#61 (permalink) |
My Cup 260 is here!
Yesterday was THE DAY!
I dynoed my car and you can find the astonishing dynochart below. The dynometer used was a Dynapack 4000 which measures flywheel power. My performance mods up to now are: 1) Lotus Stage 2 exhaust 2) Reverie CF Daytona 230CX Induction Kit 3) Reverie CF Intake Duct (Side scoops will be fitted very soon) So, down to figures now. Max output: 210,3 PS @ 7800rpm (flywheel) Max torque: 20,87Kg.m @ 6750rpm. ![]() Unfortunately I didn't have sufficient time to dyno the stock filter too, but will eventually do so later on. |
#62 (permalink) |
You either got one hell of a good motor or those mods are making approx 20 hp right? It's early and I may be missing something here.
Dan Parker 92 BMW 325 - JP Race Car 09 Jetta Tdi 06 Z4 M Coupe 09 Child on the way (anyone need a car?) |
#63 (permalink) | |
My Cup 260 is here!
Maybe both!?! ![]() Anyway, for those who'd like to have a clip you can find it here (wmv, 2.5MB). |
#67 (permalink) |
I'm bored...yawn...
damn! 20hp! Pretty sweet!
Do you have to run another dyno to simulate a hot engine or warmer weather to see if the gain is constant?
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 '08 Acura TSX 6-speed support WTC 2! |
#68 (permalink) |
Hey Guys.... DYNO CHARTS MEAN NOTHING WITHOUT A BASELINE FOR COMPARISON. Actual HP #'s have little meaning. I cannot imagine one could get that much performance from already tweeked 4 cylinder engine. The days of easy strap-on high HP mods ended years ago with bigger and less complex engines. I think a ECU tweak would be needed for a true 20 HP gain on this kind of engine.
#69 (permalink) | |
I'm bored...yawn...
#70 (permalink) | ||||
My Cup 260 is here!
1) Regular Unleaded (95RON) 2) Premium Unleaded (98 RON) 3) Shell V Power Racing, BP Ultimate 100, and other local "distiller's" 100 RON unleaded fuel. Quote:
I measured flywheel power output (PS), and if the other Elise guy will give us a comparable chart, the problem is solved, without double the "R&D" from my side! ![]() As Shay2nak correctly said, the engine is a Toyota drop-in, and only the ECU was tweaked by Lotus. As shown, there are some gains to experience from that factory tweak. If my dyno readings are a bit optimistic or the specific engine performs a bit better or any other combination that may drag the power curve just a bit higher doesn't alter the fact that the combination of the Lotus Stage 2 exhaust and the Reverie Induction system simply rocks! It's not something that has only been drawn on a paper but also a feeling all my codrivers and I have experienced when upgrading the respective stock parts, especially the filter, were the snail and the clumpsy airbox were replaced by the beautiful Reverie airbox and the side intake duct, hence actinng basically like a ram tube .In the next dyno session I'll check Komo-Tec's exhaust manifold and sport cat! Stay tuned! ![]() |
#71 (permalink) |
I'm bored...yawn...
do you remember what the dyno read from the other guy's elise off the top of your head?
What if we install larger fuel injectors and throttle body? Could we get another 5-10 hp? My goal is to get the car to 230hp by installing intake, headers, sport cat & exhaust, maybe throttle body and injectors. Then to get the car to 1850 lbs and I will be content.
#73 (permalink) |
I am leaning in this direction as well. I've had turbo cars in the past and although the turbo from forcedfed sounds great I can't help but wonder what the Elise would be like with a tweaked n/a engine. 230hp doesn't sound unreasonable and reliability is very important to me if I am going to be driving up to 6 hours from home to attend track days.
#74 (permalink) | |
Either way I do appreciate you sharing your experiences with this upgrade Last edited by Lotus F1 : 01-30-2005 at 08:04 AM. |
#75 (permalink) | |
#76 (permalink) | |
His Impatientness
www.agentsofentropy.com |
#77 (permalink) |
Wizard of Pugz!
I think some are being a bit unrealistic. I am sure it takes time to make these modifications.
For somebody to dyno their stock car one day, and make all of the modifications (e.g., install the new muffler and the Reverie intake system, tune) and then dyno the car the same day, under the same conditions, is a bit unrealistic. I do think it's important to dyno the SAME car, but not necessarily on the same day. Noting temperature, pressure, and humidity differences on the comparison plots is important too. |
#78 (permalink) | |
#79 (permalink) |
Mountain Road Nut
Or, take the scientific approach in situations like this. Use a second car as the comparison. Take two cars, dyno both back-to-back a few times under different conditions. Get a good comparison. Now modify one of them, then dyno the two cars back to back again (a few times under different conditions if possible). Of course, free (or low cost) use of a dyno would be helpful.
Of course, you just need 2 cars. Maybe a second Elise owner in your area who is also considering the mod, if it works out. |
