Follow the ******
ReVerie vs Fujita
Are there any sound or performance differences between the two?
2006 Alpine White Elise Touring, Starshield, Hard Top, Black Package, Traction Control, Fujita, Larini SE's |
I can run very fast
Yes, the reverie does not sound as loud until you get on the 2nd cam. The Fujita is louder.
my favorite Elise sites: http://www.elisemods.com http://www.sandsmuseum.com/cars/elise/index.html |
#4 (permalink) | |
Follow the ******
cbelon - Thanks for your input... go away now. ![]()
#5 (permalink) | |
fm78.tv - check it.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
#6 (permalink) | |
Follow the ******
#7 (permalink) | |
fm78.tv - check it.
#8 (permalink) | |
Follow the ******
#9 (permalink) | |
fm78.tv - check it.
#10 (permalink) |
there have been plenty of discussions on CAIs and their perceived performance gains.
I can say I have a Fujita and like the sound. Never a CEL. Simple for me. Don't expect any true HP gains and you'll be happy. |
#11 (permalink) | |
Follow the ******
#12 (permalink) |
I think Randy posted something a while ago after fairly extensive testing that the stock box actually performed better than some of the aftermarket CAIs. I'd do some more searching. A could be wrong on Randy's results so someone pipe in if that is the case.
#13 (permalink) | |
Follow the ******
#14 (permalink) |
The Architect
I go for the K&N/Green filter + velocity funnel. It's the best!
"More power makes it fast on the straight, less weight makes it fast everywhere." - Colin Chapman 2006 BRITISH RACING GREEN EXIGE 2005 SAFFRON YELLOW ELISE (R.I.P.) |
#15 (permalink) |
El Jefe - Agent 111
We did indeed do testing and found up to a 9hp loss (or something close to that). The best results were the Lotus supplied one, snorkel removed, green filter. I do not bother with the Velocity stack. I don't think it is needed. Removing the snorkel also gets a nice amount of sound.
* V E R I T A S * A E Q U I T A S * We have been feeling the buzz since 2002 2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds. ..is a stranger in an open car. Tempt you in and drive you far away |
#16 (permalink) | |
GR8 SCAPE
I used a K&N Filter and have been very happy with the sound improvement. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black interior, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, front shims removed, Alpine CDA-9856, Infinity Speakers, I-Touch adapter, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws. |
#17 (permalink) |
Follow the ******
I installed the Fujita today and I have to say WOW this thing sounds incredible! My exhaust is stock (for the moment) so you really get to hear every bit of volume from the intake. After having the wheel off and the inner fender off, I finally got a clear view of what kind of flow the filter will get from the side vents. It's a clean shot for the air/wind; straight through to the filter.
Seeing how this setup works, I can't imagine a loss of power. Sure, maybe sitting on the dyno where the engine/filter/tubes get heat soaked with a fan blowing on the front of the car, but out on the road there's no chance of that. A 9hp loss is something I would put hard money on to see. We've all seen the other dyno's of 1-8hp gains which may be from the car running slightly leaner with the new intake. But I gaurantee you're going to see some gain out on the road with any aftermarket intake on these cars. The factory snorkel seems to be a bit of a joke considering how much open air an open filter can get when driving. The snorkel is pretty small with some bends to try to pull the air up. I spoke with Sector111 about the difference between the two intakes. They said the power gain (although small) was the same for both intakes. The sound is essentially the same too. It's the materials that make up the ReVerie that adds to the cost (which isn't a bad thing). I've had enough hi-po cars to know that the butt-o-meter can lie, but the car just screams so much better that the feeling and sound of speed is SO MUCH better than the stock box. Without question I'd recommend an intake for the noise alone. Anyway, this is an internet forum and there's always talk one way or the other, but I give this mod the big thumbs up. Next up...... Larini with the SE tips. I can't wait to see how much power I lose with this one!! ![]()
#18 (permalink) |
disproving HD MTBF daily
I wouldn't put money on it, many of us have seen the loss, street and dyno'd.
The stock box is excellent.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it. |
#19 (permalink) | |
Follow the ******
Edit: Charlie, when you make it down to Phoenix to tune my car, we could do a little test. If I win, the tune is free. If you win, I'll double the cost of the tune!! :-)
#20 (permalink) |
sure how do you want to wire the money? (said that before the edit)
it makes perfect sense if you know why it does.
