#41 (permalink) | |
#42 (permalink) | |
Ara, I really don't know -- I've heard it both ways... 1) that they are the same and 2) that the 255 injectors are larger than the ones that were in the Cup240. FWIW, I do know that the Lotus replacement part # for injectors in the 255 is different than the 240. ![]() As for just going to larger injectors to increase fuel delivery, at a certain point the fuel pump capacity will be your limiting factor. And, with the Gotham re-flash opening the TB to virtually its full capacity, I think you're already there, especially under circumstances calling for almost continuous WOT operation (read...track duty). ![]() I know that Frank went to a larger fuel pump -- isn't he running 550's?? |
#43 (permalink) | |
So this is the filter you metioned? From the picture it look like an Air filter for Celica. A TRD filter will be in red.
I Live Only Once But Twice As Good! |
#44 (permalink) |
Fibreglass Junkie
If you look at the Lotus Sport brochure, the "TRD Performance Air filter" listed in there is red.
'07 Exige S L&C Motorsports - Parts for Lotus Elise/Exige in Asia LotusClubSG - Lotus Club of Singapore |
#45 (permalink) |
Monkey Tuned!
My understanding is that we need a Warlboro 255 pump to feed the 550cc injectors.
Also, you can get the cup airbox from Alan @ BH for around $215. If you get it from my 'friend' who gave me a 'special buddy deal', he'll give it to you for $350. But you don't pay tax ![]()
It's MISTER Black Flag ![]() Currently sporting a pink big toe
#46 (permalink) |
'07 Black Exige S
Wouldn't the ECU detect more airflow and adjust to keep the fuel/ air mix the same as stock, thereby negating any gains from the high flow airbox?
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness |
#47 (permalink) |
Carpe Diem
Has anyone measured for performance gains on Exige S (stock software) with this filter/airbox combo?
That filter looks like what our cars should come with - easy to clean/reusable and higher air flow.
Justin 2007 Exige S: Laser Blue + Touring + Track Pack + Traction Control + Convertible Conversion + Carbon Fiber Console and HVAC surround + Aluminum Carpet Buttons + Toybox Hethel Wheels + Goodyear F1 Rubber + Ekological HID 2005 Elise (#267 Traded): Ardent Red/Black + Touring + Hardtop + Hurricane HID + JL Audio Stealthbox & Sub + Lanzar Opti 4x400D Amp + Alpine Type S & R speakers + iPod Hardwired 2001 Audi S4: Sold but not forgotten |
#49 (permalink) |
GGM ENFORCER
cup air filter: TRD PTR05-06990-01
Cup air filter: Green Filter P/N 2093 from 2001 Toyota Avalon 3L V6 - $85 Also used in 2002 Lexus RX330, 2002 Toyota Avalon, 2002 Toyota Solara
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 GG EXIGE S ** MY CAR ** VIDEO CLIPS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com Last edited by shay2nak : 04-24-2008 at 01:48 PM. |
#50 (permalink) |
Just for some more datapoints - found that the high flow airfilter (to be used with the Cup style airbox) is the same filter as used in:
2004 TOYOTA AVALON 3.0L V6 F/I - All 2003 TOYOTA SOLARA 3.0L V6 F/I - All 2003 TOYOTA SOLARA 2.4L L4 F/I - All 2003 TOYOTA SIENNA 3.0L V6 F/I - All 2003 TOYOTA AVALON 3.0L V6 F/I - All 2003 LEXUS RX300 3.0L V6 F/I - All 2002 TOYOTA SOLARA 3.0L V6 F/I - All 2002 TOYOTA SOLARA 2.4L L4 F/I - All 2002 TOYOTA SIENNA 3.0L V6 F/I - All 2002 TOYOTA AVALON 3.0L V6 F/I - All 2002 LEXUS RX300 3.0L V6 F/I - All 2001 TOYOTA SOLARA 3.0L V6 F/I - All 2001 TOYOTA SOLARA 2.2L L4 F/I - All 2001 TOYOTA SIENNA 3.0L V6 F/I - All 2001 TOYOTA CAMRY 3.0L V6 F/I - All 2001 TOYOTA CAMRY 2.2L L4 F/I - All 2001 TOYOTA AVALON 3.0L V6 F/I - All 2001 LEXUS RX300 3.0L V6 F/I - All 2001 LEXUS ES300 3.0L V6 F/I - All 2000 TOYOTA SOLARA 3.0L V6 F/I - All 2000 TOYOTA SOLARA 2.2L L4 F/I - All 2000 TOYOTA SIENNA 3.0L V6 F/I - All 2000 TOYOTA CAMRY 3.0L V6 F/I - All 2000 TOYOTA CAMRY 2.2L L4 F/I - All 2000 TOYOTA AVALON 3.0L V6 F/I - All 2000 LEXUS RX300 3.0L V6 F/I - All 2000 LEXUS ES300 3.0L V6 F/I - All 1999 TOYOTA SOLARA 3.0L V6 F/I - All 1999 TOYOTA SOLARA 2.2L L4 F/I - All 1999 TOYOTA SIENNA 3.0L V6 F/I - All 1999 TOYOTA CAMRY 3.0L V6 F/I - All 1999 TOYOTA CAMRY 2.2L L4 F/I - All 1999 TOYOTA AVALON 3.0L V6 F/I - All 1999 LEXUS RX300 3.0L V6 F/I - All 1999 LEXUS ES300 3.0L V6 F/I - All 1998 TOYOTA SIENNA 3.0L V6 F/I - All 1998 TOYOTA CAMRY 3.0L V6 F/I - All 1998 TOYOTA CAMRY 2.2L L4 F/I - All 1998 TOYOTA AVALON 3.0L V6 F/I - All 1998 LEXUS ES300 3.0L V6 F/I - All 1997 TOYOTA CAMRY 3.0L V6 F/I - All 1997 TOYOTA CAMRY 2.2L L4 F/I - All 1997 TOYOTA AVALON 3.0L V6 F/I - All 1997 LEXUS ES300 3.0L V6 F/I - All Air filter brands and part numbers: K&N part number - 33-2145-1 TRD high flow filter part number - PTR05-06990-01 Cup air filter: Green Filter part number - 2093 Lotus High Flow Air Filter part number - ALS3E0158F Non-'high flow' - AC - A1286C FRAM - CA7351 NAPA - 6017 PURO - A24690 TOYOTA - 1780103010 WIX - 46017 Stock vs Larger size: (is the larger not almost 2.5x the surface area?) Stock - Height: 1.26 in (32 mm) Outside Length: 10.512 in (267 mm) Outside Width: 4.213 in (107 mm) Larger (part numbers listed above) - Height: 1.125 in (29 mm) Outside Length: 12.125 in (308 mm) Outside Width: 7.25 in (184 mm) The air filter box: Finally to summarize the previous notes in this thread - the Cup style airbox that houses the larger than stock filters listed above are only available from Lotus (not TRD, there is no single Toyota part that makes up this airbox). Lotus part number ALS3E0157F Ok, did I get that right? ![]()
Click links to see my '99 M3, 505rwhp '89 Mustang, '05 WRX STI (
sold), and 2008 Lotus Exige-S 240 homepages or here for my M3 vid (11MB)Last edited by EricH : 06-06-2008 at 08:04 PM. Reason: Found filter sizes |
#51 (permalink) |
GGM ENFORCER
cup airbox is on back order for another week.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 GG EXIGE S ** MY CAR ** VIDEO CLIPS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com |
#52 (permalink) |
This thread metions a gap that needs to be sealed between the 'clean' side of the stock airbox and the adapter plate to the larger box. Anyone here install this and get a gasket with it?
Notes on Cup Airbox install...
sold), and 2008 Lotus Exige-S 240 homepages or here for my M3 vid (11MB) |
#53 (permalink) | |
GGM ENFORCER
#54 (permalink) |
Here is another new post, they also sealed the gap and there are good pics too (Thanks Johnny B!):
Don't Change Your Super Charger Pulley! ![]() ![]()
#56 (permalink) |
gas, gas, gas, gas
yup, thanks for the pics John.. I have just confirmed its the airbox used on supercharged scion TCs..
page 34 http://www.trdsparks.com/install/PTR01-21050-90inst.pdf Check out page 35, does lotus also toss in that trumpet?
Jay-05' ST, HT, Touring Red I have a theory that all.... ![]() Katana flags 9 VF flag 1 |
#58 (permalink) |
GGM ENFORCER
I got my airbox last week and I just ordered the green filter. It's 2 pieces like everyone says. It's even pictured in the Lotus Sport parts catalog. Not sure when I'm going to install mine though...maybe next oil change.
#59 (permalink) |
I got mine yesterday, finally looked at it today. For those of you that have installed (I don't have my car yet - so I can't compare to the original) - these are the parts that I got, one of them is broken - do I use all of these brackets or do I need to ask for it to be replaced?
See IMG_2511.JPG near the lower right for a closeup of the broken part, it is the smallest piece with a silver pin it in. Also covered by the adapter ring is another pin that is on the box that seems to have one of its mounts broken off.
sold), and 2008 Lotus Exige-S 240 homepages or here for my M3 vid (11MB)Last edited by EricH : 07-25-2008 at 04:51 AM. |
