Misfire
ALL,
OK, so it looks like the problem is not actually the intake, but instead a coincidental gathering of water inside the spark plug housing. How the heck did all of that water get in there? Apologies for raising concerns over the intake.... Flat4 Last edited by flatfour : 07-11-2005 at 11:24 AM. Reason: Cause found |
#2 (permalink) | |
the devil's advocate...
#4 (permalink) | |
Soy Anarchisto!
http://www.knfilters.com/massair.htm People still blame these (type) filters for screwing up MAF sensors. Perhaps it became dirty during installation, or you have some leaking duct-work. Clean your filter, replace the MAF sensor, make sure you don't touch it. Make sure the duct-work is installed and there's no way for contamination. Change your plugs which are probably fouled by now. If it happens again, you might then revert to stock. Unfortunately, you might have to replace the MAF again. Once they are gone, they are gone, and they are expensive to replace for the measly 2hp gain you got from intake modification... You might also revert to stock, wait for the misfire and the MIL, then take it to the dealer for MAF replacement under warranty. Unfortunately, if they know you modified the intake, you probably won't get warranty support for the MAF... 'Greg |
#6 (permalink) | |
#8 (permalink) | |
Soy Anarchisto!
How does this "lean" condition come about if the sensor is reporting the correct air flow? Assuming all other systems are working correctly, it cannot. MAF sensors are wires exposed to the air flow. Current is applied to the wire to heat it up and a thermocouple measure the temperature of the wire. The amount of current required to keep the wire at a fixed temp is a function of the mass of air passing over the wire. The computer has a lookup table in memory and maps the current to the amount of air passing throught the control volume of the throttle body. Dirty MAF sensors cause incorrect flow measurements and "lean" or "rich" air/fuel mixtures because the correct air mass is not being reported to the computer. High-flow filters also let more dirt by, in addition to more air. Lean conditions would be intermittent at first, and probably progressively get worse. Clean or replace the MAF, and see if the misfires continue. If so, replace the stock intake, and clean the MAF again. If you still get misfires, take it to the dealer and make them replace the MAF under warranty. 'Greg |
#9 (permalink) |
Greg, I'll defer to your superior knowledge. What I was trying to say was....the tech can monitor the MAF readings at various RPM's and determine if the MAF voltage readings are within spec and hence working properly. I agree that MAF sensors can routinely go bad on cars -- that has happened on some Porsche's I've owned -- but the tech could always diagnose that issue by studying the readout on his OBD computer, as well as the code for the CEL. For sure, studying the condition of the MAF by pulling it can also help with any diagnosis.
#10 (permalink) |
The Original Dro
People without problems don't usually start threads to say so, so in the interest of balance I want to point out that many people have installed the ITG without any problems. I have 1500 miles on my ITG and the car runs great.
#11 (permalink) | |
Student Driver
The Scantool (or even a generic OBD tool) can show the current airflow reading in real-time, handy for finding out if you're hitting the limit of the sensor, or getting erratic readings. The Lotus ECU will also trip an error (P0101) if the "range or performance" of the MAF is detected to be out of spec, though they don't say what that means. TYpical values are 1.5-5.0g/sec (idle), 5.0-15.0 g/sec (2500 idle). That should be easy to confirm. And I was surprised to see that we do indeed have a hotwire MAF. It should have plenty of available range to cover increased intake flow, right? |
#12 (permalink) |
Thanks for all of the replies. The fault was the "Missfire fault" causing damage to the catalyst. This was reset, and I drove thr car for 5 miles (thrashing) and no missfires were apparent. Then I got the car hot on a long run and the missfire returned. I will remove the Intake and see hoe the car does as standard. All pipework is tight and sound, the MAF sensor looks as clean as a whistle (looks).
I never had this grief wth a scooby - decat, ecu, etc. I am keen to see if all is safe wehn it is back to standard. Flat4 |
#14 (permalink) | ||
Student Driver
#17 (permalink) |
Soy Anarchisto!
Misfires can be caused by other things and it just may be coincidental to the ITG install, so you may want to rule out the following (or make sure your technician has ruled out):
coil pack ignition wires plugs fuel pressure regulator fuel filter knock sensors vacum lines I don't think I saw a vehicle history anywhere. How many miles are on your engine? Of course all the above is unlikely if you've only got 3k miles on your car, but just to be complete... |
#19 (permalink) | |
Driving my Corolla : )
Neil
WTF people? |
#20 (permalink) |
elise groupie
We noticed that you are located in England. Perhaps you should consider contacting ITG directly about these issues.
Let us know if anything develops. If any of our customers ever have similar issues, this way we may know how to resolve them.
Long live the
