Old 05-10-2009, 11:09 AM   #1 (permalink)
intofx's Avatar
Images: 14
Exhaust gasket
When installing the gasket between the manifold and the cat, is it proper to put it on the manifold or in the cat? The old one was stuck to the manifold but I have heard many stayed inside the cat when it was removed. Any tips to prevent a leak when installing a new one?
TIA,
Matt
2006 Phantom Black Exige
2004 Porsche C4S
2007 Black Hummer H2 SUT
intofx is online now   Reply With Quote
Old 05-10-2009, 03:13 PM   #2 (permalink)
intofx's Avatar
Images: 14
ttt
2004 Porsche C4S
Old 05-10-2009, 07:15 PM   #3 (permalink)
choi0706's Avatar
its a tight fit.. pry off the old one on the manifold.. and push in the new one.. doubtful you'll find a leak because of the gasket.. its more likely to leak because those springloaded bolts aren't tight..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 05-10-2009, 07:17 PM   #4 (permalink)
choi0706's Avatar
stick it on the manifold first..
Rally Ready
Old 05-10-2009, 07:18 PM   #5 (permalink)
Images: 7
How tight should they be? I have the Lotus manual but the exhaust system seems to be totally absent.
Thanks!
lotusland is offline   Reply With Quote
Old 05-14-2009, 07:02 PM   #6 (permalink)
Images: 7
Thanks!
bump...
Old 08-30-2009, 05:38 PM   #7 (permalink)
Images: 7
Thanks!
Bump...does anyone have a spec for how tight the nuts on the flex joint (spring loaded) on the stock exhaust should be?
Old 08-30-2009, 09:32 PM   #8 (permalink)
choi0706's Avatar
32ft lbs..
Rally Ready
Old 08-30-2009, 10:13 PM   #9 (permalink)
32ft lbs..
Is the header 37ft lbs?
vao4v is offline   Reply With Quote
Old 08-30-2009, 11:43 PM   #10 (permalink)
choi0706's Avatar
yes header is 37 ft lbs as well..
Rally Ready
