GR8 SCAPE
STAGE 2 Install How-To w/pics
SEE FINAL UPDATE AT END OF THREAD
STAGE 2 INSTALL I finally finished the installation of the Stage 2 this weekend. Not that hard to do, but had a few issues along the way. Took about 3 hours. Here’s how I did it: 1. Put car up on Rhino ramps, removed diffuser and engine under tray. 2. Remove aluminum access panel on passenger side. This is a small panel with 4 screws that attach to the heat shield. You must remove this to allow exhaust to slide over. This is where one side of the exhaust drops down and slides left to remove from cat pipe. 3. Removed Hanger Bolts and rubber bushings from Access Panel side. These pieces are on the exhaust hanger long stud. Remove and place on new exhaust. 4. LOOSEN Hanger Bolts on driver’s side. DO NOT REMOVE BOLTS AND BUSHINGS ON THIS SIDE. 5. Remove exhaust clamp nut and applied PB blaster to joint. Let sit for 15 minutes and then separated pipes. Slide exhaust to the left, disengage exhaust from hanger bolts on driver’s side, drop exhaust down and remove from car. CAREFUL: The exhaust is heavy; it dropped on my chest, as I wasn’t ready for the weight. Ouch!! 6. Now I prepped the Diffuser Panel to enlarge the opening for the new exhaust, using template that comes with the exhaust. 7. Taped template over existing opening, traced cutout line with Sharpie. 8. I used a combination of Dremmel and Jigsaw tools to cut/enlarge opening. Aluminum cuts fairly easily, but making some of the turns was tough. Initial cut was rough. So I used a Dremmel with sanding stone attachment to smooth and feather edges. No sharp edges, OK to handle. 9. I took the Diffuser panel to a powder coater and had it done in a textured black. (pics at a later date.) 10. Now to install Stage 2. Start by re-inserting hanger stud on exhaust into the hanger bushings on driver’s side first. 11. Lift exhaust up and slide exhaust pipe onto cat pipe. MAKE SURE EXHAUST CLAMP IS ON EXHAUST PIPE BEFORE YOU CONNECT PIPES. Otherwise you will have to take them apart again. DO NOT tighten exhaust clamp until you complete Steps 13 & 14 below. 12. NOTE: OEM exhaust clamp wasn’t used, as it didn’t tighten down enough on Stage 2 exhaust. I bought a Stainless Steel T-clamp (Summit Racing, $5.50) instead. 13. Raise other side of exhaust and reattach passenger side hanger bolts and bushings to rear sub-assembly. 14. BEFORE tightening hanger bolts, position new exhaust at center point of car. I test fitted the Diffuser panel to make sure it is lined up properly. 15. Tighten Exhaust Clamp and all other bolts. Refit Access Panel. 16. I started and ran the car for several minutes before re-fitting all the under trays. 17. SOUNDS GREAT!! 18. When I have everything back together with powder coated diffuser and boomerang tow hook from Sector 111, will post final pics.
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. Last edited by waydui : 03-26-2007 at 11:31 AM. |
GR8 SCAPE
More Pics
Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
GR8 SCAPE
More pics...
Wayne
I'm bored...yawn...
nice job!
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 '08 Acura TSX 6-speed support WTC 2! |
#9 (permalink) |
I'm bored...yawn...
does anyone know if the Exige S' diffuser needs to be cut to accept the stage 2 tips?
#10 (permalink) | |
__________________ Last edited by Jack : 02-19-2007 at 10:30 AM. |
#13 (permalink) | |
Super charged!
I just posted this in another thread and wanted to add to Waynes great write up for everyone's reference...
#14 (permalink) |
GR8 SCAPE
In addition to loosening the driver's side hanger bolts, I used some PB Blaster sprayed onto the exhaust stud and around the rubber bushings.
Slid right out. No hammers or banging required. To reinsert, I cleaned off Blaster and used saliva as a lubricant to slide into bushings. Didn't want to leave Blaster product on rubber bushings. Wayne
#16 (permalink) |
Drifting w/o LSD
Great post. Do you have a Summit part no. for that t-clamp? Thanks!
2007 Cobalt Blue Porsche 997S 2008 BMW M3 (M-DCT) 2006 Ducati Sportclassic Sport 1000 (Tangerine Yellow) 2001 Ducati Mh900e #18 2005 SY Elise (sold); 2006 PB Exige (RIP) |
#17 (permalink) |
GR8 SCAPE
STAGE 2 INSTALL - UPDATE
I finally finished putting the whole thing together, including the black powder-coated diffuser panel and Sector 111 "boomerang" tow hook.
Powder-coating was $50. I bought the Exige diffuser edging (silicone split tubing) to get the black color. The Elise tubing is silver. Silicone is a PITA to glue/bond to powder-coated metal. I ended up using Loctite "superglue". I also used some garden sprinkler system hose, which I split with a razor blade and snapped onto the edge of the diffuser. Much easier to work with, but a little thicker, and heavier, too. The tow hook was simple to install. I bought some additional hardware: spacers, lock washers and longer bolts to attach the piece. To keep the tow hook "tongue" from bouncing off the diffuser, I bought a pack of industrial strength Velcro patches. I put them all around the contact area on the tongue. Turns out that powder-coated metal is a "Low Surface Energy" (LSE) substrate, so I got some LSE adhesive and built an insert spacer with LSE adhesive on each side and put it between the diffuser and the Velcro pieces. Everything stays put now. I like the new look and the Stage II is really a great-sounding exhaust! Regards, Wayne
#18 (permalink) |
I'm bored...yawn...
nice plate.
#19 (permalink) |
Thanks for the write up and pics, I will be putting my stage 2 on this week! Do you know if cutting is nessessary on the openings for the Exige? I'd hate to scratch up my diffuser...
http://www.youtube.com/jerusdc |
#20 (permalink) | |
EDIT: LOL, I didn't see that it was posted above - eh, it's cleaner in P's thread.
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior. |
