Old 04-20-2009, 04:07 PM   #61 (permalink)
Nothing witty to say
Originally Posted by def View Post
I installed the manly engine mount inserts, and a new lotus sport clamp.
I feel like I should be OK. Hopefully I didn't previously (before I had the inserts) crack or weaken the area around the Cat. Haven't noticed any soot.
Hot days at thunderhill over this summer still have me worried, though.
How did the engine mount inserts affect the vibration in idle and under light load? My car is still a daily driver and I don't want any major additional rattles.
BTW, I also have the FF engine damper.
cstetter is offline   Reply With Quote
Old 04-20-2009, 04:39 PM   #62 (permalink)
Bane's Avatar
Images: 4
Originally Posted by Krug1 View Post
I just had a Weapon R header installed. Today when I went to pick up the old parts, I noticed that they did not reinstall any of the heat shields. The guy that did the installation said there wasn't any room and something about the heat shield not being able to bolt to the header??? Does this sound correct? Also, I noticed already due to the stock exhaust, a very small area about the size of a dime seems to have been melted through my diffuser prior to the header install. Should I be concerned about melting/fire and excessive heat. Keep in mind that I don't plan on tracking my car, at least not right now.
They said they could wrap the header, which may be the route to go, but I wish they would have brought this to my attention sooner. I am not going to be real pleased to have to pay more money to someone to do work that could have been done in the first place. There goes another hundred$$$.
Like to hear you all's input
Andy
Yes that sounds correct.
The Weapon R header also doesn't have a flex joint in there so it's really important to upgrade your motor mounts to try to prolong it's life.
Wrapping will help but won't be nearly as effective as a proper coating. If you're concerned about heat I would probably do it if I were you.
*edit* The motor mounts made a noticeable difference (both positive and negative) for me. Since it's not my DD I love them. It's a little annoying with the extra vibration (especially when taking off from a stop) but nothing that's deal-breaking IMO.
$599 PPE header (INFO)
2007 BMW 335i - Mostly stock
un-Official LotusTalk Stealth Bulb provider *6* sets in stock!
Old 04-20-2009, 05:51 PM   #63 (permalink)
def
...ault
def's Avatar
The vibration is noticable a little bit, but doesn't bother me. It may bother some people, but I would think if you drive a lotus, you wouldn't care since you put up with so much other stuff. Hop in my car sometime and see for yourself
//kevin - 05 Graphite Gray - Red Touring / LSS / Starshield / Stage 2 + more
def is offline   Reply With Quote
Old 04-25-2009, 08:43 PM   #64 (permalink)
Images: 7
Bane,
I am really interested in getting this type of coating. What is the theory behind it -- how does it keep things cooler? It is really just a ceramic coating, right? Does it just keep the heat in the system until it is expellled via the exhaust instead of letting it dissipate en route?
Originally Posted by Bane View Post
Just to add a bit of information... the mil-spec coating I put on the PPE headers makes a WORLD of difference in terms of heat management.
My boot used to get so hot with the stock header that I could barely touch the carpet buttons in there.
Now it was cool to the touch after a track day and after sitting in traffic in 90 degree heat.
This applies to all exhaust systems so even if you aren't using my setup I highly recommend the coating...
lotusland is offline   Reply With Quote
Old 04-25-2009, 09:04 PM   #65 (permalink)
Head LOONY
tvacc's Avatar
Originally Posted by lotusland View Post
Bane,
Where did you get this coating?
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus
Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances
tvacc is offline   Reply With Quote
Old 04-26-2009, 01:21 PM   #66 (permalink)
Bane's Avatar
Images: 4
Lotusland: You are correct on the theory of operation. It's a ceramic coating on both the inside and the outside of the piping allowing the gases to stay as hot as possible inside the piping.
tvacc: I offer this coating on the PPE headers. I'm debating not even making it optional anymore as it's proven to be well worth the added cost. It's made by a company called N-coat/HPC (nCoat, Inc. Innovating the Next Generation of Coating Technologies). They are local and do some of the best coating work I've ever seen.
