Old 03-29-2007, 09:32 AM   #21 (permalink)
def
...ault
def's Avatar
Not much of a template though, since they are both pictures of one. Does anyone know if there is there a printout (to make it more precise)?
I'm waiting to hear back about picking up a local used stage 2. If it's a jenspeed, I'm going to purchase it, and would love to have a body shop do the cutout for me (dealer = $$$$$$)
Thanks,
//kevin - 05 Graphite Gray - Red Touring / LSS / Starshield / Stage 2 + more SOLD
def is offline   Reply With Quote
Old 03-29-2007, 11:29 AM   #22 (permalink)
GR8 SCAPE
waydui's Avatar
Hi Kevin,
I still have the original sheet template that I used to cut mine out. It's actual size and has the measurements printed on it.
I can fax or e-mail a PDF of it to you. Let me know.
Regards,
Wayne
_______________________
Old 03-29-2007, 12:39 PM   #23 (permalink)
def
...ault
def's Avatar
PM sent, thanks wayne!
Old 03-29-2007, 12:44 PM   #24 (permalink)
fm78.tv - check it.
Serebo1's Avatar
Images: 4
Originally Posted by waydui
Hi Kevin,
Regards,
Wayne
Might be a good thing to have in the library. As long as it's scanned flat, most people can blow it up to scale following the dimensions....
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior.
Serebo1 is offline   Reply With Quote
Old 03-30-2007, 08:38 AM   #25 (permalink)
A lot of stickers!
Images: 9
Great info. Very straightforward. Is this in the uberthread? It should be.
I installed mine last night. Did not need Rhino Ramps or any type of lift. Also did not need to remove the undertray; just the rear diffuser.
The PB Blaster was very helpful as it was still a bitch to get the old exhaust out of there. I just ended up wiggling it up and down and it eventually came out. You aren't kidding that stock muffler is HUGE!
Only problem I encountered believe or not was reinstalling one of the hanger mounts on the passenger side, as the holes weren't matching up. Of course I was reinstalling it at night in my apt. complex garage w very poor lighting. I also notice some burning smell, which I assume is burnoff of the PB blaster.
Otherwise it now sounds like a beast much better that the "fartcan" stock exhaust. Thanks Matt for the exhaust.
Jeff
Formerly known as brgm100
1991 Lotus M100 Elan
2005 Lotus Elise
2008 Saturn Astra XR 3 door 5 Speed
Toad is offline   Reply With Quote
Old 03-30-2007, 10:33 AM   #26 (permalink)
Computer Nerd
Transonic's Avatar
Images: 2
Great write up, I'll be sure to save the thread.
Two quick questions though regarding the exhaust clamp. You mentioned it was spot welded to the exhaust. You used PB Blaster (is this the stuff?) to remove it. Would that be the same as using liquid wrench or even WD-40 or is the PB Blaster definitely needed? And #2, one T-Clamp and you're all set? No need for anything to "glue" it in place?
'05 Elise Starlight Black + Sport Pack on Red Leather
Exige Grills | Arqray Single Tip Titanium | Rear Panel Eliminator | LIR Racing CF Side Scoops | raceVIEW CF Mirrors | Zoom CF Mirror | HIDs | 4.5lb battery | Sector111 Bootie | No Carpets or Sound Deadening Foam | Sector111 4Tress Bar w/ EZMount | reENFORCER | SS Brake Lines | Green Filter & Desnorkeled
Transonic is offline   Reply With Quote
Old 03-30-2007, 11:33 AM   #27 (permalink)
A lot of stickers!
Images: 9
I don't think there should be anything to glue, just clamp. In fact I didn't see any loctite on any of the bolts.
Jeff
2005 Lotus Elise
Old 04-02-2007, 06:16 AM   #28 (permalink)
GR8 SCAPE
waydui's Avatar
Hi Transonic,
I'm sorry but I wasn't very clear about the clamp process.
I wanted to use the SAME clamp that came with the OEM exhaust on the Stage II. I had to CUT IT OFF with a Dremmel cutoff wheel because the original clamp was spot welded to the stock exhaust.
However, the original clamp was too big for the Stage II exhaust pipe, so I ended up buying a 2.5" T-Clamp instead.
Yes, you have the right PB Blaster product. I think PB Blaster works better than WD-40, but that's just my opinion.
No, there is nothing to glue. The T-clamp holds everything together just fine.
Regards,
Wayne
Old 04-02-2007, 06:20 AM   #29 (permalink)
GR8 SCAPE
waydui's Avatar
Diffuser Template PDF File
Due to several requests, I am attaching a PDF file of the Diffuser Template cutout.
NOTE: BE SURE TO UPSIZE THE TEMPLATE TO 115% TO COMPENSATE FOR SHRINKAGE IN DIGITIZING IMAGE.
Use this to cut out an enlarged opening for the Stage II exhaust. The aluminum cuts easily, but make sure you smooth out the edges, removing any burrs, etc.
