#21 (permalink) |
Plug Whisperer
Good fab work fellas! Anyone ever tried a chambered exh like flowmaster type designs or is that bad juju on a 4 banger???
#22 (permalink) | |
Hydrocarbons Rule
It would be nice if they would give you some dimensional measurements of the internal area of the muffler so you could calculate the sizes of the ports in between the baffles. ![]() ![]() ![]()
#23 (permalink) |
I am going to do my custom exhaust this week. I am planning to do 1 18" Magnaflow muffler and diffuser exist. Not going to use any dual tips and I want the pipe exit to be flush with the diffuser. I am also planning to cut a piece of aluminum to cover rest of the space in the OEM diffuser hole. Basically I want the exhaust exist to be as stealth as possible.
2006 ST Elise/SSR TypeC/Green Filter 2008 Subaru Legacy 2.5GT Limited |
#24 (permalink) | |
What do you guys do about the hole in the OE diffuser post exhaust swap?
2005 Magnetic Blue Elise - "the Lotus" (original I know) 2001 Jeep Wrangler - "soul crusher". If you dont GET it after you drive it, then you dont GET it - serpent |
#25 (permalink) | |
Hydrocarbons Rule
I've have seen a few cars here in Japan where they covered both sides of the hole with duct tape. Then they spray paint over it so it blends in. I've also seen them cut a thin piece of aluminum that is larger than the hole. Paint it and then use double sided molding tape to stick it to the diffuser as well.
#26 (permalink) | |
![]() I considered a CF diffuser like ReVerie CF Rear Diffuser - 3 Element for the Lotus Elise and Exige - Sector111 until I saw the price. I wonder if a good welder could make it hole-less and still look clean?
#27 (permalink) | |
Plug Whisperer
Later, Phil
#28 (permalink) | |
no worries if Not Did you just make it big enough to cover the hole? or the entire center section? I could experiment with this...but I'm @ work, so you know curiosity is bugging me.
#29 (permalink) |
I looked everywhere at Home depot tonight and can't find any aluminum material I like, its either too thin or too small. Those flashing material from HD are paper thin. I ended up buying a piece of baking sheet from Target. This should be available everywhere and it looks much better than regular unfinished metal (and cheaper too!!). Very close to the OEM brushed look. I bought some 500F metal epoxy and I am going to glue it to my diffuser tomorrow. I will post some pictures when I am done.
AirBake Ultra Natural Cookie Sheet - 16x14" : Target
#30 (permalink) |
Dan D
Damn! Good work fellas!!
07 Exige S 265: GG, Track Pack, V1, RV Camera, S111 CF roof and splitter, 4.5-lb Voltphreaks battery, 10-lb Von Hep Exhaust, Green filter, 265 crank hp +/-, Volk TE 37 Wheels, RTDbrace, Scroth 6-point ASM harnesses, Innovative Motor Mounts, Saiku Michi Catch Cans. To come: IC fans, headers, and sport cat. 1955 lbs total weight (est w/tank half full) 05 Elise: Storm Titanium, Sport, Touring, Stage II (SOLD) (May '05 - Sept '06) |
#31 (permalink) | |
Thanks Serge |
#32 (permalink) |
Hydrocarbons Rule
Sound is Great and I think you'd probably pass noise levels at the track.
