2009 XP National Champion
![]() Join Date: Oct 2003
Easy Bolt-on HP!!!! From Blackwatch Racing
Folks, it has taken me forever to get around to this, but finally went and did some back to back comparison of the stock car vs. the Blackwatch Racing TB(2005) + Intake. As we've discussed in the past, putting an intake on makes noise but little power as it is going through the stock throttlebody. Its like 2 kinks in the same hose. You're not gonna get the full flow until their both gone.
So I did an A to B comparison between stock and with Airbox and Intake + TB. The results were not surprising, but favorable nonetheless. We picked up max of +10HP and +7lb-ft! Everything else is stock including exhaust. Didn't even port match the intake, which is probably worth a couple more ponies. You could feel the difference as it smooths out the cam transition and pulls harder from 5500rpm up. Finally something for the NA guys as well as FI guys. This throttlebody is not a re-bore with paper thin walls. It is a fully cast part with pressed in bearings, beveled throttle plate, throttle set screw, and 70mm opening. Just pull off the stock TB, swap the sensor, and spring over, IAT control and you're done. It took me about 30 minutes. Regular price is $695, for a limited time, we've got them on sale for $495. Big-Bore Throttle Body for 2005 Elise, Lotus Intake Products - Blackwatch Racing See the dyno below:
sorry to be a spoiler, but won't the Learn Function on on ECU cancel out this increase after a short period...?
This will definitely benefit FI engines more than NA's, because the dyno shows the gains after the high-lift cam engagement. thanks
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
I <3 chicken, I <3 liver
are you guys planning DBW TBs?
#4 (permalink) | |
NOT ßANNED!
However, with the Charlie NA tune, which... (excuse me for possibly making crap up) it might.. not... relearn .. unfavorably??... Been reading so much stuff lately it all seems like someone mashed my brains. Anyway, with the intake manifold i've been hearing about, a new TB, and a header, a custom tune might be time and money well spent, if you wanna stay NA.
yeah, that combo should be pretty badass.
#7 (permalink) |
No, additional airflow is additional airflow. I let the car idle for 10 minutes and drove it some to settle the adaption. The AFRs were very similar.
#8 (permalink) |
What intake was this done in combo with? I personally have no qualms with the stock airbox. esp after reading all the threads about ECU learning curve. And you guys don't list an intake For Sale...so makes me a curious little rabbit
I'd be curious of a 2 wk post dyno...just to settle the minds of some...
2005 Magnetic Blue Elise - "the Lotus" (original I know) 2001 Jeep Wrangler - "soul crusher". If you dont GET it after you drive it, then you dont GET it - serpent Last edited by mrcarcrazy : 03-09-2009 at 08:06 AM. |
#10 (permalink) | |
BavMo, we'll see about an '06.
#13 (permalink) | |
![]() Or setup a intake/TB kit. as there are a few things I want to order from you guys. why not just get them all knocked out in one fatal blow?
2005 Magnetic Blue Elise - "the Lotus" (original I know) 2001 Jeep Wrangler - "soul crusher". If you dont GET it after you drive it, then you dont GET it - serpent |
#14 (permalink) |
TWRD & Blip advertising
![]() Join Date: Jul 2004
Awesome news and results Fred. Can't wait to try it with the Lotus Sport ECU.
Jacob Join Lotuscar.ning.com for LA Lotus social events 05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels |
#15 (permalink) | |
We are working on an intake package also. However as there are many folks with the Fujita, we thought this was relevant as well.
#16 (permalink) |
luxige
Fred, how do you think (guess) this TB would pair up with a Cup airbox?
(Asking in context of a DBW version.)
In theory, there is no difference between Theory and Practice. In practice, there is. - Y. Berra |
#17 (permalink) |
Set up Q
let me add another scenario:
cup air box+katana+NEW Throttle body=?? HP increase
05 Lotus Elise R/K Supercharger, Stage II, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, Cup Air Box, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
#18 (permalink) | |
Its kind of like getting a really thick shake and trying to suck it up through the straw. The narrower the bore of the straw the harder it is. You only have from 14.7psi of suction power maximum i.e. atmospheric pressure to vacuum. However if you blow into the straw it is no problem to blow bubbles in the shake. You can always generate pressures above atmospheric. McDonalds solved this with Big-Bore straws. Their new vanilla shakes are excellent BTW.... So you got a cup car Airbox to open up the first part of the hose.... One more kink to go.
#19 (permalink) | |
Knucklehead, I think you'll like it. It matches your seat. ![]()
#20 (permalink) | |
Q Part Deux
![]() are they still on sale?
