Old 04-03-2009, 11:57 PM   #1 (permalink)
Also, my rug was stolen.
elisesile's Avatar
How much heat shielding to take off?
Arqray SS single tip. Von Hep panel delete bracket. How much heat shielding is safe to remove and still look good?
05 Lotus Elise S/T
06 Porsche Carrera S Coupe - for hauling kids and luggage
elisesile is offline   Reply With Quote
Old 04-04-2009, 05:51 AM   #2 (permalink)
STARLIGHT
V-RAPTOR's Avatar
You need to remove it ALL in order for it to look good, in my opinion!
That is what I did. At first I had left the heat shield over the elbow
pipe and it looked like crap. So I got some header wrap, removed
the rest of the heat shield, and wraped that pipe (bc it is so close
to the clam). I have had no issues thus far with the entire heat
shield removed and have read an endless amount of threads here
with the same results. Removing the heat shield from the elbow
pipe was very time consuming for me using tin snipes and cutting
off a little at a time. Maybe some one else can chime in with an
easier way.
Anyways here is my final results.
2005 Starlight Black Biscuit Interior // Hard Top // Von Hep Exhaust // Von Hep Rear Delete // Full Heat Shield Removed // Fujita CAI // Rota Torque Wheels W/ Toyo R1R's // ForceFed Carbon Fiber Splitter // Carbon Fiber Engine lid cover // LidBone // JL Audio VR525-CXi Front and Rear // Micro Mirror // Painted interior bits // Bling Buttons // Darth Holder
V-RAPTOR is offline   Reply With Quote
Old 04-04-2009, 06:51 AM   #3 (permalink)
thegoat's Avatar
Agreed. Take it all off.
I didn't have to cut anything when I took mine. Maybe you missed a bolt somewhere?
2009 White w/ Carbon Birkin Super 7 (on order)
2001 Silver Honda Civic Ex (daily driver)
2006 Polar Blue Exige - Sold
2006 Chrome Orange Elise - Sold
2000 Porsche Boxster - Sold
thegoat is offline   Reply With Quote
Old 04-04-2009, 07:55 AM   #4 (permalink)
elisesile's Avatar
It does look very clean with all the shielding off. Don't you have heat problems inside your trunk?
05 Lotus Elise S/T
Old 04-04-2009, 08:05 AM   #5 (permalink)
thegoat's Avatar
No, no issues. After removing the heat shielding, you will see that there is a secondary heat shielding/insulation on the underside of the wall between the exhaust and the trunk. I would leave that in.
While I don't hang out in the trunk to see how hot it gets, the milk stays cold on the ride home.
Old 04-04-2009, 02:39 PM   #6 (permalink)
STARLIGHT
V-RAPTOR's Avatar
Same here no heat problems in the trunk. Car runs a couple degrees cooler also.
Old 04-04-2009, 04:29 PM   #7 (permalink)
elisesile's Avatar
You guys inspired me. Ripped that darn heat sheild completely out. Did leave the U tube cover for now.
Thanks for the advise.
05 Lotus Elise S/T
Old 04-04-2009, 05:51 PM   #8 (permalink)
Darkside Eng's Avatar
Images: 22
umm... I cut mine so that I left the top piece so whatever i had in the trunk would not cook. I took off that ugly U tube cover and wrapped it.
As you can see my wrap is fading already, you should go with a high performance wrap, unlike i did.
Darkside Eng is offline   Reply With Quote
Old 04-04-2009, 09:56 PM   #9 (permalink)
jallingt's Avatar
+1, Looks like I have some wrapping to do, the black header wrap looks great.
I bet it weighs less than the Al heat shield
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can, no camber shims, Tillett saddles)
2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels, H-sport sway bars)
2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator)
Couple nice bicycles, way too many snow skis.
jallingt is offline   Reply With Quote
Old 04-05-2009, 05:33 AM   #10 (permalink)
STARLIGHT
V-RAPTOR's Avatar
You are going to eventually remove the rest of it. Trust me I know!