Regards,
Wayne
Old 04-02-2007, 07:02 AM   #30 (permalink)
Drifting w/o LSD
mattwhite's Avatar
Glad to see you got it on. Did you cut the diffuser yourself?
2007 Cobalt Blue Porsche 997S
2008 BMW M3 (M-DCT)
2006 Ducati Sportclassic Sport 1000 (Tangerine Yellow)
2001 Ducati Mh900e #18
2005 SY Elise (sold); 2006 PB Exige (RIP)
mattwhite is offline   Reply With Quote
Old 04-07-2007, 08:17 PM   #31 (permalink)
A lot of stickers!
Images: 9
Hi Matt,
I'll probably cut it tommorrow, since the picnic thing got cancelled and the weather is crappy. Wayne sent me the .pdf. I picked up the Dremmel at Sears today.
Jeff
2005 Lotus Elise
Old 04-11-2007, 08:18 AM   #32 (permalink)
A lot of stickers!
Images: 9
Computer question.
Is there a way to get this .pdf to "scale" correctly to a printer or plotter? I tried many different paper settings to try to match the radius numbers and other measurments and did not have any luck.
Jeff
2005 Lotus Elise
Old 04-11-2007, 09:17 AM   #33 (permalink)
def
...ault
def's Avatar
Uh oh, I just printed it out and didn't even think about the right proportions...
I'm taking my car today after work to have 15k service, new tires, and diffuser cut by the shop. Let me know what you find... asap
Old 04-11-2007, 09:33 AM   #34 (permalink)
def
...ault
def's Avatar
OK so I just printed out another copy, and took it to the copy machine... I did some quick (wrong) math, so I had to print out a few copies, but looks like blowing it up 115% did the trick (11x17 paper). The "56.9" figure looks off a little, but the rest are all perfect....
I don't have my car here at work due to rain (gotta go home and switch cars to take it to service). Otherwise I'd be able to hold up the cutout to the current diffuser hole. Are you sure we need to blow this up... Wayne did you? Anyone?
Old 04-11-2007, 10:18 AM   #35 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
I had a hell of a time trying to remove the stock exhaust as well, but didn't realize the stock clamp is welded onto the exhaust! I had to put everything back together again and take the car out for a spin to make sure all was well. When you speak of burnoff, I had a scare during my drive...I sprayed WD40 on the stock clamp and the driver's side hanger. I tried to wipe as much of it off as I could before I reassembled everything and when I went driving soon after, I could see smoke coming from my rear tire!!! I was at a stop light and just looked in my side mirror and saw it. Anyway, pulled over right away and had my extinguisher in sight as I checked it out. Turns out the smoke was coming from around where the clamp is. Anyway, it smelled like WD40 also. I kept driving for another 5 miles came home and it's still burning off the WD40!!!
WD40 isn't flammable is it?? My car didn't catch fire so I guess it's a NO. Only when it's being sprayed out of the can? I'm going to try to install the exhaust next weekend and hopefully I won't need to spray it again.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 04-11-2007, 10:21 AM   #36 (permalink)
GR8 SCAPE
waydui's Avatar
I DID NOT blow up the document, I used as it is and did not have any issues cutting out the enlarged area to the right size.
The PDF itself is only a few millimeters (2-3mm per locus) off the diagram specs. There was more than enough clearance once I cut the diffuser.
Regards,
Wayne
Old 04-11-2007, 10:31 AM   #37 (permalink)
GR8 SCAPE
waydui's Avatar
Actually WD-40 IS flammable, but it has a high flash point and needs a spark or flame to ignite it. WD-40 is essentially kerosene.
WD-40 on a hot manifold or exhaust will just smoke until it all burns off.
DO NOT put an open flame to WD-40 or you will have a fire.
FWIW, I use PB Blaster and like it better than WD-40.
Regards,
Wayne
Old 04-11-2007, 10:59 AM   #38 (permalink)
A lot of stickers!
Images: 9
Thanks for the tip. I just did the same thing, blowing it to 115 and the measurements look good. I had to use 2 legal size sheets of paper, which I'll have to tape together.
When I did they 8.5 x 11, the "extended" area matched up to the original size of the hole.
Jeff
2005 Lotus Elise
Old 04-11-2007, 12:39 PM   #39 (permalink)
def
...ault
def's Avatar
OK I just called Thom at FVMC (where I bought the exhaust). He pulled out a template and we DO need to blow up the PDF template above by 115%. The measurements should be correct in MM. Wayne, I'm not sure if it shrunk after it was faxed or which sized you used (obviously it worked out great for you, so it doesn't matter), but I will use the enlarged one.
Might want to make a note of that in your post with the .pdf file, but I'll provide some picts of mine (hopefully) soon.
Thanks for the help guys,
Old 04-11-2007, 12:55 PM   #40 (permalink)
GR8 SCAPE
waydui's Avatar
Hi Kevin,
Thanks for following up on this. I edited my post to reflect resizing issue.
Hope it works for you.
I'm sure you'll love the sound!!!
Regards,
Wayne