Old 04-26-2009, 02:07 PM   #67 (permalink)
Head LOONY
tvacc's Avatar
I asked because I have a Caterham Seven and I had the headers coated by a company south of Rochester NY. ()name not necessay as I dont wantt to give them negative pubicity...as I like the guys) It was a ceramic coating and was supposed to be cooler but I really did not see any difference. Of course it would have to be possible to remove the current coating by some means. I am not going to buy another set of $400 headers to do this.
Just wanted to know if it it was possible...and the cost.
Tony Vaccaro
Old 04-27-2009, 12:13 PM   #68 (permalink)
Bane's Avatar
Images: 4
As far as I know, the coating is a permanent process. It actually bonds to the metal so you can't easily remove it.
This is getting a little off topic though... PM me if you want more information about the coating.
Back on to the original topic: Another side benefit of the coating is that it adds a mil or two of material to the header, making the slip joint a much tighter fit
Old 06-09-2009, 04:04 PM   #69 (permalink)
jmiesse's Avatar
Found my exhaust clamp loose after Barber!
Just for the sake of it everyone should go under the car and see if the exhaust can be slid fore and aft by hand. Or just check the clamp if your not sure by taking off the diffuser. It could save your car and or your life!
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II
Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror
jmiesse is offline   Reply With Quote
Old 07-02-2009, 11:27 AM   #70 (permalink)
Bane's Avatar
Images: 4
I'd like to introduce the Bane/PPE MOAC (Mother Of All Clamps):
It'll fit right onto one of our headers but requires a little trimming of the stock cat heat shield. This is the best solution we could come up with short of installing proper v-bands for our questionable slip fit exhaust systems...
Official information will be in another thread. I just wanted to post the teaser pic here so people know they have a few options!
... and yes that's a prototype 3" muffler that'll bolt right up to your factory exhaust system
Old 07-02-2009, 02:58 PM   #71 (permalink)
sleepe's Avatar
The clamp that arrived with my Larini 8" broke last week. It performed fairly well for about a year, but it always had a small leak. I got the s111 accuseal clamp, but haven't installed it yet.
Where did you find that monster clamp?
-Robert
Elise'06ST:[size="1"]RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi-Nitron sportpro-RTVbrace-widened undertrays-VF2-manly's inserts-engine damper
sleepe is offline   Reply With Quote
Old 07-02-2009, 03:05 PM   #72 (permalink)
Head LOONY
tvacc's Avatar
I got the one I used from summitracing.com
Dynomax Performance 33226 - Dynomax Lap-Joint Band Clamps – SummitRacing.com
I dont know if that is the correct size, I just did a quick search on "clamps" at Summit
I bought one for my Seven..have not put it on the Elise yet.
Tony Vaccaro
Old 07-02-2009, 03:08 PM   #73 (permalink)
Head LOONY
tvacc's Avatar
Here is a link that shows them all...
SummitRacing.com
Tony Vaccaro
Old 08-08-2009, 05:41 PM   #74 (permalink)
Andy, ive had 3 brake 1 on the elise and 2 on the exige. a good thing to check before each track day. How did you fix it so you could run the TT?. carl
User formerly known as 4carl
carl is offline   Reply With Quote
Old 08-08-2009, 06:02 PM   #75 (permalink)
Form and Function
plastique999's Avatar
Yes, and my small clamp on my 2bular exhaust also failed - actually, the nut cracked in half.
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 08-08-2009, 09:57 PM   #76 (permalink)
sleepe's Avatar
I finally installed the s111 accuseal slip-fit clamp. It is a monster clamp, with a thick band and huge bolt. I torqued it down to 35 ft/lbs no problem. I comparison the Larini clamp looks like a ziptie.
Highly recommended!
