II Exhaust, Sector 111 Rear Tow Hook, Shift-I System, Sector 111 V-Bar, Schroth Profi II 4 pt harness. V1 with remote display in dash. Sector 111 and Stan's shiftmod, Garmin GPS Nuvi 270,,,really want a Supercharger this winter
swede is offline   Reply With Quote
Old 07-04-2008, 07:26 AM   #14 (permalink)
yes exactly... but with enhancements in modern bodywork styling (subjective) and
Alluminium Monoque Vs spaceframe
6pots all around standard vs 4pots standard
apart from that equal / better hopefully in all areas including speed / performance / handling
price comparison is dependant on where in the world you live.
compliance again is dependant as this is only supplied as factory built and not as per ultima also in kity form.
Old 07-05-2008, 02:02 AM   #15 (permalink)
Sydney111s
well craig, if I was you, I'd get the varex muffler as used on the VE commodore (they use the 6.0L LS-2 in these now) so it should work for your needs. Highly recommend the solution for SVA purposes as you will have fully functioning, quiet/stock muffler, then press the button, and nice and racy as per the u-tube video..
Old 07-05-2008, 04:12 AM   #16 (permalink)
gas, gas, gas, gas
choi0706's Avatar
theres already a bolt on exhaust for the 111r.. it uses a vacc operated valve..
Jay-05' ST, HT, Touring Red
I have a theory that all....
Katana flags 8
Red flags aren't fun..............
choi0706 is offline   Reply With Quote
Old 07-05-2008, 01:40 PM   #17 (permalink)
looks impressive.. it would need to be welded inline where a link between CAT and this fabricated. shouldnt be a problem. It needs to meet 101bd and 3/4 revs. which is quite a tall order on a 7000rpm V8
Old 07-05-2008, 02:53 PM   #18 (permalink)
Virginia Beach Car Guy
VBCARGUY's Avatar
Where do you get it?
Triumph Tr4a Race Car 1967 SOLD
1954 CJ 3b Willys
2002 Yukon Denali Daily Driver
2006 Exige. The only man in america to have a exige s then go back to a NA exige
1967 911S 1900lbs 220hp
VBCARGUY is offline   Reply With Quote
HTML code is On