Old 04-05-2009, 09:40 AM   #11 (permalink)
Legend in my own mind
MightyMike's Avatar
Images: 9
Mine is also wrapped. Be advised that you should re-wrap at least once a year as the wrap disintegrates over time due to the heat.
06 ST Elise
02 SLK32 AMG
BWR Supercharged w/CharlieX tune, Borla Exhaust, OCC, ACT XTSS Clutch, Zeitronix A/F Meter, LETSLA, Manly Mounts, RTD Brace, ReVerie Diffuser, Scoops, Side Skirts, & Shifter Ball, Forcefed Spoiler, & a bunch of other stuff
MightyMike is offline   Reply With Quote
Old 04-12-2009, 03:41 PM   #12 (permalink)
Derriere Extraordinaire
Z-dculus's Avatar
can someone inventory all the bolts that will need to come out to get the heat shield off? does the exhaust need to be off also? I may do this.....but want to be able to return to stock
2006 KG-Sport Pack, LSD, TC, SS, RAC Monolites, Sector CF Roof, Carbon 3 Element Diffuser, V3 Panel eliminator (p-coated), Odyssey PC680, Boomerang , HIDs, CF Console, Multivex, Lotus Stage II, CF Zoom Rear View, Sector LidBone, Darth Holder (thanks Kestrel!), Sector 4Tress Harness Bar/CRD Mount, couple exige trim pieces- KGB Authenticated
2009 VeeDub Jetta (new kid on the block)
1978 Chevrolet Caprice Classic -(relegated to 'project car' status)
Z-dculus is offline   Reply With Quote
Old 04-12-2009, 03:53 PM   #13 (permalink)
elisesile's Avatar
Six or seven black 8mm bolts. Need to take out the exhaust and rear panel. I was able to get the complete, un-cut shield out without removing the cat. Also want to return to stock if needed. U-tube cover requires removal of sensor or cutting.
05 Lotus Elise S/T
Old 04-12-2009, 04:09 PM   #14 (permalink)
Z-dculus's Avatar
awesome thanks for the quick response. are they all under the car or are some inside the trunk?
Old 04-12-2009, 04:17 PM   #15 (permalink)
elisesile's Avatar
all heat sheild bolts are under the car. top mounting bolts for the rear panel are in the trunk
05 Lotus Elise S/T
Old 04-12-2009, 04:35 PM   #16 (permalink)
Z-dculus's Avatar
great thanks a lot man........we're getting naked!
Old 04-12-2009, 04:40 PM   #17 (permalink)
06 elise
MNlotus's Avatar
yeah i think i need to trim more off my rear. there is still some right next to the tip and right by the u bend
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 04-12-2009, 04:44 PM   #18 (permalink)
elisesile's Avatar
BTW: I was worried about not having any heatshielding, but as others on this thread have noted, no problem.
Took the car to track day Friday with no heating problems. Coolant temp as measured by the dash indicator is about 5 degrees cooler than before removal. Makes sense I guess because there is now air flow possible through that area. Completely enclosed before.
05 Lotus Elise S/T
Old 06-19-2009, 10:51 AM   #19 (permalink)
stinkyonion's Avatar
Images: 2
Took all mine off also, no wrap. No problems.
2006 polar blue Elise, VF stage II, clam hinge, von Hep exhaust, HID, Zeitronix/Dashdaq (GPS, wideband O2, EGT, fuel+oil pressure), BWR fuel rail, moroso oil pan, HD SS clutch, RTV brace, green wire mod, harnesses, Oddysey 625, alpine pdx-5, jvc avx77 head unit, jl speakers, voltmeter on dash, custom gauge pod, etc.
stinkyonion is offline   Reply With Quote
Old 06-19-2009, 12:47 PM   #20 (permalink)
breinhar's Avatar
I cut mine just above the bend on the main sheild so that the trunk was still protected. So far I have been fine. I wrapped my u joint and even with the wrap the side of the clam gets quite hot (not enough for me to be concerned) after a good drive or track day. But I am also s/c.
"I think a Ferrari is a scaled down version of..... God"
breinhar is offline   Reply With Quote
