Pro Alloy Install
Hey guys a while back I thought I saw a thread with... How to install step by step.
Anyone know or have any ideas on where it's at? Thanks In Advance
Exige S 07... ReVerie Rear 1650mm wing, CF 3 element diffuser, Front Exige flat bottom splitter, Craftsquare CF Side Mirrors, CF Exige Side Scoops, ,CF Binnacle, CF Center Console, CF Side Skirts & CF Canards on order. Arqray Twin Muffler, ACT Clutch, Findanza Flywheel, Schroth PROFI II ASM Harness for Hans, WorksBell Rapfix II Quick Release, re-ENFORCER, ULTRAdisc-Front & rear,Nitron Sport PRO, Pagid RS14 , LSS RIMS Powder coated, stellaCORSE Wheels Street Ducati , R1-LE |
I <3 chicken, I <3 liver
you got the chargecooler?
cooler install
Yup started install this morning... took some pictures. Having hard time installing RAD instructions are not so clear. Picture shows fans on the bottom however install doesnt fit.
Can't wait to finish. Got clams off , removed stock intercooler, removed stock Rad, installed new I/C, Pump and lines. Also changing out speakers since it's all out, putting in new Moroso Oil Pan, and Custom GRIPP Roll Cage and motor mounts. Can't wait!! ![]() ![]() Ara did you get headers?
Blue Wheel Pimp
Did you get the new fan assembly with it? If so those fans (with the aluminium bracket) go on top of the radiator.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
Cool but I cant get them in... do I have to remove black fan shroud?
Blue Wheel Pimp
I honestly dont know the pro alloy instructions or what needs to be done. My setup is all custom and I did have to remove the radiator shroud. Dont know that you need to for the pro alloy though.
#7 (permalink) |
it's been on the car for a few months now.
it's just the decat and new exhaust I'll get in a few days. ![]()
