Old 09-27-2008, 11:16 PM   #1 (permalink)
'07 Black Exige S
Pestodude's Avatar
Help me set up the best exhaust combo.
I just purchased and am awaiting delivery of a Larini, above the difuser muffler:
Larini Sports Exhaust System - SE Style for the Lotus Elise and Exige - Sector111
I want to set up my entire exhaust system with this install...header, decat, reverie difuser.
Looking for advise as to the best header/ de-cat set up that will match up (physically and performance-wise) with the Larini muffler. I plan to either have Charlie tune to the new set up or get a custom tuned EFI stand alone to get the most out of the system. I guess the Weapon R street header is no longer available. I'm inclined to go towards torque as opposed to HP.
WHAT SHOULD I BUY?????
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness
Last edited by Pestodude : 09-28-2008 at 09:19 AM. Reason: posted a link to Sector 111
Pestodude is offline   Reply With Quote
Old 09-28-2008, 09:34 AM   #2 (permalink)
'07 Black Exige S
Pestodude's Avatar
What is a good header for torque. The PPE is more horsepower, isn't it?
Randy
Old 09-28-2008, 11:07 AM   #3 (permalink)
lotusforsale's Avatar
Images: 8
I always throught there isn't much hp or torque to be gained through the exhaust systems of these cars, that most of the systems were really for sound and looks.
At least, that seems to have been the general consensus here over time.
lotusforsale is offline   Reply With Quote
Old 09-28-2008, 12:27 PM   #4 (permalink)
'07 Black Exige S
Pestodude's Avatar
I think the consensus is that if you get headers, decat and a tune there are gains to be had. but only with a custom tune for the aftermarket setup.
Randy
Old 09-28-2008, 12:40 PM   #5 (permalink)
Live to Drive
Bavarian Motorist's Avatar
If you're getting a custom tune, I recommend upgrading the intake system as well.
I have the PPE system and love it...would love to try it with a de-cat....
Driving a Lotus Exige with sticky... performance tires on icy roads or in standing water is about as much fun as walking a high wire treated with WD-40 - Car & Driver
BWR supercharged... I suppose I "got the power" now??
Old 09-28-2008, 07:20 PM   #6 (permalink)
'07 Black Exige S
Pestodude's Avatar
I've ordered a cup airbox as well. Doing it all at once.
Randy
Old 09-28-2008, 08:40 PM   #7 (permalink)
Form and Function
plastique999's Avatar
Hey Randy,
I have the Larini SE exhaust as well...will be installing BWR s/c shortly.
One thing about this exhaust - if you get the Reverie diffusor (I am going to install the 5 element), then don't get the Euro panel - won't fit. But you'll need a rear panel eliminator.
I hear the Gotham tune alone for the Exige will add around 40 hp alone?
Your car will be a beast!
www.FaceNBody.com
2005 Lotus Elise: Larini SE exhaust,HID's,turn signals delete,rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,Gut Aero wing,Gut front splitter,CF 5-element diffusor,Exige mesh, Ohlins DA,RAC monolites,Toyo R888's,Pagid RS Blues,CO painted calipers,SS lines,Reverie XC CF seat, Reverie CF steering wheel,V force harness bar,Schroth Profi II 6 pt harness,shifter re-Enforcer, BWR key to BWR S/C!
2007 E63 M6 (many mods...)
Old 09-28-2008, 09:52 PM   #8 (permalink)
'07 Black Exige S
Pestodude's Avatar
Running the rear panel eliminator now. I'm buying the exhaust used from a forum member. It's coming with the europanel. Thanks for the tip re: useing the Reverie diffuser and the europanel. Are you using a header?
Randy
Old 09-28-2008, 10:57 PM   #9 (permalink)
Form and Function
Currently no header....gonna go step by step....prob. just s/c first...but you never know!
Always thirsting for more power!
www.FaceNBody.com
HTML code is On
