Old 06-11-2005, 09:46 PM   #1 (permalink)
toyopet's Avatar
problem with new itg cai
hey guys,
just got done installing itg cai and immediately noticed a problem. at around 5-7k rpm, the car has some hesitation. but below or over it, its' running just fine. any one of you encounter the same problem? any suggestions? thanx.
toyopet is offline   Reply With Quote
Old 06-11-2005, 10:13 PM   #2 (permalink)
Dro
The Original Dro
Dro's Avatar
I have the ITG and don't have that problem.
I'd check the vacuum line caps provided with the install kit to make sure they didn't come off. If they were okay I'd probably look at the MAF sensor next. The o-ring on that thing is tricky to get right.
(Disclaimer: I'm not a real mechanic I just play one in my garage.)
Dro is offline   Reply With Quote
Old 06-12-2005, 06:08 PM   #3 (permalink)
arandolph's Avatar
I also have one and have not had any trouble. Actually, I think it is awesome!
arandolph is offline   Reply With Quote
Old 06-12-2005, 09:16 PM   #4 (permalink)
Check engine light P0171
No hesitation with mine that I know of. So far I have only had it on for 150 miles but I now have the above code on and I am not sure why.
Does anyone else have this problem?
I am going to call my dealer tomorrow.
Take care,
mr t
mr t is offline   Reply With Quote
Old 06-12-2005, 11:58 PM   #5 (permalink)
KMS Elise's Avatar
No problems, more than 2000 miles with my ITG cai.
KMS Elise is offline   Reply With Quote
Old 06-13-2005, 09:37 AM   #6 (permalink)
Jack's Avatar
I'd agree. Sounds like it could be a vacuum line/cap issue (especially the CEL problem) -- that appears to be one of the tricky/delicate areas of this install.
Jack
'08 2-Eleven
Jack is online now   Reply With Quote
Old 06-13-2005, 09:40 AM   #7 (permalink)
Take care,
mr t
looks like the maf isn't positioned properly in the intake tract, and causing the evap cel.
Controlled Inertia
02 Celica GT-S R.I.P.
05 Obsidian Black Pearl WRX STI
Illusive is offline   Reply With Quote
Old 06-13-2005, 11:37 AM   #8 (permalink)
P0171
The vacuum caps were double checked and the MAF was very carefully installed. If there was a installation mishap, the check engine light would not have taken 150 miles to come on, right?
How long do you need to have the battery disconnected to reset the check engine light?
Does anyone think that the problem could be related to the reprograming of my ECU at my 1K service?
Thanks all for your comments,
mr t
Old 06-13-2005, 12:12 PM   #9 (permalink)
Jack's Avatar
mr t
CEL would not necessarily come on right away -- it generally takes several driving cycles for it to come on, as well as go off once a problem is resolved.
The battery need only be disconnected for 10 minutes or so.
I doubt your problem was your dealer's reprograming of the ECU.
By any chance, did you get gas during this time frame -- could it be a gas cap issue?
Jack
'08 2-Eleven
Old 06-14-2005, 09:02 PM   #10 (permalink)
Cleared Ck. Eng. Light
Hi Jack,
There was never an issue with the gas cap. I always make sure it goes on correctly.
After driving for two days, The light went out on its' own so I really don't know why it came on in the first place but I am glad that it is gone. I guess it cycled thru it like you said.
Thanks for your time to input your thoughts,
Take care,
mr t
Old 06-14-2005, 09:15 PM   #11 (permalink)
Student Driver
Ground Loop's Avatar
If you're curious, you can still view the reason for your last Check Engine light with an OBD tool. You can even view the engine parameters at the time it decided to throw the error.
If you're curious..
Old 06-14-2005, 09:33 PM   #12 (permalink)
elise groupie
Modern Wedgie's Avatar
toyopet,
are you still having problems with hesitation? Have any of the suggestions noted in this thread helped you? These guys are awesome. I would have suggested the same things!
Long live the
Modern Wedgie is offline   Reply With Quote
Old 06-15-2005, 11:08 AM   #13 (permalink)
Thanks!
Thanks Ground Loop,
For the advice, If it happens again I will be REAL curious but for now, I'll just have fun.
Take care,
mr t
Old 06-16-2005, 09:23 AM   #14 (permalink)
Project Nirvana Elise
shinoo's Avatar
Toyopet,
Please contact Lillie or I directly by email or phone. We have not heard this issue from any customers.
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
Old 06-19-2005, 08:15 PM   #15 (permalink)
toyopet's Avatar
thanx for all the helpful tips guys. got it straightened out. actually it just cured itself after a day of driving. thanx a lot everyone.
