Old 04-09-2009, 08:55 PM   #1 (permalink)
Help me get the rear panel off my '07!
I'm building my own exhaust and doing some other stuff and need to get the rear panel off. I cannot for the life of me figure out how to get to the top three bolts.
I've seen references to the fact that the three bolt heads are in the trunk, but I don't seem to have them. I have three little stickers in places I expect the bolts to be, but nothing obvious underneath them.
Has anyone taken off the rear panel on an '07? It is one of the cars with the bumperettes.
2007 Ardent Red Elise, track pack, BWR SC
2004 RX-8, 350z muncher
2004 BMW 325i, kiddie hauler
brokenboy is offline   Reply With Quote
Old 04-09-2009, 09:05 PM   #2 (permalink)
A pound at a time.
The 07's do not use the same 3 bolts. When you remove the carpet and padding you will see a metal strip with, if i remember correctly 5 bolts. Remove the 5 bolts and the metal strip which is held on with an adhesive.
Then on the underside remove the heat sheild and you should be able to pull the rear panel down.
Take your time with this I used alot of curse words and it really tested my patience.
Good luck
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser
Sh4rkattk is offline   Reply With Quote
Old 04-09-2009, 09:10 PM   #3 (permalink)
Thanks for the quick response! I was wondering about that strip of metal in the trunk.
I'll start using the thesaurus to look up extra curse words so I have them ready
Old 04-10-2009, 07:17 AM   #4 (permalink)
perfututum futūtor
RoadDad's Avatar
Here are a few links with pictures that may help out. I don't know if you have already seen them or not but just in case.
2007 rear panel removal
Me... I don't need to.
Bite me." -Randy
